[Gelöst] Flashen = INSTALL_KERNEL_CHECKSUM
xsapling
30 Jan 2005
Habe ein Image für die 7490 mit den nachfolgenden Einstellungen, also insbesondere mit replace kernel erstellt.
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3272 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_6842 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7272 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7390 is not set
FREETZ_TYPE_7490=y
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_FIRMWARE_05_5X=y
# FREETZ_TYPE_FIRMWARE_LABOR is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_262144 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_524288 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_1048576 is not set
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# Remove piglet
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_AHA is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_FHEM is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
FREETZ_REMOVE_CHRONYD=y
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
FREETZ_REMOVE_PRINTSERV=y
# FREETZ_REMOVE_PRINTSERV_MODULE is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
FREETZ_REMOVE_AVM_E2FSPROGS=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_GSMVOICE is not set
FREETZ_PATCH_SIGNED=y
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_EXT4=y
FREETZ_AUTOMOUNT_FAT=y
FREETZ_AUTOMOUNT_HFS=y
FREETZ_AUTOMOUNT_HFS_PLUS=y
FREETZ_AUTOMOUNT_LUKS=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_AUTOMOUNT_REISER_FS=y
FREETZ_AUTOMOUNT_LINUXSWAP=y
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_MODIFY_UMTSD is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_SSL_LIBS is not set
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
# FREETZ_AVMDAEMON_DISABLE_TR069 is not set
FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS=y
FREETZ_AVMDAEMON_DISABLE_DNS=y
FREETZ_AVMDAEMON_DISABLE_DHCP=y
FREETZ_AVMDAEMON_DISABLE_LLMNR=y
# Additional components ------------------
# Packages
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
FREETZ_PACKAGE_COMGT=y
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
FREETZ_PACKAGE_DIGITEMP=y
# FREETZ_PACKAGE_DIGITEMP_DS2490 is not set
# FREETZ_PACKAGE_DIGITEMP_DS9097U is not set
FREETZ_PACKAGE_DIGITEMP_DS9097=y
# FREETZ_PACKAGE_DNS2TCP is not set
FREETZ_PACKAGE_DNSMASQ=y
# HINT: Don't forget to enable a dns/dhcp server.
FREETZ_PACKAGE_DNSMASQ_DISABLE_DNS=y
FREETZ_PACKAGE_DNSMASQ_DISABLE_DHCP=y
# FREETZ_PACKAGE_DOSFSTOOLS is not set
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY=y
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_DROPBEAR_UTMP is not set
# FREETZ_PACKAGE_DROPBEAR_WTMP is not set
FREETZ_PACKAGE_DROPBEAR_STATIC=y
# FREETZ_PACKAGE_DTACH is not set
FREETZ_PACKAGE_DVBSNOOP=y
# FREETZ_PACKAGE_DVBSTREAM is not set
FREETZ_PACKAGE_DVBTUNE=y
FREETZ_PACKAGE_E2FSPROGS=y
FREETZ_PACKAGE_E2FSPROGS_STATIC=y
FREETZ_PACKAGE_E2FSPROGS_E2FSCK=y
# FREETZ_PACKAGE_E2FSPROGS_E2MAKING is not set
# FREETZ_PACKAGE_E2FSPROGS_E2TUNING is not set
# FREETZ_PACKAGE_E2FSPROGS_E2DEBUG is not set
# FREETZ_PACKAGE_E2FSPROGS_E2FIXING is not set
# FREETZ_PACKAGE_E2FSPROGS_E2RESIZE is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_ESPEAK=y
# FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
FREETZ_PACKAGE_HTPDATE=y
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPSEC_TOOLS is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
FREETZ_PACKAGE_MADPLAY=y
FREETZ_PACKAGE_MATRIXTUNNEL=y
FREETZ_PACKAGE_MC=y
# Configuration
FREETZ_PACKAGE_MC_WITH_NCURSES=y
# FREETZ_PACKAGE_MC_WITH_SLANG is not set
FREETZ_PACKAGE_MC_WITH_BACKGROUND=y
FREETZ_PACKAGE_MC_WITH_CHARSET=y
FREETZ_PACKAGE_MC_WITH_EDIT=y
FREETZ_PACKAGE_MC_WITH_DIFF_VIEWER=y
FREETZ_PACKAGE_MC_WITH_SUBSHELL=y
FREETZ_PACKAGE_MC_WITH_VFS=y
FREETZ_PACKAGE_MC_WITH_VFS_CPIO=y
FREETZ_PACKAGE_MC_WITH_VFS_EXTFS=y
FREETZ_PACKAGE_MC_WITH_VFS_FTP=y
FREETZ_PACKAGE_MC_WITH_VFS_SFS=y
FREETZ_PACKAGE_MC_WITH_VFS_TAR=y
FREETZ_PACKAGE_MC_WITH_HELP=y
FREETZ_PACKAGE_MC_WITH_SYNTAX=y
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
FREETZ_PACKAGE_MTR=y
# FREETZ_PACKAGE_NAGIOS is not set
FREETZ_PACKAGE_NANO=y
# Nano additional features
FREETZ_PACKAGE_NANO_TINY=y
FREETZ_PACKAGE_NANO_MULTIBUFFER=y
FREETZ_PACKAGE_NANO_NANORC=y
FREETZ_PACKAGE_NANO_COLOR_SYNTAX=y
# Nano syntax highlighting files
FREETZ_PACKAGE_NANO_SYNTAX_FILE_SH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_NANORC=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_C=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_CSS=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_HTML=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PHP=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_TEX=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PATCH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_XML=y
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
FREETZ_PACKAGE_NETCAT=y
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFSROOT is not set
FREETZ_PACKAGE_NFS_UTILS=y
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
FREETZ_PACKAGE_OPENNTPD=y
