joerg@linux-l63w:~/freetz-trunk> rm -rf source/jabberd-1.4.4/
joerg@linux-l63w:~/freetz-trunk> make jabberd-precompiled
which: no intltool-update in (/home/joerg/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/gnome/bin)
WARNING: The program intltool-update was not found in path.
PATH="/home/joerg/freetz-trunk/toolchain/target/bin:/home/joerg/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/gnome/bin" \
make -j2 -C source/libidn-1.15
cat: ./.prev-version: Datei oder Verzeichnis nicht gefunden
make[1]: Entering directory `/home/joerg/freetz-trunk/source/libidn-1.15'
make[1]: Leaving directory `/home/joerg/freetz-trunk/source/libidn-1.15'
sed -i -r -e "s,^libdir=('?)(.*)('?)$,libdir=\1/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc\2\3,g" -e "s,^includedir=('?)(.*)('?)$,includedir=\1/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc\2\3,g" -e "s,^prefix=('?)(.*)('?)$,prefix=\1/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc\2\3,g" -e "s,^exec_prefix=('?)(.*)('?)$,exec_prefix=\1/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc\2\3,g" \
/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libidn.la
cp -a /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libidn*.so* root/usr/lib/
/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} root/usr/lib/libidn.so.11
rm -f -r source/jabberd-1.4.4
tar -C source -v -xzf dl/jabberd-1.4.4.tar.gz
jabberd-1.4.4/man/jabber.xml.5.in
shopt -s nullglob; for i in make/jabberd/patches/*.patch; do tools/freetz_patch source/jabberd-1.4.4 $i; done
applying patch file make/jabberd/patches/101_configure_fix_libtool_tag.patch
patching file configure
applying patch file make/jabberd/patches/102_fix_libjabberd_la.patch
patching file jabberd/Makefile.in
touch source/jabberd-1.4.4/.unpacked
( cd source/jabberd-1.4.4; rm -f config.{cache,status} ; source /home/joerg/freetz-trunk/make/config.mipsel ; PATH=""/home/joerg/freetz-trunk/toolchain/target/bin:/home/joerg/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/gnome/bin"" CC="/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc" CXX="/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/home/joerg/freetz-trunk/toolchain/target/bin/../lib/pkgconfig" ./configure --cache-file=/home/joerg/freetz-trunk/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --with-tags=CXX --enable-shared --enable-static )
configure: loading cache /home/joerg/freetz-trunk/make/config.cache
checking for a BSD-compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking for postgresql/libpq-fe.h... (cached) no
checking for postgresql... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating jabberd/Makefile
config.status: creating jabberd/base/Makefile
config.status: creating jabberd/lib/Makefile
config.status: creating dialback/Makefile
config.status: creating dnsrv/Makefile
config.status: creating jsm/Makefile
config.status: creating jsm/modules/Makefile
config.status: creating man/Makefile
config.status: creating pthsock/Makefile
config.status: creating xdb_file/Makefile
config.status: creating xdb_sql/Makefile
config.status: creating config.h
config.status: executing depfiles commands
You may now type 'make' to build your new Jabber system.
Type 'make install' to install then.
