FreePBX - Problem bei der Installation..
fruitz
18 Apr 2007
ich hoffe, dies ist das richtige Forum für mein Problem.
Ich hänge seit Tagen an der Installation von FreePBX. Dabei bin ich genau nach Anleitung vorgegangen: http://www.aussievoip.com/wiki/freePBX-Ubuntu. Ich habe jeden Schritt genau befolgt, bin sogar so frech zu behaupten, dass ich ne Ahnung habe, was jeder Schritt genau macht ;).
Mein Problem beginnt im fast letzten Schritt. Bei der Installation von FreePBX mittel "./install_amp" kommt folgende Fehlermeldung:
root@asterix:/usr/src/freepbx-2.2.1# ./install_amp
Checking for PEAR DB..OK
Checking for PEAR Console::Getopt..OK
Checking user..OK
Checking for /etc/amportal.conf..OK
Reading /etc/amportal.conf..OK
Checking for /etc/asterisk/asterisk.conf..OK
Reading /etc/asterisk/asterisk.conf..OK
Using asterisk as PBX Engine
Checking for Asterisk 1.2..OK
Checking for selinux..OK
Connecting to database..OK
Checking current version of AMP..2.2.1
Installing new AMP files..OK
Configuring install for your environment..OK
Setting permissions on files..OK
Checking for upgrades..0 found
Generating AMP configs..
Generating Configurations.conf..
-su: /var/lib/asterisk/bin/retrieve_conf: Permission denied
Generating AMP configs..OK
Restarting Flash Operator Panel..-su: /var/www/admin/bounce_op.sh: Permission denied
OK
Please update your modules and reload Asterisk by visiting http://192.168.178.100/admin
* Note: It's possible that if you click the red 'Update Now' bar BEFORE *
* updating your modules, your machine will start dropping calls. Ensure *
* that all modules are up to date BEFORE YOU CLICK THE RED BAR. As long *
* as this is observed, your machine will be fully functional whilst the *
* upgrade is in progress.                                               *
Auf der Weboberfläche bekomme ich dann die Fehlermeldung:
Warning: file(/etc/amportal.conf) [function.file]: failed to open stream: Permission denied in /var/www/admin/functions.inc.php on line 35
Missing or unreadable config file (/etc/amportal.conf)...cannot continue
Die Datei amportal.conf existiert auf jeden Fall. Aber wie gesagt, ich bin genau nach Anleitung vorgegangen und viele andere Dokus machen genau die gleichen Schritte!
Ich denke die 2 Fehler bei der Installation sind die Ursache dieser Fehler. Es scheint ein Problem beim Zugriff auf die mysql-Datenbanken fehlzuschlagen..
Ich bin fast ratlos.. anscheinend bin ich der Einzige auf der Welt mit diesem Problem. Google hat nix dazu ausgespuckt..
Ich hoffe jemand kann mir da weiterhelfen!
Fruitz
Lösung gefunden - Aber neues Problem
Hallo nochmal,
nach einiger Recherche und einigen Stunden vor dem Rechner, habe ich ein Lösung für das Problem gefunden.
Das Problem war, das "Asterisk" als Nicht-Root-Nutzer laufen muss. Wie das geht, steht in folgender Anleitung:
Link
Die Installation von FreePBX läuft jetzt durch:
Checking user..OK
Restarting Flash Operator Panel..OK
Jetzt taucht aber ein neues Problem auf:
root@asterix:/usr/src/freepbx-2.2.1# modprobe ztdummy
root@asterix:/usr/src/freepbx-2.2.1# amportal start
SETTING FILE PERMISSIONS
Permissions OK
STARTING ASTERISK
/usr/sbin/safe_asterisk: 93: Syntax error: Bad fd number
Asterisk Started
STARTING FOP SERVER
FOP Server Started
Dies scheint ein Problem in der "safe_asterisk" zu sein. Hat jemand vl eine Idee, wie man jetzt weiter vorgehen kann? Oder vielleicht hat jemand FreePBX-2.2.1 unter Ubuntu 6.10 am laufen und kann mir ein paar Hinweise geben.
Fruitz
mwsss