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
FREETZ_PACKAGE_OPENSSH_sshd=y
FREETZ_PACKAGE_OPENSSH_ssh=y
FREETZ_PACKAGE_OPENSSH_scp=y
FREETZ_PACKAGE_OPENSSH_CLIENTUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_add=y
FREETZ_PACKAGE_OPENSSH_ssh_agent=y
FREETZ_PACKAGE_OPENSSH_KEYUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_keygen=y
FREETZ_PACKAGE_OPENSSH_ssh_keysign=y
FREETZ_PACKAGE_OPENSSH_ssh_keyscan=y
FREETZ_PACKAGE_OPENSSH_sftp=y
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# Build statically linked binaries ---
FREETZ_PACKAGE_OPENSSH_STATIC=y
# FREETZ_PACKAGE_OPENSSL is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_2 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
# FREETZ_PACKAGE_OPENVPN_POLARSSL is not set
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
FREETZ_PACKAGE_OPENVPN_USE_V2_CGI=y
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
FREETZ_PACKAGE_PORTMAP=y
FREETZ_PACKAGE_PPP=y
FREETZ_PACKAGE_PPPD=y
FREETZ_PACKAGE_PPPD_CHAT=y
FREETZ_PACKAGE_PPTP=y
FREETZ_PACKAGE_PPTPD=y
FREETZ_PACKAGE_PRIVOXY=y
FREETZ_PACKAGE_PRIVOXY_WITH_ADBLOCK=y
FREETZ_PACKAGE_PRIVOXY_WITH_SHARED_PCRE=y
FREETZ_PACKAGE_PRIVOXY_WITH_ZLIB=y
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
FREETZ_PACKAGE_SAMBA=y
# FREETZ_SAMBA_VERSION_3_0 is not set
FREETZ_SAMBA_VERSION_3_6=y
FREETZ_PACKAGE_SAMBA_SMBD=y
FREETZ_PACKAGE_SAMBA_NMBD=y
FREETZ_PACKAGE_SAMBA_SMBCLIENT=y
FREETZ_PACKAGE_SAMBA_NMBLOOKUP=y
FREETZ_PACKAGE_SAMBA_MAX_DEBUG_LEVEL=-1
FREETZ_PACKAGE_SCREEN=y
FREETZ_PACKAGE_SER2NET=y
FREETZ_PACKAGE_SHELLINABOX=y
# FREETZ_PACKAGE_SHELLINABOX_STATIC is not set
FREETZ_PACKAGE_SHELLINABOX_SSL=y
FREETZ_PACKAGE_SIPROXD=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_DEFAULTTARGET=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_FIX_BOGUS_VIA=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_LOGCALL=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_PREFIX=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_REGEX=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_SHORTDIAL=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_STUN=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_DEMO=y
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
FREETZ_PACKAGE_SOCAT=y
FREETZ_PACKAGE_SOCAT_WITHTERMIOS=y
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
FREETZ_PACKAGE_STREAMRIPPER=y
FREETZ_PACKAGE_STREAMRIPPER_WITH_OGGVORBIS=y
FREETZ_PACKAGE_STUNNEL=y
FREETZ_PACKAGE_STUNNEL_STATIC=y
# FREETZ_PACKAGE_STUNNEL_USE_CYASSL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
FREETZ_PACKAGE_SUNDTEK=y
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
FREETZ_PACKAGE_TCPDUMP=y
# FREETZ_PACKAGE_TCPDUMP_MINI is not set
FREETZ_PACKAGE_TCPPROXY=y
FREETZ_PACKAGE_TCP_WRAPPERS=y
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
FREETZ_PACKAGE_TIFF=y
FREETZ_PACKAGE_TIFF_bmp2tiff=y
FREETZ_PACKAGE_TIFF_fax2ps=y
FREETZ_PACKAGE_TIFF_fax2tiff=y
FREETZ_PACKAGE_TIFF_gif2tiff=y
FREETZ_PACKAGE_TIFF_ppm2tiff=y
FREETZ_PACKAGE_TIFF_raw2tiff=y
FREETZ_PACKAGE_TIFF_tiff2bw=y
FREETZ_PACKAGE_TIFF_tiff2pdf=y
FREETZ_PACKAGE_TIFF_tiff2ps=y
FREETZ_PACKAGE_TIFF_tiffinfo=y
FREETZ_PACKAGE_TIFF_tiffsplit=y
# FREETZ_PACKAGE_TINC is not set
FREETZ_PACKAGE_TINYPROXY=y
FREETZ_PACKAGE_TINYPROXY_WITH_TRANSPARENT_PROXY=y
FREETZ_PACKAGE_TINYPROXY_WITH_FILTER=y
FREETZ_PACKAGE_TINYPROXY_WITH_UPSTREAM=y
FREETZ_PACKAGE_TINYPROXY_WITH_REVERSE=y
FREETZ_PACKAGE_TINYPROXY_STATIC=y
# FREETZ_PACKAGE_TMUX is not set
FREETZ_PACKAGE_TOR=y
FREETZ_PACKAGE_TOR_GEOIP=y
# FREETZ_PACKAGE_TOR_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION=y
FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
# FREETZ_PACKAGE_TRANSMISSION_REMOTE is not set
FREETZ_PACKAGE_TRANSMISSION_CREATE=y
FREETZ_PACKAGE_TRANSMISSION_EDIT=y
FREETZ_PACKAGE_TRANSMISSION_SHOW=y
# FREETZ_PACKAGE_TRANSMISSION_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
FREETZ_PACKAGE_TREE=y
FREETZ_PACKAGE_TRICKLE=y
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# unfs3 (not available, you have selected incompatible package nfsd)
# FREETZ_PACKAGE_UNRAR is not set
FREETZ_PACKAGE_USBIP=y
FREETZ_PACKAGE_USBIP_WRAPPER=y
FREETZ_PACKAGE_USBROOT=y
FREETZ_PACKAGE_USBROOT_E2FSCK=y
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
FREETZ_PACKAGE_VIM=y
# FREETZ_PACKAGE_VIM_TINY is not set
FREETZ_PACKAGE_VIM_NORMAL=y
# FREETZ_PACKAGE_VIM_HUGE is not set
FREETZ_PACKAGE_VNSTAT=y
FREETZ_PACKAGE_VNSTAT_DAEMON=y
FREETZ_PACKAGE_VNSTAT_IMAGE=y
FREETZ_PACKAGE_VPNC=y
FREETZ_PACKAGE_VPNC_WITH_HYBRID_AUTH=y
FREETZ_PACKAGE_VPNC_NAT_SUPPORT=y
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
FREETZ_PACKAGE_WGET_USE_GNUTLS=y
FREETZ_PACKAGE_WGET_STATIC=y
FREETZ_PACKAGE_WOL=y
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
FREETZ_PACKAGE_AVM_FORWARDING=y
FREETZ_PACKAGE_COLLECTD=y
