Fon3 always use same SIP provider?
Edward Velo
31 Mai 2006
Hello,
I have 3 SIP providers in use in my Fritz!box 7050, and I use the dialling rules to use the best one for each destination.
Now, I would like Fon3 to ALWAYS use a certain SIP provider, independent of the dialling rules (so Fon1 and Fon2 should still use the dialling rules).
Is that possible? I know it can be done manually with *12x#yyyyyy but I was wondering if it can be set automatically?
Thanks!
Hello,
dialling rules in the fritzbox are guilty for all fons (fon 1 - 3). You have to do it manually, if you will use a special SIP provider for one fon.
If you have no rules in fritzbox for one destination, fritzbox will take for calls to this destination the number and Provider, which you have set for the calling fon.
M.CH.
