ffgt klappt über meine Fritzbox 7270 nicht
sisqonrw
12 Mai 2006
ich nutze da Fax Programm ffgtk auf meinem Kubuntu. Auf meiner fritzbox 7050 hatte es geklappt. Jetzt habe ich eine 7270. Einrichten konnte ich es. Bekomme diese Meldung:
ffgtk timed out waiting for initial communication
log report:
29:44 faxophoneLog(): tiff: /var/spool/ffgtk/salsero-Fax-ID924.tif, modem: 2, ecm: on, controller: 4, src: 0000000, trg: 09113084455066, ident: +00 0000 000000, header: ffgtk, anonymous: 0)
17:29:44 faxophoneLog(): Using 'Analog Fax' id
17:29:44 faxophoneLog(): REQ: CONNECT (0000000 -> 09113084455066)
17:29:44 faxophoneLog(): CNF: CAPI_CONNECT - (nPlci: 4100)
17:29:44 faxophoneLog(): IND: DISCONNECT - nPlci 4100
17:29:44 faxophoneLog(): RESP: DISCONNECT - nPlci 4100
17:29:44 faxophoneLog(): Spandsp is not yet completed - give it a little more time...
17:29:44 faxophoneLog(): Phase E handler (0x2) Timed out waiting for initial communication
17:29:44 faxophoneLog(): - pages transferred 0
17:29:44 faxophoneLog(): - image resolution 0 x 0
17:29:44 faxophoneLog(): - compression type 0
17:29:44 faxophoneLog(): - coding method None
17:29:44 faxophoneLog(): Remote station id:
17:29:44 connectionStatus(): Fax transfer failed
17:29:45 connectionTerminated(): Terminated!!
17:29:45 connectionTerminated(): CAPI Error 0x34a2 (Kein Kreis / Kanal verfügbar)
17:29:46 faxophoneLog(): tiff: /var/spool/ffgtk/salsero-Fax-ID924.tif, modem: 2, ecm: on, controller: 4, src: 0000000, trg: 09113084455066, ident: +00 0000 000000, header: ffgtk, anonymous: 0)
17:29:46 faxophoneLog(): Using 'Analog Fax' id
17:29:46 faxophoneLog(): REQ: CONNECT (0000000 -> 09113084455066)
17:29:46 faxophoneLog(): CNF: CAPI_CONNECT - (nPlci: 4356)
17:29:46 faxophoneLog(): IND: DISCONNECT - nPlci 4356
17:29:46 faxophoneLog(): RESP: DISCONNECT - nPlci 4356
17:29:46 faxophoneLog(): Spandsp is not yet completed - give it a little more time...
17:29:46 faxophoneLog(): Phase E handler (0x2) Timed out waiting for initial communication
17:29:46 faxophoneLog(): - pages transferred 0
17:29:46 faxophoneLog(): - image resolution 0 x 0
17:29:46 faxophoneLog(): - compression type 0
17:29:46 faxophoneLog(): - coding method None
17:29:46 faxophoneLog(): Remote station id:
17:29:46 connectionStatus(): Fax transfer failed
17:29:46 connectionTerminated(): Terminated!!
17:29:46 connectionTerminated(): CAPI Error 0x34a2 (Kein Kreis / Kanal verfügbar)
17:29:48 spoolerCallback(): File: /var/spool/ffgtk/salsero-Fax-ID924.tif Type: -1 (empty) Event: 2 (file deleted)
17:29:52 loadProfile(): Set fax report folder to: '/home/xyz/Dokumente/'
17:29:52 loadProfile(): File-chooser got: '(null)'
17:29:52 markWindowOpen(): nOpenWindows is now: 2
Erkennt jemand wo der Fehler sein kann?
Im ffgtk-Forum: www.tabos.org findest Du Hilfe direkt vom Entwickler. Bei Ubuntu gibt es ebenfalls einen umfangreichen Thread zu ffgtk.
me2k