# plugins
FREETZ_PACKAGE_COLLECTD_PLUGIN_apache=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_contextswitch=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_cpu=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_csv=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_df=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_disk=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_entropy=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_exec=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_fritzbox=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_interface=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_irq=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_load=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_memory=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_network=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_ping=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_rrdtool=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_syslog=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_uptime=y
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC=y
# Misc
FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH=y
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY=y
FREETZ_PACKAGE_DTMFBOX_CGI=y
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
FREETZ_PACKAGE_IPTABLES_CGI=y
# FREETZ_PACKAGE_NHIPT is not set
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
# FREETZ_MODULE_nf_conntrack is not set
# FREETZ_MODULE_nf_conntrack_ftp is not set
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
# FREETZ_MODULE_nf_conntrack_ipv4 is not set
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
# FREETZ_MODULE_nf_conntrack_tftp is not set
# FREETZ_MODULE_nf_defrag_ipv4 is not set
# FREETZ_MODULE_nf_nat is not set
# FREETZ_MODULE_nf_nat_ftp is not set
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
# FREETZ_MODULE_nf_nat_tftp is not set
FREETZ_MODULE_iptable_filter=y
# FREETZ_MODULE_iptable_mangle is not set
# FREETZ_MODULE_iptable_nat is not set
# FREETZ_MODULE_iptable_raw is not set
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
# FREETZ_MODULE_ipt_ttl is not set
# FREETZ_MODULE_ipt_TTL is not set
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
# FREETZ_MODULE_xt_NFQUEUE is not set
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
# FREETZ_MODULE_xt_statistic is not set
# FREETZ_MODULE_xt_string is not set
FREETZ_MODULE_xt_tcpudp=y
# FREETZ_MODULE_xt_tcpmss is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
# FREETZ_LIB_libipt_SAME is not set
FREETZ_LIB_libipt_SNAT=y
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
FREETZ_LIB_libipt_ULOG=y
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
# FREETZ_LIB_libxt_comment is not set
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
# FREETZ_LIB_libxt_statistic is not set
# FREETZ_LIB_libxt_string is not set
# FREETZ_LIB_libxt_tcpmss is not set
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
# FREETZ_LIB_libxt_time is not set
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
FREETZ_PACKAGE_MINI_FO=y
FREETZ_PACKAGE_MINI_FO_JFFS2=y
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
FREETZ_PACKAGE_SQUID=y
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
FREETZ_PACKAGE_VIRTUALIP_CGI=y
FREETZ_PACKAGE_ZABBIX=y
FREETZ_PACKAGE_ZABBIX_agentd=y
FREETZ_PACKAGE_ZABBIX_server=y
FREETZ_PACKAGE_ZABBIX_proxy=y
FREETZ_PACKAGE_ZABBIX_sender=y
FREETZ_PACKAGE_ZABBIX_get=y
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FIREWALL=y
FREETZ_PACKAGE_DNSD_CGI=y
FREETZ_PACKAGE_DOWNLOADER=y
FREETZ_PACKAGE_NFSD_CGI=y
FREETZ_PACKAGE_ONLINECHANGED_CGI=y
FREETZ_PACKAGE_OPENVPN_V2_CGI=y
# FREETZ_PACKAGE_PHPXMAIL is not set
FREETZ_PACKAGE_PPP_CGI=y
FREETZ_PACKAGE_PPP_CGI_COMGT=y
FREETZ_PACKAGE_RRDSTATS=y
FREETZ_PACKAGE_RRDSTATS_CABLEMODEM=y
FREETZ_PACKAGE_RRDSTATS_CABLEMODEM_WGET=y
FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD=y
FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD_SUNDTEK=y
FREETZ_PACKAGE_RRDSTATS_STORAGE=y
FREETZ_PACKAGE_RRDSTATS_NETWORK=y
FREETZ_PACKAGE_RRDSTATS_TEMPERATURE_SENSOR=y
FREETZ_PACKAGE_RRDSTATS_DIGITEMP=y
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_TRANSMISSION_CGI=y
FREETZ_PACKAGE_VNSTAT_CGI=y
FREETZ_PACKAGE_WOL_CGI=y
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
FREETZ_LIB_STDCXXLIB=y
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
FREETZ_LIB_libuClibc__=y
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
FREETZ_LIB_libgpg_error=y
FREETZ_LIB_libgcrypt=y
# Configuration
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
FREETZ_LIB_libgcrypt_WITH_DIGEST_md5=y
FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160=y
FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1=y
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes=y
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa=y
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
FREETZ_LIB_libmatrixssl=y
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
# FREETZ_OPENSSL_VERSION_1 is not set
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
FREETZ_LIB_libsqlite3=y
# File systems
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
FREETZ_LIB_libglib_2=y
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libexif is not set
FREETZ_LIB_libjpeg=y
# FREETZ_LIB_liblept is not set
FREETZ_LIB_libpng12=y
