Fehler beim compilieren von 2.6er Kernel DS Mod
Seppl82
14 Okt 2006
bei mir ist nachfolgender Fehler bei
"make precompile"
aufgetreten, irgendeine Idee wie ich es trotzdem zum laufen kriegen kann?
Hab die: 7170
Hab den: ds-0.2.9_26-12 mit Patch! (FW 29.04.29)
Hab das: SuSE Linux 10.1
Dankeschön
make[5]: Entering directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchai n/binutils-2.16.91.0.6/bfd/doc'
make[5]: `chew' is up to date.
make[5]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6/bfd/doc'
./chew -f ../.././bfd/doc/doc.str <../.././bfd/doc/../mmo.c >mmo.tmp
/bin/sh ../.././bfd/doc/../../move-if-change mmo.tmp mmo.texi
restore=: && backupdir=".am$$" && \
am__cwd=`pwd` && cd ../.././bfd/doc && \
rm -rf $backupdir && mkdir $backupdir && \
for f in ../.././bfd/doc/bfd.info ../.././bfd/doc/bfd.info-[0-9] ../.././bfd/doc /bfd.info-[0-9][0-9] ../.././bfd/doc/bfd.i[0-9] ../.././bfd/doc/bfd.i[0-9][0-9];  do \
  if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
cd "$am__cwd"; \
if /home/frsc/downloads/ds-0.2.9_26-12/source/toolchain/binutils-2.16.91.0.6/mis sing makeinfo --split-size=5000000 --split-size=5000000   -I ../.././bfd/doc \
 -o ../.././bfd/doc/bfd.info ../.././bfd/doc/bfd.texinfo; \
then \
  rc=0; \
  cd ../.././bfd/doc; \
else \
  rc=$?; \
  $restore $backupdir/* `echo "./../.././bfd/doc/bfd.info" | sed 's|[^/]*$||'`; \
fi; \
rm -rf $backupdir; exit $rc
WARNING: `makeinfo' is missing on your system.  You should only need it if
         you modified a `.texi' or `.texinfo' file, or any other file
         indirectly affecting the aspect of the manual.  The spurious
         call might also be the consequence of using a buggy `make' (AIX,
         DU, IRIX).  You might want to install the `Texinfo' package or
         the `GNU make' package.  Grab either from any GNU archive site.
make[4]: *** [../.././bfd/doc/bfd.info] Error 1
make[4]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6/bfd/doc'
Making info in po
make[4]: Entering directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchai n/binutils-2.16.91.0.6/bfd/po'
( if test 'x../.././bfd/po' != 'x.'; then \
    posrcprefix='../.././bfd/'; \
  else \
    posrcprefix="../"; \
  fi; \
  rm -f SRC-POTFILES-t SRC-POTFILES \
    && (sed -e '/^#/d' \
            -e '/^[     ]*$/d' \
            -e "s@.*@   $posrcprefix& \\\\@" < ../.././bfd/po/SRC-POTFILES.in \
        | sed -e '$s/\\$//') > SRC-POTFILES-t \
    && chmod a-w SRC-POTFILES-t \
    && mv SRC-POTFILES-t SRC-POTFILES )
( rm -f BLD-POTFILES-t BLD-POTFILES \
            -e '/^[     ]*$/d' \
            -e "s@.*@   ../& \\\\@" < ../.././bfd/po/BLD-POTFILES.in \
        | sed -e '$s/\\$//') > BLD-POTFILES-t \
    && chmod a-w BLD-POTFILES-t \
    && mv BLD-POTFILES-t BLD-POTFILES )
cd .. \
  && CONFIG_FILES=po/Makefile.in:po/Make-in \
     CONFIG_HEADERS= /bin/sh ./config.status
config.status: creating po/Makefile.in
config.status: executing depfiles commands
config.status: executing default commands
make[4]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6/bfd/po'
make[4]: Nothing to be done for `info'.
make[4]: Entering directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchai n/binutils-2.16.91.0.6/bfd'
make[4]: Nothing to be done for `info-am'.
make[4]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6/bfd'
make[3]: *** [info-recursive] Error 1
make[3]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6/bfd'
make[2]: *** [all-bfd] Error 2
make[2]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain /binutils-2.16.91.0.6'
make: *** [/home/frsc/downloads/ds-0.2.9_26-12/source/toolchain/binutils-2.16.91 .0.6/binutils/objdump] Error 2
frsc@brainfuck:~/downloads/ds-0.2.9_26-12>
Suchfunktion benutzen...
Lösung
MfG Oliver
holh-66
