[Frage] FreePBX kein Faxversand mehr möglich
phone-man
27 Feb 2005
bei meiner FreePBX 12 mit Asterisk 13 konnte ich bisher einwandfrei Faxe senden, nun klappt es leider nicht mehr. Ich Log erhalte ich folgenden Fehler:
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:1] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(filename)=/tmp/1423442993.tif") in new stack
[2015-05-13 19:40:46] WARNING[17294][C-00000039] res_fax.c: channel 'Local/123456789@from-internal-00000028;1' set FAXOPT(filename) to '/tmp/1423442993.tif' is unhandled!
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:2] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(ecm)=yes") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:3] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(headerinfo)=xxxxxxxxxx") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:4] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(localstationid)=123456789") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:5] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(maxrate)=14400") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:6] Set("Local/123456789@from-internal-00000028;1", "FAXOPT(minrate)=4800") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:7] SendFAX("Local/123456789@from-internal-00000028;1", "/tmp/1423442993.tif,d") in new stack
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' sending FAX:
[2015-05-13 19:40:46] VERBOSE[17294][C-00000039] res_fax.c: /tmp/1423442993.tif
[2015-05-13 19:40:46] VERBOSE[17295][C-00000038] bridge_channel.c: Channel Local/123456789@from-internal-00000028;2 joined 'simple_bridge' basic-bridge <b35f5932-8686-42de-ae53-4bd167705691>
[2015-05-13 19:40:46] VERBOSE[17298][C-00000038] bridge_channel.c: Channel SIP/sipgate-0000002f joined 'simple_bridge' basic-bridge <b35f5932-8686-42de-ae53-4bd167705691>
[2015-05-13 19:40:47] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 000.358296 ], channel sent 15 frames (300 ms) of energy.
[2015-05-13 19:40:47] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 000.520084 ], stack sent 25 frames (500 ms) of energy.
[2015-05-13 19:40:47] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 000.699422 ], channel sent 17 frames (340 ms) of silence.
[2015-05-13 19:40:48] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 001.718562 ], channel sent 51 frames (1020 ms) of energy.
[2015-05-13 19:40:48] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 001.760861 ], channel sent 2 frames (40 ms) of silence.
[2015-05-13 19:40:49] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 002.598657 ], channel sent 35 frames (700 ms) of energy.
[2015-05-13 19:40:49] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 002.638288 ], channel sent 2 frames (40 ms) of silence.
[2015-05-13 19:40:51] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 004.218653 ], channel sent 79 frames (1580 ms) of energy.
[2015-05-13 19:40:51] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 004.280078 ], stack sent 187 frames (3740 ms) of silence.
[2015-05-13 19:40:52] VERBOSE[17294][C-00000039] res_fax.c: Channel 'Local/123456789@from-internal-00000028;1' fax session '4', [ 005.380076 ], stack sent 55 frames (1100 ms) of energy.
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [s@outboundfax:8] System("Local/123456789@from-internal-00000028;1", "/var/lib/asterisk/bin/sendfaxnotify.php INIT "fxxxxxxxx" "123456789" "13/05/15 : 19:40:42" "NO_STATUS" "NO_STATUS" "NO_PAGES"") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Auto fallthrough, channel 'Local/123456789@from-internal-00000028;1' status is 'UNKNOWN'
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:1] NoOp("Local/123456789@from-internal-00000028;1", "FAXOPT(ecm) : yes") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:2] NoOp("Local/123456789@from-internal-00000028;1", "FaxStatus : FAILED") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:3] NoOp("Local/123456789@from-internal-00000028;1", "FaxStatusString : Far end cannot receive at the resolution of the image") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:4] NoOp("Local/123456789@from-internal-00000028;1", "FaxError : Far end cannot receive at the resolution of the image") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:5] NoOp("Local/123456789@from-internal-00000028;1", "RemoteStationID : ") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:6] NoOp("Local/123456789@from-internal-00000028;1", "FaxPages : 0") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:7] NoOp("Local/123456789@from-internal-00000028;1", "FaxBitRate : 14400") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:8] NoOp("Local/123456789@from-internal-00000028;1", "FaxResolution : 11811x11811") in new stack
[2015-05-13 19:40:53] VERBOSE[17294][C-00000039] pbx.c: Executing [h@outboundfax:9] System("Local/123456789@from-internal-00000028;1", "/var/lib/asterisk/bin/sendfaxnotify.php NOTIFY "xxxxxxx" "123456789" "13/05/15 : 19:40:42" "FAILED" "Far end cannot receive at the size of image" "0"") in new stack
Nach einer Recherche habe ich die Breite der tif Datei auf 1728 Pixel angepasst, anschließend lautet der STATUSSTRING nicht mehr "Far end cannot receive at the size of image" sondern "Far end cannot receive at the resolution of the image".
Hat jemand eine Idee, woran das Problem liegen kann?
IchBinEsDoch