FREETZ_LIB_libgd=y
# FREETZ_LIB_libopenjpeg is not set
FREETZ_LIB_libtiff=y
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
FREETZ_LIB_libmad=y
FREETZ_LIB_libogg=y
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
FREETZ_LIB_libvorbis=y
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
FREETZ_LIB_libid3tag=y
# FREETZ_LIB_libtag is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUS256color=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
FREETZ_LIB_libcapi20=y
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
FREETZ_LIB_libpcap=y
# FREETZ_LIB_libnet is not set
FREETZ_LIB_liboping=y
FREETZ_LIB_libosip2=y
FREETZ_LIB_libosipparser2=y
# FREETZ_LIB_libspandsp is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
FREETZ_LIB_libreadline=y
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
FREETZ_LIB_libpcreposix=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
FREETZ_LIB_libcurl=y
FREETZ_LIB_libcurl_WITH_SSL=y
# FREETZ_LIB_libcurl_WITH_CYASSL is not set
FREETZ_LIB_libcurl_WITH_OPENSSL=y
# FREETZ_LIB_libcurl_WITH_POLARSSL is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libev is not set
FREETZ_LIB_libevent=y
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
FREETZ_LIB_libmultid=y
FREETZ_LIB_libmultid_WITH_ANYIP=y
FREETZ_LIB_libmultid_WITH_DNS=y
FREETZ_LIB_libmultid_WITH_DHCP=y
FREETZ_LIB_libmultid_WITH_LLMNR=y
FREETZ_LIB_libltdl=y
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
FREETZ_LIB_libpopt=y
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_librrd=y
FREETZ_LIB_librrd_th=y
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
FREETZ_LIB_libsysfs=y
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
FREETZ_KERNEL_VERSION_2_6_32_60=y
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_VR9=y
FREETZ_KERNEL_LAYOUT="vr9"
FREETZ_MODULES_KVER="2.6.32.60"
FREETZ_KERNEL_PATCHES="${FREETZ_MODULES_KVER}"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# crypto
FREETZ_MODULE_crypto_algapi=y
# FREETZ_MODULE_crypto_blkcipher is not set
FREETZ_MODULE_crypto_hash=y
FREETZ_MODULE_arc4=y
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
FREETZ_MODULE_sha1_generic=y
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
FREETZ_MODULE_ppp_async=y
FREETZ_MODULE_ppp_deflate=y
FREETZ_MODULE_ppp_generic=y
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
FREETZ_MODULE_ppp_mppe_mppc=y
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
FREETZ_MODULE_slhc=y
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
FREETZ_MODULE_usbip=y
FREETZ_MODULE_usbip_common_mod=y
FREETZ_MODULE_usbserial=y
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_btusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
FREETZ_MODULE_option=y
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext2=y
FREETZ_MODULE_ext4=y
# FREETZ_MODULE_fat is not set
FREETZ_MODULE_hfs=y
FREETZ_MODULE_hfsplus=y
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
FREETZ_MODULE_jbd2=y
FREETZ_MODULE_lockd=y
FREETZ_MODULE_mini_fo=y
# FREETZ_MODULE_minix is not set
FREETZ_MODULE_nfsd=y
FREETZ_MODULE_exportfs=y
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
FREETZ_MODULE_nls_utf8=y
FREETZ_MODULE_reiserfs=y
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
FREETZ_MODULE_jffs2=y
FREETZ_MODULE_mbcache=y
# lib
FREETZ_MODULE_crc16=y
FREETZ_MODULE_crc_ccitt=y
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
FREETZ_MODULE_sunrpc=y
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
FREETZ_BUSYBOX__PACKER=y
FREETZ_BUSYBOX__NETWORK=y
FREETZ_BUSYBOX__TERMINAL=y
FREETZ_BUSYBOX__DEVELOPER=y
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
FREETZ_BUSYBOX_LONG_OPTS=y
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
FREETZ_BUSYBOX_FEATURE_UTMP=y
# FREETZ_BUSYBOX_FEATURE_WTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS=y
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=500
FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY=y
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVE_ON_EXIT is not set
FREETZ_BUSYBOX_FEATURE_REVERSE_SEARCH=y
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE=y
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z=y
# FREETZ_BUSYBOX_AR is not set
FREETZ_BUSYBOX_BUNZIP2=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
FREETZ_BUSYBOX_DPKG=y
FREETZ_BUSYBOX_DPKG_DEB=y
# FREETZ_BUSYBOX_FEATURE_DPKG_DEB_EXTRACT_ONLY is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_FEATURE_GZIP_LONG_OPTIONS=y
FREETZ_BUSYBOX_GZIP_FAST=0
FREETZ_BUSYBOX_LZOP=y
# FREETZ_BUSYBOX_LZOP_COMPR_HIGH is not set
FREETZ_BUSYBOX_RPM2CPIO=y
FREETZ_BUSYBOX_RPM=y
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT=y
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_LONG_OPTIONS is not set
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
FREETZ_BUSYBOX_UNLZMA=y
# FREETZ_BUSYBOX_FEATURE_LZMA_FAST is not set
FREETZ_BUSYBOX_LZMA=y
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
FREETZ_BUSYBOX_BASE64=y
FREETZ_BUSYBOX_WHO=y
FREETZ_BUSYBOX_USERS=y
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_FEATURE_CHOWN_LONG_OPTIONS=y
FREETZ_BUSYBOX_CHROOT=y
