[Problem] freepbx & Qsc
atux_null
31 Aug 2017
Hi. i have a sip trunk with Qsc that i would like to use in my freepbx system. I have managed to register and make outbound calls. The problem is with the incoming calls, that they do not reach the asterisk at all.
For trunk i have:
username=xxxxxxx
type=friend
secret=YYY
pedantic=yes
nat=yes
insecure=very
host=sip.qsc.de
fromdomain=qsc.de
context=from-internal     # this is the context in the extensions.
canreinvite=no
authuser=xxxxxxx
i did create an inbound route for any did/any cid, but the call is not coming to the system
//edit stoney: [CODE]Tag[/CODE] gesetzt
We need more information about your network environment.
Is QSC also the carrier of your internet connection?
What Router/Switches are used?
Can you see any messages in the network traffic when you do a tcpdump and then call from external?
Pianist
