Firmware-Version 54.04.63-12043 - fehler
user31085
5 Mrz 2005
/var/log/mod_load.log
Loading /var/flash/freetz.../usr/bin/modload: line 29: cannot create /tmp/.load.tmp.198: Read-only file system
does not exist.
Creating /var/flash/freetz...mkdir: cannot create directory '/tmp/flash': Read-only file system
tar: flash: No such file or directory
tar: error exit delayed from previous errors
done.
Loading users, groups and passwords...mkdir: cannot create directory '/tmp/flash/': Read-only file system
done.
Loading hosts...done.
Loading config...done.
Loading modules...done.
/var/log/mod.log
rc.mod version -12043-freetz-devel-2425M
Loading /var/flash/freetz.../usr/bin/modload: line 29: cannot create /tmp/.load.tmp.1025: Read-only file system
does not exist.
done.
done.
crond is disabled
telnetd is disabled
Starting webinterface...done.
Starting syslogd...done.
Creating inetd.conf cp: cannot create '/tmp/flash/inetd.conf': No such file or directory
ok.
Updating inetd config for telnetd: grep: /var/tmp/flash/inetd.conf: No such file or directory
/usr/bin/modinetd: line 11: cannot create /var/tmp/flash/inetd.conf: nonexistent directory
sed: /var/tmp/flash/inetd.conf: No such file or directory
inactive.
Updating inetd config for vsftpd: grep: /var/tmp/flash/inetd.conf: No such file or directory
/usr/bin/modinetd: line 13: cannot create /var/tmp/flash/inetd.conf: nonexistent directory
inactive.
Updating inetd config for webcfg: grep: /var/tmp/flash/inetd.conf: No such file or directory
inactive.
Reloading inetd...not running.
tar: can't open '/tmp/.save.tmp': Read-only file system
/usr/bin/modsave: line 12: cannot open /tmp/.save.tmp: no such file
/usr/bin/modsave: let: line 12: syntax error: size=
Writing /var/flash/freetz...cat: can't open '/tmp/.save.tmp': No such file or directory
done.
 bytes written.
Starting inetd...done.
cat: can't open '/etc/default.Fritz_Box_7270_16/avm/ar7.cfg': No such file or directory
Looking for user 'ftp' ... created - now saving to data buffer ... mkdir: cannot create directory '/tmp/flash/': Read-only file system
cp: cannot stat 'passwd': No such file or directory
cp: cannot stat 'group': No such file or directory
cp: cannot stat 'shadow': No such file or directory
cp: cannot stat 'gshadow': No such file or directory
failed
vsftpd is disabled
mkdir: cannot create directory '/tmp/flash/samba': No such file or directory
samba is disabled
swap is disabled
Da hat sich wohl einiges geändert. Die Verzeichnisse scheinen nicht mehr da zu sein!
Wir waren schnell. ;-) r2425
Leider wohl zu schnell.
MfG Oliver
Klasse, jetzt klappt es wunderbar - vielen Dank für den schnellen Fix!!
Viele Grüße,
Thomas
figo12