FREETZ_BUSYBOX_CKSUM=y
FREETZ_BUSYBOX_COMM=y
FREETZ_BUSYBOX_CP=y
# FREETZ_BUSYBOX_FEATURE_CP_LONG_OPTIONS is not set
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
FREETZ_BUSYBOX_DOS2UNIX=y
# FREETZ_BUSYBOX_UNIX2DOS is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_FEATURE_ENV_LONG_OPTIONS is not set
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_FEATURE_LS_COLOR=y
FREETZ_BUSYBOX_FEATURE_LS_COLOR_IS_DEFAULT=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
# FREETZ_BUSYBOX_FEATURE_MKDIR_LONG_OPTIONS is not set
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
# FREETZ_BUSYBOX_FEATURE_MV_LONG_OPTIONS is not set
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
# FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
# FREETZ_BUSYBOX_FEATURE_RMDIR_LONG_OPTIONS is not set
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
FREETZ_BUSYBOX_UUENCODE=y
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
FREETZ_BUSYBOX_CLEAR=y
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_FEATURE_SETCONSOLE_LONG_OPTIONS is not set
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
FREETZ_BUSYBOX_MKTEMP=y
FREETZ_BUSYBOX_PIPE_PROGRESS=y
FREETZ_BUSYBOX_RUN_PARTS=y
FREETZ_BUSYBOX_FEATURE_RUN_PARTS_LONG_OPTIONS=y
FREETZ_BUSYBOX_FEATURE_RUN_PARTS_FANCY=y
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_FANCY=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_LONG_OPTIONS=y
FREETZ_BUSYBOX_WHICH=y
# Editors
FREETZ_BUSYBOX_PATCH=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
FREETZ_BUSYBOX_CMP=y
FREETZ_BUSYBOX_DIFF=y
# FREETZ_BUSYBOX_FEATURE_DIFF_LONG_OPTIONS is not set
FREETZ_BUSYBOX_FEATURE_DIFF_DIR=y
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_ADDUSER_LONG_OPTIONS is not set
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
# FREETZ_BUSYBOX_FEATURE_ADDGROUP_LONG_OPTIONS is not set
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
FREETZ_BUSYBOX_SU=y
FREETZ_BUSYBOX_FEATURE_SU_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_SU_CHECKS_SHELLS=y
FREETZ_BUSYBOX_SULOGIN=y
FREETZ_BUSYBOX_VLOCK=y
# Linux Ext2 FS Progs
FREETZ_BUSYBOX_CHATTR=y
FREETZ_BUSYBOX_FSCK=y
FREETZ_BUSYBOX_LSATTR=y
FREETZ_BUSYBOX_TUNE2FS=y
# Linux Module Utilities
FREETZ_BUSYBOX_MODINFO=y
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
FREETZ_BUSYBOX_HEXDUMP=y
# FREETZ_BUSYBOX_FEATURE_HEXDUMP_REVERSE is not set
# FREETZ_BUSYBOX_HD is not set
FREETZ_BUSYBOX_HWCLOCK=y
FREETZ_BUSYBOX_FEATURE_HWCLOCK_LONG_OPTIONS=y
FREETZ_BUSYBOX_FEATURE_HWCLOCK_ADJTIME_FHS=y
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID=y
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_MOUNT=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE=y
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL=y
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
FREETZ_BUSYBOX_RDATE=y
FREETZ_BUSYBOX_RDEV=y
FREETZ_BUSYBOX_READPROFILE=y
FREETZ_BUSYBOX_RTCWAKE=y
FREETZ_BUSYBOX_SCRIPT=y
FREETZ_BUSYBOX_SCRIPTREPLAY=y
FREETZ_BUSYBOX_SETARCH=y
FREETZ_BUSYBOX_SWAPONOFF=y
FREETZ_BUSYBOX_FEATURE_SWAPON_PRI=y
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID=y
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
FREETZ_BUSYBOX_LESS=y
FREETZ_BUSYBOX_FEATURE_LESS_MAXLINES=9999999
FREETZ_BUSYBOX_FEATURE_LESS_BRACKETS=y
FREETZ_BUSYBOX_FEATURE_LESS_FLAGS=y
# FREETZ_BUSYBOX_FEATURE_LESS_MARKS is not set
FREETZ_BUSYBOX_FEATURE_LESS_REGEXP=y
# FREETZ_BUSYBOX_FEATURE_LESS_WINCH is not set
# FREETZ_BUSYBOX_FEATURE_LESS_DASHCMD is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
FREETZ_BUSYBOX_UBIMKVOL=y
FREETZ_BUSYBOX_UBIRMVOL=y
FREETZ_BUSYBOX_UBIRSVOL=y
FREETZ_BUSYBOX_UBIUPDATEVOL=y
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
FREETZ_BUSYBOX_FEATURE_CROND_D=y
FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL=y
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
FREETZ_BUSYBOX_MAN=y
# FREETZ_BUSYBOX_MICROCOM is not set
FREETZ_BUSYBOX_MOUNTPOINT=y
FREETZ_BUSYBOX_MT=y
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RFKILL is not set
# FREETZ_BUSYBOX_RUNLEVEL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
FREETZ_BUSYBOX_STRINGS=y
# FREETZ_BUSYBOX_TASKSET is not set
FREETZ_BUSYBOX_TIME=y
FREETZ_BUSYBOX_TIMEOUT=y
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
FREETZ_BUSYBOX_WALL=y
FREETZ_BUSYBOX_WATCHDOG=y
# Networking Utilities
FREETZ_BUSYBOX_NAMEIF=y
FREETZ_BUSYBOX_FEATURE_NAMEIF_EXTENDED=y
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
FREETZ_BUSYBOX_NC_SERVER=y
FREETZ_BUSYBOX_NC_EXTRA=y
FREETZ_BUSYBOX_NC_110_COMPAT=y
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
FREETZ_BUSYBOX_DNSD=y
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
# FREETZ_BUSYBOX_FEATURE_FTPGETPUT_LONG_OPTIONS is not set
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID=y
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV=y
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES=y
FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY=y
FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP=y
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
FREETZ_BUSYBOX_IFPLUGD=y
