Fehler IAXMODEM
Beebob007
26 Mai 2008
hallo, ich bekomme folgenden Fehler:
[Mar 3 04:02:57] NOTICE[3906] chan_iax2.c: Restricting registration for peer '30' to 60 seconds (requested 50)
Eine Änderung in der iax.conf brachte nichts:
; Minimum and maximum amounts of time that IAX peers can request as
; a registration expiration interval (in seconds).
minregexpire = 60
maxregexpire = 60
Wie kann ich den fehler beheben?
Beebob007
Ich sehe keinen Fehler nur eine Mitteilung.
ja richtig, aber die bedeutet doch,dass ich den wert auf 60 setzen soll.aber wo mach ich das?die mitteilung müäät mir die logfile voll......
Asterisk Version? iax.conf oder iax2.conf? [general] section?
hi,
asterisk 1.4.22-3
unter /etc/asterisk/ nur eine iax.conf
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make ;
; custom modifications, details at: http://freepbx.org/configuration_files ;
[general]
; These will all be included in the [general] context
#include iax_general_additional.conf
#include iax_general_custom.conf
#include iax_registrations_custom.conf
#include iax_registrations.conf
; These should all be expected to come after the [general] context
;iax_custom.conf is the proper place to start creating new contexts that you
;might have a need for. Dundi IAX trunks is one example of when this file is needed.
#include iax_custom.conf
#include iax_additional.conf
;iax_custom_post.conf will allow you to modify FreePBX generated IAX setups so
;that you can add additional parameters to a auto-generated setup.
;if you have a auto-generated context of [foobar] and need to add a parameter
;to it then create this line [foobar](+) and place your additions on the next line
#include iax_custom_post.conf
und in der \etc\asterisk\iax_general_additional.conf steht folgendes:
disallow=all
allow=ulaw
allow=alaw
allow=gsm
mailboxdetail=yes
tos=ef
gruß und frohe ostern weiterhin
keiner eine idee???
das muß doch zu lösen sein.....
Na dann zelegen wir das ganze mal:
Restricting registration for peer '30'.......
meint die CLI und will dir damit sagen,
irgendetwas passt nicht für peer 30!
Ich sehe nix von [30] in deinen conf's.
Also, schau bitte selber mal wo da was steht.
Ich glaube der peer ist in dem Fall wohl eher Nebensache.
If you have "update_registry: Restricting registration for peer 'xxxxxx' to 60 seconds (requested 1200)", you can add maxregexpire=1300 to the [general] section.
Für mich ist halt nur die Frage wie und wo man das für FreePBX hinterlegen muss.
@stinkstifel
Wo bitte holst du denn _das_ Zitat her?
hi,
im grundegenommen hat stinkstiefel aber recht.egal für welche nr. muss es doch immer die gleiche datei sein die editiert werden muß, oder?
so, ich hab noch folgendes gefunden:
iax_additional.conf:
; custom modifications, details at: [url]http://freepbx.org/configuration_files[/url]       ;
[30]
deny=0.0.0.0/0.0.0.0
type=friend
setvar=REALCALLERIDNUM=30
secret=*********
qualify=yes
port=4570
permit=0.0.0.0/0.0.0.0
transfer=no
mailbox=30@device
host=dynamic
dial=IAX2/30
context=from-internal
callerid=device <30>
accountcode=
muss hier:
minregexpire = 60
maxregexpire = 60
rein???laut diverser hilfen muß das in iax.conf oder iax2.conf...... :confused:
IchBinEsDoch
