Fehler beim erstellen vom trunk
hans75
2 Mai 2009
ich bekomme immer folgenden Fehler beim erstellen:
  CC      drivers/net/avm_cpmac/cpmac_fusiv_if.o
  CC      drivers/net/avm_cpmac/cpmac_puma_if.o
  CC      drivers/net/avm_cpmac/cpphy_switch.o
make[4]: *** Keine Regel vorhanden, um das Target »drivers/net/avm_cpmac/cpmac_product_conf.o«,
  benötigt von »drivers/net/avm_cpmac/avm_cpmac.o«, zu erstellen.  Schluss.
make[4]: *** Warte auf noch nicht beendete Prozesse...
  LD      net/802/built-in.o
  CC      net/8021q/vlan_core.o
  LD      net/8021q/built-in.o
  CC      net/atm/addr.o
make[3]: *** [drivers/net/avm_cpmac] Fehler 2
make[2]: *** [drivers/net] Fehler 2
make[1]: *** [drivers] Fehler 2
make[1]: *** Warte auf noch nicht beendete Prozesse...
  LD      net/bluetooth/built-in.o
  LD      net/bluetooth/bnep/built-in.o
  LD      net/bluetooth/rfcomm/built-in.o
  CC      net/bridge/br.o
  CC      net/atm/pvc.o
  CC      net/bridge/br_device.o
  CC      net/atm/signaling.o
  CC      net/bridge/br_fdb.o
  CC      net/atm/svc.o
  CC      net/bridge/br_forward.o
  CC      net/bridge/br_if.o
  CC      net/atm/ioctl.o
  CC      net/atm/common.o
  CC      net/bridge/br_input.o
  CC      net/bridge/br_ioctl.o
  CC      net/atm/atm_misc.o
  CC      net/bridge/br_notify.o
  CC      net/atm/raw.o
  CC      net/bridge/br_stp.o
  CC      net/atm/resources.o
  CC      net/bridge/br_stp_bpdu.o
  CC      net/atm/atm_sysfs.o
  CC      net/bridge/br_stp_if.o
  CC      net/atm/proc.o
  CC      net/bridge/br_stp_timer.o
  CC      net/atm/br2684.o
  CC      net/bridge/br_netlink.o
  CC      net/bridge/br_sysfs_if.o
  LD      net/atm/atm.o
  LD      net/atm/built-in.o
  CC      net/core/sock.o
  CC      net/bridge/br_sysfs_br.o
  LD      net/bridge/bridge.o
  LD      net/bridge/built-in.o
  CC      net/ethernet/eth.o
  LD      net/ethernet/built-in.o
  LD      net/ieee802154/built-in.o
  CC      net/ipv4/route.o
  CC      net/core/request_sock.o
  CC      net/core/skbuff.o
  CC      net/ipv4/inetpeer.o
  CC      net/core/iovec.o
  CC      net/ipv4/protocol.o
  CC      net/core/datagram.o
  CC      net/ipv4/ip_input.o
  CC      net/core/stream.o
  CC      net/ipv4/ip_fragment.o
  CC      net/core/scm.o
  CC      net/ipv4/ip_forward.o
  CC      net/core/gen_stats.o
  CC      net/ipv4/ip_options.o
  CC      net/core/gen_estimator.o
  CC      net/core/net_namespace.o
  CC      net/ipv4/ip_output.o
  CC      net/core/sysctl_net_core.o
  CC      net/core/skb_dma_map.o
  CC      net/core/dev.o
  CC      net/ipv4/ip_sockglue.o
  CC      net/ipv4/inet_hashtables.o
  CC      net/ipv4/inet_timewait_sock.o
  CC      net/core/ethtool.o
  CC      net/ipv4/inet_connection_sock.o
  CC      net/ipv4/tcp.o
  CC      net/core/dev_mcast.o
  CC      net/core/dst.o
  CC      net/core/netevent.o
  CC      net/core/neighbour.o
  CC      net/ipv4/tcp_input.o
  CC      net/core/rtnetlink.o
  CC      net/core/utils.o
  CC      net/core/link_watch.o
  CC      net/ipv4/tcp_output.o
  CC      net/core/filter.o
  CC      net/core/net-sysfs.o
  CC      net/ipv4/tcp_timer.o
  LD      net/core/built-in.o
  CC      net/ipv6/af_inet6.o
  CC      net/ipv4/tcp_ipv4.o
  CC      net/ipv6/anycast.o
  CC      net/ipv6/ip6_output.o
  CC      net/ipv4/tcp_minisocks.o