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME=y
FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS=y
FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS=y
# FREETZ_BUSYBOX_IPADDR is not set
# FREETZ_BUSYBOX_IPLINK is not set
# FREETZ_BUSYBOX_IPROUTE is not set
# FREETZ_BUSYBOX_IPTUNNEL is not set
# FREETZ_BUSYBOX_IPRULE is not set
FREETZ_BUSYBOX_IPCALC=y
FREETZ_BUSYBOX_FEATURE_IPCALC_FANCY=y
FREETZ_BUSYBOX_FEATURE_IPCALC_LONG_OPTIONS=y
FREETZ_BUSYBOX_NETSTAT=y
FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE=y
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
FREETZ_BUSYBOX_PSCAN=y
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
FREETZ_BUSYBOX_TELNET=y
FREETZ_BUSYBOX_FEATURE_TELNET_TTYPE=y
FREETZ_BUSYBOX_FEATURE_TELNET_AUTOLOGIN=y
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT=y
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
FREETZ_BUSYBOX_FEATURE_TFTP_GET=y
FREETZ_BUSYBOX_FEATURE_TFTP_PUT=y
FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE=y
FREETZ_BUSYBOX_FEATURE_TFTP_PROGRESS_BAR=y
FREETZ_BUSYBOX_TFTP_DEBUG=y
FREETZ_BUSYBOX_TRACEROUTE=y
FREETZ_BUSYBOX_TRACEROUTE6=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP=y
FREETZ_BUSYBOX_TUNCTL=y
FREETZ_BUSYBOX_FEATURE_TUNCTL_UG=y
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
FREETZ_BUSYBOX_FEATURE_WGET_LONG_OPTIONS=y
FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
FREETZ_BUSYBOX_LSOF=y
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU=y
FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS=y
FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS=y
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FEATURE_UPTIME_UTMP_SUPPORT=y
FREETZ_BUSYBOX_FREE=y
FREETZ_BUSYBOX_FUSER=y
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
FREETZ_BUSYBOX_PGREP=y
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
FREETZ_BUSYBOX_PKILL=y
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
FREETZ_BUSYBOX_FEATURE_SHOW_THREADS=y
FREETZ_BUSYBOX_WATCH=y
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT=y
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE=y
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
FREETZ_SKIN_newfreetz=y
FREETZ_SKIN_phoenix=y
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_CUSTOM_IMAGE_NAME=y
# FREETZ_CUSTOM_IMAGE_NAME_PREFIX is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_32=y
# FREETZ_TARGET_UCLIBC_0_9_33 is not set
# FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="4622c6e00b05f6369ed3d777acb57ad2"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="b3d4da39d502edb1efa35930cd612a8c"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="41279902c9d19635072d2adcf59d9c6b"
FREETZ_DL_SITE="@AVM/fritzbox.7490/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_7490.113.05.59.image"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
FREETZ_DL_SOURCE_MD5="0edf6e0a84c1695cebdecc8dfc9bf8bb"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
FREETZ_AVM_HAS_LABOR=y
# FREETZ_AVM_HAS_FW6XX is not set
FREETZ_AVM_HAS_FW55X=y
# FREETZ_AVM_HAS_FW52X is not set
# FREETZ_AVM_HAS_FW4XX is not set
# FREETZ_AVM_HAS_FWEWE_05_2X is not set
# FREETZ_AVM_HAS_FWEWE_05_5X is not set
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
# FREETZ_AVM_HAS_LANG_EN is not set
# FREETZ_AVM_HAS_LANG_IT is not set
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_PIGLET is not set
FREETZ_AVM_HAS_PTY_SUPPORT=y
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_SOCAT is not set
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE=y
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
# FREETZ_AVM_HAS_JFFS2 is not set
# FREETZ_AVM_HAS_JUNK_BYTES is not set
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_AHA=y
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7490_05_59=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_05_5X=y
FREETZ_AVM_VERSION_STRING="7490_05.59"
FREETZ_TYPE_PREFIX="7490"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_5X"
Bei Installation des erstellten Images über die Freetz-Oberfläche erscheint die folgende Fehlermeldung:
ERLEDIGT – Rückgabewert des Installationsskripts: 3 (INSTALL_KERNEL_CHECKSUM)
Von /var/post_install generierter Inhalt:
Fehler: Nach-Installationsskript nicht gefunden oder nicht ausführbar.
Habe ein Image für die 7490 mit den nachfolgenden Einstellungen, also insbesondere mit replace kernel erstellt.
Warum schreibst Du "insbesondere mit replace kernel"? Soll das heißen, dass es ohne replace kernel nicht auftritt? Dann schreib das doch bitte direkt. Wenn nicht, könntest Du genauso gut schreiben, dass insbesondere FREETZ_LIB_libcurl gesetzt ist.
Das insbesondere hebt hervor, dass nicht nur der kernel getauscht wurde, sondern auch einige andere Dinge (Packages) hinzugefügt worden sind.
Der Fehler trat erstmals auf, als ich versuchte, erstmals mit devel-11198 einen replaced kernel auf die Box (derzeit freetz-devel-11158 )zu bringen.
Seit diesem Zeitpunkt, bricht auch das Einspielen von bereits früher erfolgreich eingespielten *non replaced kernel* Images mit eben der eingangs genannten Fehlermeldung ab (gerade festgestellt).
