Fehler make[2]: *** [applets/applet_tables] Error 1
imaccookie
26 Jun 2006
Hallo nach dem ich die Optionen ausgewählt habe und den Befehl make gemacht habe bekommen ich einen Fehler, ich habe den ganzen Output mal mit rein gehängt.
Vielleicht kann mir jemand einen Tipp geben.
Vielen Dank im Vorraus
Götz
[Edit frank_m24: Bitte benutzt CODE Tags für lange Ausgaben.]
uname: illegal option -- o
usage: uname [-amnprsv]
make -j2 -C source/busybox-tools/busybox-1.9.2
  HOSTCC  applets/applet_tables
  LD      archival/built-in.o
ar: no archive members specified
usage:  ar -d [-TLsv] archive file ...
	ar -m [-TLsv] archive file ...
	ar -m [-abiTLsv] position archive file ...
	ar -p [-TLsv] archive [file ...]
	ar -q [-cTLsv] archive file ...
	ar -r [-cuTLsv] archive file ...
	ar -r [-abciuTLsv] position archive file ...
	ar -t [-TLsv] archive [file ...]
	ar -x [-ouTLsv] archive [file ...]
make[2]: *** [archival/built-in.o] Error 1
make[1]: *** [archival] Error 2
make[1]: *** Waiting for unfinished jobs....
In file included from applets/../include/libbb.h:13,
                 from applets/../include/busybox.h:10,
                 from applets/applet_tables.c:16:
applets/../include/platform.h:145: error: conflicting types for ‘socklen_t’
/usr/include/sys/socket.h:108: error: previous declaration of ‘socklen_t’ was here
applets/../include/platform.h:187: error: conflicting types for ‘intmax_t’
/usr/lib/gcc/powerpc-apple-darwin9/4.0.1/include/stdint.h:97: error: previous declaration of ‘intmax_t’ was here
applets/../include/platform.h:188: error: conflicting types for ‘uintmax_t’
/usr/lib/gcc/powerpc-apple-darwin9/4.0.1/include/stdint.h:106: error: previous declaration of ‘uintmax_t’ was here
In file included from applets/../include/busybox.h:10,
applets/../include/libbb.h:20:20: error: mntent.h: No such file or directory
applets/../include/libbb.h:34:24: error: sys/statfs.h: No such file or directory
applets/../include/libbb.h:309: error: ‘AF_PACKET’ undeclared here (not in a function)
applets/../include/libbb.h:312: error: ‘AF_NETLINK’ undeclared here (not in a function)
applets/../include/libbb.h:797: warning: ‘struct mntent’ declared inside parameter list
applets/../include/libbb.h:797: warning: its scope is only this definition or declaration, which is probably not what you want
make[1]: *** [applets] Error 2
make: *** [source/busybox-tools/busybox-1.9.2/busybox] Error 2
Welche Build-Umgebung? Welche Box? Welche Firmware? Welche Version von Freetz? Trunk?
Am besten füge doch deine .config hier bei (aber bitte gezippt oder als Textdatei, nicht in Prosa). Dann kann man die meisten Fragen schon beantworten.
MfG
Welche Build-Umgebung? Mac OSX 10.5.3 / Xcode 3.0
Welche Box? 7270
Welche Firmware? Firmware-Version 54.04.57
Welche Version von Freetz? 1.0
Trunk?
MfG[/QUOTE]
Steht irgendwo, daß man erwarten kann, daß es mit dieser Build-Umgebung funktioniert?
Es steht Dir aber frei, die notwendigen Änderungen zu machen und sie hier bekannt zu geben.
Ich denke nicht, dass du die busybox unter MAC OS kompiliert bekommst. Hab mich da auch schonmal versucht und es hat nicht geklappt.
MfG Oliver
figo12
