Fehler bei PS3 Media Server mit Fritzbox 7390
works
9 Nov 2010
Hallo, habe immer den PS3 Media Server benutzt mit meiner alten Fritzbox 7170, hat alles ohne Probleme funktioniert. In der neuen Wohnung haben wir die Fritzbox 7390 bekommen und leider komm ich von der PS3 nicht mehr auf den PS3 Media Server auf dem Imac.
Habe die IP schon manuell eingegeben.
hier die Fehlermeldung.
[main] TRACE 13:05:07.390 Starting Java PS3 Media Server v1.20.409
[main] TRACE 13:05:07.535 by shagrath / 2008-2010
[main] TRACE 13:05:07.539 http://ps3mediaserver.blogspot.com
[main] TRACE 13:05:07.539 http://code.google.com/p/ps3mediaserver
[main] TRACE 13:05:07.540
[main] TRACE 13:05:07.540 Java 1.6.0_22-Apple Inc.
[main] TRACE 13:05:07.540 OS Mac OS X x86_64 10.6.4
[main] TRACE 13:05:07.540 Encoding: UTF-8
[main] TRACE 13:05:07.545 Temp folder: /var/folders/ge/geWdp6OFH9a61gRLbKb5N++++TI/-Tmp-/javaps3media
[main] TRACE 13:05:07.605 Loading configuration file: Bravia4500.conf
[main] TRACE 13:05:07.609 Loading configuration file: Bravia5500.conf
[main] TRACE 13:05:07.614 Loading configuration file: FreeboxHD.conf
[main] TRACE 13:05:07.615 Loading configuration file: Kuro.conf
[main] TRACE 13:05:07.618 Loading configuration file: Philips.conf
[main] TRACE 13:05:07.620 Loading configuration file: PopcornHour.conf
[main] TRACE 13:05:07.622 Loading configuration file: PS3.conf
[main] TRACE 13:05:07.627 Loading configuration file: Realtek.conf
[main] TRACE 13:05:07.630 Loading configuration file: Samsung.conf
[main] TRACE 13:05:07.631 Loading configuration file: Streamium.conf
[main] TRACE 13:05:07.634 Loading configuration file: WDTVLive.conf
[main] TRACE 13:05:07.636 Loading configuration file: XBMC.conf
[main] TRACE 13:05:07.637 Loading configuration file: XBOX360.conf
[main] TRACE 13:05:07.640 Checking font cache... launching simple instance of MPlayer... You may have to wait 60 seconds !
[main] TRACE 13:05:07.736 Done!
[main] TRACE 13:05:07.746 Registering transcoding engine FFmpeg Audio
[main] TRACE 13:05:07.750 Registering transcoding engine MEncoder
[main] TRACE 13:05:07.751 Registering transcoding engine MPlayer Audio
[main] TRACE 13:05:07.752 Registering transcoding engine MEncoder Web
[main] TRACE 13:05:07.752 Registering transcoding engine MPlayer Video Dump
[main] TRACE 13:05:07.752 Registering transcoding engine MPlayer Web
[main] TRACE 13:05:07.753 Registering transcoding engine TsMuxer
[main] TRACE 13:05:07.753 Registering transcoding engine Audio High Fidelity
[main] TRACE 13:05:07.754 Registering transcoding engine VideoLan Audio Streaming
[main] TRACE 13:05:07.754 Registering transcoding engine VideoLan Video Streaming
[main] TRACE 13:05:07.754 Registering transcoding engine Raws Thumbnailer
[main] TRACE 13:05:07.930 Scanning network interface vnic1 / vnic1
[main] TRACE 13:05:07.932 Scanning network interface vnic0 / vnic0
[main] TRACE 13:05:07.932 Scanning network interface en1 / en1
[main] TRACE 13:05:07.932 Scanning network interface lo0 / lo0
[main] TRACE 13:05:07.933 Using forced address 192.168.178.1
[main] TRACE 13:05:07.934 Created socket: /192.168.178.1:5001
[main] TRACE 13:05:07.942 FATAL ERROR : Unable to bind on port: 5001 cause: Can't assign requested address
[main] TRACE 13:05:07.942 Maybe another process is running or hostname is wrong...
[main] TRACE 13:05:07.943 Some serious errors occurs...
Dort müsste die IP Adresse des Rechners stehen, also die Server IP.
Geh unter PS3 Media Server auf :
"Allgemeine Einstellungen"
und wähle dort die Netzwerkkarte aus und schreibe zur not die IP Adresse deines Rechners bei "Erzwinge IP Adresse" rein.
Normalerweise reicht es aber auch wenn man die Netzwerkkarte festlegt.