Auszug:
install: kernel_start=0x00000000
install: kernel_size=4194304
install: kernel_image_size=0
install: filesystem_start=0x00400000
install: filesystem_size=50331648
install: filesystem_image_size=0
install: Kernel Adress or Size error - Abort!
sh: write error: Invalid argument
set INFO led to off
Der Fehler tritt auch beim Einspielen durch andere Rechner auf.
sh -x /var/install
root@fritz:/var# sh -x /var/install
+ export INSTALL_SUCCESS_NO_REBOOT=0
+ export INSTALL_SUCCESS_REBOOT=1
+ export INSTALL_WRONG_HARDWARE=2
+ export INSTALL_KERNEL_CHECKSUM=3
+ export INSTALL_FILESYSTEM_CHECKSUM=4
+ export INSTALL_URLADER_CHECKSUM=5
+ export INSTALL_OTHER_ERROR=6
+ export INSTALL_FIRMWARE_VERSION=7
+ export INSTALL_DOWNGRADE_NEEDED=8
+ force_update=n
+ uname -r
+ currKver=2.6.32.60
+ kversion=
+ flash_update_drv_path=
+ flash_update_drv_test=
+ flash_update_drv_MIPS32R2=
+ kversion=2.6.32
+ find /lib/modules -type f -name flash_update.ko
+ flash_update_drv_path=/lib/modules/2.6.32.60/kernel/drivers/char/flash_update/flash_update.ko
+ [ -z /lib/modules/2.6.32.60/kernel/drivers/char/flash_update/flash_update.ko ]
+ echo install: have Kernel 2.6.32.60 - set kversion '2.6.32' and FlashUpdateTool '/lib/modules/2.6.32.60/kernel/drivers/char/flash_update/flash_update.ko'
+ [ -n  ]
+ echo install: check and install new firmware ...
+ need_reboot=0
+ korrekt_version=0
+ /bin/update_led_on
+ [ 2.6.32 = 24 ]
+ echo OEM=avm
OEM=avm
+ [ 2.6.32 = 24 ]
+ export CONFIG_ENVIRONMENT_PATH=/proc/sys/urlader
+ cat /proc/sys/urlader/annex
+ export ANNEX=B
+ [ -z B ]
+ echo ANNEX=B
ANNEX=B
+ [ -z  ]
+ echo testing acceptance for device Fritz_Box_HW185 ...
+ /etc/version --install=mips34_512MB_xilinx_vdsl_dect446_4geth_2ab_isdn_nt_te_pots_2usb_host_wlan11n_27490
korrekt install type: mips34_512MB_xilinx_vdsl_dect446_4geth_2ab_isdn_nt_te_pots_2usb_host_wlan11n_27490
+ echo device has installtype mips34_512MB_xilinx_vdsl_dect446_4geth_2ab_isdn_nt_te_pots_2usb_host_wlan11n_27490
+ [ ! -z avm ]
+ oem_found=0
+ [ avm = avm ]
+ echo OK - OEM avm is supported
+ oem_found=1
+ break
+ [ 1 = 0 ]
+ echo OK - accept this update for device Fritz_Box_HW185 ...
+ korrekt_version=1
+ echo testing acceptance for device Fritz_Box_HW185 done
+ kernel_start=0x00000000
+ kernel_size=4194304
+ filesystem_start=0x00400000
+ filesystem_size=50331648
+ urlader_start=0x00000000
+ urlader_size=262144
+ newFWver=05.59
+ flash_start=0
+ [ 1 = 0 ]
+ /etc/version -v
+ currFWver=113.01.01
+ echo curr: 113.01.01  new: xx.05.59
+ major_currFWver=113
+ middle_currFWver=113.01
+ middle_currFWver=01
+ minor_currFWver=01
+ echo debug: curr: 113.01.01
+ middle_newFWver=05
+ minor_newFWver=59
+ echo debug: new: "XX.05.59"
+ minor_currFWver=1
+ major_newFWver=
+ middle_newFWver=5
+ minor_newFWver=59
+ echo major_currFWver=113
major_currFWver=113
+ echo middle_currFWver=1
middle_currFWver=1
+ echo minor_currFWver=1
minor_currFWver=1
+ echo middle_newFWver=5
middle_newFWver=5
+ echo minor_newFWver=59
minor_newFWver=59
+ [ -z 1 ]
+ [ -z 1 ]
+ [ -z 5 ]
+ [ -z 59 ]
+ [ n = y ]
+ echo check Firmware Version: xx.05.59
+ [ 5 -lt 1 ]
+ echo DEBUG: 5 >= 1
DEBUG: 5 >= 1
+ [ 5 -eq 1 ]
+ echo DEBUG: 5 > 1
DEBUG: 5 > 1
+ echo Accept Firmware Version: xx.05.59
+ echo install: 2.6.32 check files...
+ [ -f /var/tmp/filesystem.image ]
+ [ 50331648 -ne 0 ]
+ /var/chksum /var/tmp/filesystem.image
File doesn't contain the checksum, adding
Calculated checksum is 985F8441
Adding failed
+ echo chksum for file /var/tmp/filesystem.image ok
+ ls -l /var/tmp/filesystem.image
+ sed -e s/[^0-9]/#/g
+ sed -e s/#\+[0-9]\+#\+\([0-9]\+\).*/\1/
+ filsystem_image_size=0
+ [ 0 -gt 50331648 ]
+ echo size for file /var/tmp/filesystem.image ok
+ [ -f /var/tmp/kernel.image ]
+ /var/chksum /var/tmp/kernel.image
Calculated checksum is 1558AE12
Adding failed
+ echo chksum for file /var/tmp/kernel.image ok
+ ls -l /var/tmp/kernel.image
+ kernel_image_size=0
+ [ 0 -gt 4194304 ]
+ echo size for file /var/tmp/kernel.image ok
+ [ ! -f /var/post_install ]
+ echo echo $0: start
+ echo sleep 1
+ echo killall run_clock
+ echo if ps | grep -v grep | grep -q telefon ; then killall telefon ; fi
+ echo if ps | grep -v grep | grep -q telnetd ; then killall telnetd ; fi
+ [ 2.6.32 = 24 ]
+ echo echo skip deleting language from env
+ echo echo MODE=update > /dev/avm_power
+ [ -e /dev/watchdog ]
+ echo echo "disable" > /dev/watchdog
+ echo echo still running:
+ echo ps
+ echo lsmod
+ echo sleep 1
+ echo install: 2.6.32 getting mtds to install...