  CC      net/ipv4/tcp_cong.o
  CC      net/ipv6/ip6_input.o
  CC      net/ipv4/datagram.o
  CC      net/ipv6/addrconf.o
  CC      net/ipv4/raw.o
  CC      net/ipv4/udp.o
  CC      net/ipv6/addrlabel.o
  CC      net/ipv4/udplite.o
  CC      net/ipv4/arp.o
  CC      net/ipv6/route.o
  CC      net/ipv4/icmp.o
  CC      net/ipv6/ip6_fib.o
  CC      net/ipv4/devinet.o
  CC      net/ipv6/ipv6_sockglue.o
  CC      net/ipv4/af_inet.o
  CC      net/ipv6/ndisc.o
  CC      net/ipv4/igmp.o
  CC      net/ipv6/udp.o
  CC      net/ipv4/fib_frontend.o
  CC      net/ipv6/udplite.o
  CC      net/ipv6/raw.o
  CC      net/ipv4/fib_semantics.o
  CC      net/ipv6/protocol.o
  CC      net/ipv4/inet_fragment.o
  CC      net/ipv6/icmp.o
  CC      net/ipv4/sysctl_net_ipv4.o
  CC      net/ipv4/fib_hash.o
  CC      net/ipv6/mcast.o
  CC      net/ipv4/proc.o
  CC      net/ipv4/ipmr.o
  CC      net/ipv6/reassembly.o
  CC      net/ipv4/inet_lro.o
  CC      net/ipv6/tcp_ipv6.o
  CC      net/ipv4/ipconfig.o
  CC      net/ipv6/exthdrs.o
  CC      net/ipv4/netfilter.o
  CC      net/ipv6/datagram.o
  LD      net/ipv4/netfilter/built-in.o
  CC      net/ipv4/tcp_cubic.o
  CC      net/ipv4/mcfastforward.o
  CC      net/ipv6/ip6_flowlabel.o
  CC      net/ipv6/inet6_connection_sock.o
  CC      net/ipv6/sysctl_net_ipv6.o
  LD      net/ipv4/built-in.o
  CC      net/llc/llc_core.o
  CC      net/ipv6/ip6mr.o
  CC      net/llc/llc_input.o
  CC      net/llc/llc_output.o
  LD      net/llc/llc.o
  LD      net/llc/built-in.o
  CC      net/netfilter/core.o
  CC      net/ipv6/netfilter.o
  CC      net/netfilter/nf_log.o
  CC      net/ipv6/proc.o
  CC      net/netfilter/nf_queue.o
  LD      net/ipv6/netfilter/built-in.o
  CC      net/ipv6/addrconf_core.o
  CC      net/netfilter/nf_sockopt.o
  CC      net/ipv6/exthdrs_core.o
  LD      net/netfilter/netfilter.o
  LD      net/netfilter/built-in.o
  CC      net/netlink/af_netlink.o
  CC      net/ipv6/inet6_hashtables.o
  LD      net/ipv6/ipv6.o
  LD      net/ipv6/built-in.o
  CC      net/packet/af_packet.o
  CC      net/netlink/genetlink.o
  LD      net/netlink/built-in.o
  CC      net/sched/sch_generic.o
  LD      net/packet/built-in.o
  LD      net/sunrpc/built-in.o
  CC      net/unix/af_unix.o
  CC      net/sched/sch_mq.o
  CC      net/sched/sch_api.o
  CC      net/unix/garbage.o
  CC      net/unix/sysctl_net_unix.o
  CC      net/sched/sch_blackhole.o
  LD      net/unix/unix.o
  LD      net/unix/built-in.o
  CC      net/wireless/wext.o
  CC      net/sched/cls_api.o
  LD      net/wireless/built-in.o
  CC      net/sysctl_net.o
  CC      net/sched/sch_fifo.o
  LD      net/sched/built-in.o
  LD      net/built-in.o
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/kernel/ref-ur8-16mb-7270_05.05/linux-2.6.32'
ERROR: Build failed.
make: *** [source/kernel/ref-ur8-16mb-7270_05.05/linux-2.6.32/vmlinux.eva_pad] Fehler 1
Der Fehler kommt vermutlich von cpmac, das habe ich aber schon abgewählt (siehe config) und trotzdem kommt der Fehler?
Weiss jemand eine Lösung?
Danke!
ah, ok. Der ist von heute.
Dann probier ich es ein anderes mal erneut.
Schönes WE.
Probier bitte nochmal.
svn up
make kernel-dirclean
make
Sorry dass ich mich erst jetzt melde....
Hat geklappt, danke!!
Gut dann mach ich hier zu.
Oliver
atrora