touch source/jabberd-1.4.4/.configured
PATH=""/home/joerg/freetz-trunk/toolchain/target/bin:/home/joerg/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/gnome/bin"" \
make -j2 -C source/jabberd-1.4.4 \
LDFLAGS="-lm -ldl -lm -ldl" \
CC="/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc" \
make[1]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4'
make all-recursive
/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -shared -nostdlib /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crti.o /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/crtbeginS.o .libs/config.o .libs/heartbeat.o .libs/load.o .libs/mio.o .libs/mio_ssl.o .libs/mtq.o .libs/xdb.o .libs/deliver.o .libs/log.o .libs/mio_raw.o .libs/mio_xml.o -Wl,--whole-archive ../jabberd/lib/.libs/libjabberdlib.a -Wl,--no-whole-archive -Wl,--rpath -Wl,/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib -Wl,--rpath -Wl,/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib -lm -ldl -lresolv /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libidn.so /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libpth.so /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libexpat.so -L/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/ -L/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/ -L/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4 -L/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc -L/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib -luClibc++ -lc -lgcc -lgcc_s /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/crtendS.o /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/bin-ccache/../lib/gcc/mipsel-linux-uclibc/4.2.4/../../../../mipsel-linux-uclibc/lib/crtn.o -march=4kc -Wl,-soname -Wl,libjabberd.so.0 -o .libs/libjabberd.so.0.0.0
(cd .libs && rm -f libjabberd.so.0 && ln -s libjabberd.so.0.0.0 libjabberd.so.0)
(cd .libs && rm -f libjabberd.so && ln -s libjabberd.so.0.0.0 libjabberd.so)
rm -fr .libs/libjabberd.lax
mkdir .libs/libjabberd.lax
rm -fr .libs/libjabberd.lax/libjabberdlib.a
mkdir .libs/libjabberd.lax/libjabberdlib.a
(cd .libs/libjabberd.lax/libjabberdlib.a && mipsel-linux-ar x /home/joerg/freetz-trunk/source/jabberd-1.4.4/jabberd/../jabberd/lib/.libs/libjabberdlib.a)
mipsel-linux-ar cru .libs/libjabberd.a config.o heartbeat.o load.o mio.o mio_ssl.o mtq.o xdb.o deliver.o log.o mio_raw.o mio_xml.o .libs/libjabberd.lax/libjabberdlib.a/xhash.o .libs/libjabberd.lax/libjabberdlib.a/xmlnode.o .libs/libjabberd.lax/libjabberdlib.a/pproxy.o .libs/libjabberd.lax/libjabberdlib.a/jpacket.o .libs/libjabberd.lax/libjabberdlib.a/jid.o .libs/libjabberd.lax/libjabberdlib.a/sha.o .libs/libjabberd.lax/libjabberdlib.a/karma.o .libs/libjabberd.lax/libjabberdlib.a/jutil.o .libs/libjabberd.lax/libjabberdlib.a/socket.o .libs/libjabberd.lax/libjabberdlib.a/crc32.o .libs/libjabberd.lax/libjabberdlib.a/pool.o .libs/libjabberd.lax/libjabberdlib.a/expat.o .libs/libjabberd.lax/libjabberdlib.a/xstream.o .libs/libjabberd.lax/libjabberdlib.a/snprintf.o .libs/libjabberd.lax/libjabberdlib.a/str.o .libs/libjabberd.lax/libjabberdlib.a/base64.o .libs/libjabberd.lax/libjabberdlib.a/genhash.o .libs/libjabberd.lax/libjabberdlib.a/rate.o
mipsel-linux-ranlib .libs/libjabberd.a
creating libjabberd.la
(cd .libs && rm -f libjabberd.la && ln -s ../libjabberd.la libjabberd.la)
/bin/sh ../libtool --tag=CXX --mode=link /home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -lm -ldl -lm -ldl -o jabberd -export-dynamic jabberd.o static.o ../jabberd/base/libjabberdbase.la libjabberd.la -lresolv -lidn -lpth -lexpat
/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -o .libs/jabberd jabberd.o static.o -Wl,--export-dynamic ../jabberd/base/.libs/libjabberdbase.a -lm -ldl ./.libs/libjabberd.so -lresolv /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libidn.so /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libpth.so /home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libexpat.so -Wl,--rpath -Wl,/home/joerg/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib
creating jabberd
make[4]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/jabberd'
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/jabberd'
Making all in dialback
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/dialback'
Making all in dnsrv
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/dnsrv'
Making all in jsm
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/jsm'
Making all in pthsock
make[3]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/pthsock'
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/pthsock'
Making all in xdb_file
make[3]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/xdb_file'
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/xdb_file'
Making all in xdb_sql
make[3]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/xdb_sql'
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/xdb_sql'
Making all in man
make[3]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/man'
generating jabberd.8 from jabberd.8.in
generating jabber.xml.5 from jabber.xml.5.in
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4/man'
make[3]: Entering directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4'
generating jabber.xml.dist from jabber.xml.dist.in
make[3]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4'
make[2]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4'
make[1]: Leaving directory `/home/joerg/freetz-trunk/source/jabberd-1.4.4'
mkdir -p packages/jabberd-1.4.4/root/usr/bin/
cp source/jabberd-1.4.4/jabberd/.libs/jabberd packages/jabberd-1.4.4/root/usr/bin/jabberd
/home/joerg/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/jabberd-1.4.4/root/usr/bin/jabberd