+ echo install: --mtd------------------------------------------------
+ cat /proc/mtd
+ grep ^mtd.*reserved-kernel
+ sed s/:.*//
+ sed s/^mtd//
+ var_kernel_mtdnr=0
+ cat /proc/mtd
+ + grepgrep -v ^mtd.*kernel reserved
+ sed s/:.*//
+ sed s/^mtd//
+ var_non_res_kernel_mtdnr=2
+ cat /proc/mtd
+ grep ^mtd.*reserved-filesystem
+ sed s/:.*//
+ sed s/^mtd//
+ var_fs_mtdnr=1
+ cat /proc/sys/urlader/environment
+ grep ^linux_fs_start
+ tr \t =
+ eval linux_fs_start=1
+ linux_fs_start=1
+ mount
+ grep /dev/mtdblock1
+ var_mount_mtd=
+ mount
+ grep /dev/mtdblock0
+ var_mount_mtd_kernel=
+ test -z 0
+ test -z 2
+ test -z 1
+ test -n
+ test -n
+ echo install: --assert---------------------------------------------
+ test -d /var/tmp
+ test -f /var/tmp/kernel.image
+ test -f /var/tmp/filesystem.image
+ test -d /var/tmp/fs
+ test -d /var/tmp/fs_mtd
+ echo install: --addr+size------------------------------------------
+ filesystem_image_size=0
+ echo install: kernel_start=0x00000000
+ echo install: kernel_size=4194304
+ echo install: kernel_image_size=0
+ echo install: filesystem_start=0x00400000
+ echo install: filesystem_size=50331648
+ echo install: filesystem_image_size=0
+ [ -z 0 ]
+ [ 0 = 0 ]
+ echo install: Kernel Adress or Size error - Abort!
+ /bin/update_led_off
+ echo set INFO led to off
set INFO led to off
+ exit 3
Es ging mir auch nicht um das insbesondere, sondern um das Replace Kernel. Wie Du inzwischen selbst schreibst, hat es mit Replace Kernel nichts zu tun. Insofern ist der Titel "replace kernel = INSTALL_KERNEL_CHECKSUM" irreführend.
So wie es aussieht, enthält die Datei kernel.image 0 Bytes. Stimmt das, oder die die Längenbestimmung falsch?
die kernel.image aus der image-Datei ist 1.841.664 groß. Wie kann ich das mit der Längenbestimmung herausbekommen/verifizieren?
Habe mir jetzt den Thread nicht vollständig durchgelesen, es sei jedoch angemerkt, dass "Replace Kernel" mit 7490 aktuell (noch) nicht funktioniert. Also abwarten bis wir es hingekriegt haben.
Hier sieht man, dass AVM selbst in der neuesten Firmware den Check noch nicht hin bekommt. Allerdings bekommen sie auch die Prüfung nicht hin, deswegen läuft der Update dann weiter.
Adding failed
Hier wird versucht, die Größe der kernel.image zu bestimmen.
Es gehört vermutlich zu einer Zeile in der Art im /var/install Skript:
kernel_image_size="`ls -l /var/tmp/kernel.image | sed -e 's/[^0-9]/#/g' | sed -e 's/#\+[0-9]\+#\+\([0-9]\+\).*/\1/'`"
Was wird denn angezeigt bei "ls -l /var/tmp/kernel.image"?
root@fritz:/var/tmp# ls -l /var/tmp/kernel.image
-rw-r-----    1 root     0          1932552 Oct 29 22:47 /var/tmp/kernel.image
______neu - Edit
Auch das AVM-Webinterface verweigert das Flashen, weil die Kernel-Prüfsumme nicht stimme.
Ich konnte den Fehler inzwischen eingrenzen.
Und zwar kann ich ein und das selbe Image erfolgreich auf einem frischen System flashen. Sobald ich aber meine aktuellen Einstellungen über freetz restore (und zwar avm+freetz-Einstellungen) wird das Flashen von jeder Firmware mit obigem Fehler abgelehnt.
Wie können wir dem Fehler weiter auf den Grund gehen?
Wie sieht /etc/group aus? Die Gruppe wird als "0" angezeigt und nicht als "root". Als Folge davon ist die zweite Zahl die 0 von der Gruppe und nicht die Größe der Datei.
Ich habe im vorhergehenden Beitrag eine Ergänzung hinzugefügt.
/etc/group sieht so aus
root@fritz:/var/mod/root# cat /etc/group
nobody:x:1000:
ntp:x:1001:
openvpn:x:1002:
sshd:x:1003:
siproxd:x:1004:
squid:x:1005:
tor:x:1006:
users:x:1007:
nachdem ich in group die Zeile
root:x:0:
hinzufügte, lief das Update-Skript tadellos durch.
Frage: fehlt die root Zeile von Haus aus? Denn auch in meinem ersten Backup (mit dem ich auch noch Firmwares flashen konnte) fehlt die root-Zeile in group.
root fehlt auch in der gshadow.
Sollte ich den root auch dort eintragen?
Also ein
root:!::
Kann es sein, dass meine group über root hinaus auch recht unvollständig ist?
Danke für Deine Hilfe!!
Nein, sonst wäre noch nie ein Image Update möglich gewesen.
Die Vorgabe für Original und veränderte Datei findest Du hiermit mit Build-Verzeichnis:
tar xOf build/original/filesystem/var.tar ./var/tmp/group
tar xOf build/modified/filesystem/var.tar ./var/tmp/group
gshadow ist nicht sonderlich wichtig, aber es schadet nicht, auch dort den Eintrag zu haben.
vapep43913
