FreeSWITCH (Docker safarov/freeswitch:1.10.12)
Oekel
14 Jun 2013
ich dachte nicht das man sich so schwer tun kann (zumal ich schon etliche Docker in Betrieb habe)
Aber der obige Container will einfach nicht sauber starten und die KI behauptet es läge an ipv6, die ich deaktivieren müsse ;(
version: "3.8"
services:
freeswitch:
image: safarov/freeswitch:1.10.12
container_name: freeswitch
restart: unless-stopped
networks:
vlan40:
ipv4_address: 192.168.4.101
#ports:
#- "5060:5060/udp"
#- "5060:5060/tcp"
#- "5080:5080/udp"
#- "5080:5080/tcp"
#- "8021:8021/tcp" # Event Socket
#- "16384-16393:16384-16393/udp" # RTP Ports
#- "16384-32768:16384-32768/udp"
volumes:
#- freeswitch_config:/usr/share/freeswitch
- freeswitch_config:/etc/freeswitch
environment:
- TZ=Europe/Berlin
- EXTERNAL_SIP_IP=192.168.4.101
- EXTERNAL_RTP_IP=192.168.4.101
cap_add:
- SYS_NICE
fusionpbx:
image: crazyquark/fusionpbx:latest
container_name: fusionpbx
networks:
vlan40:
ipv4_address: 192.168.4.102
#ports:
# - "80:80"
# - "443:443"
depends_on:
- freeswitch
environment:
- TZ=Europe/Berlin
volumes:
- fusionpbx_config:/var/www/fusionpbx
networks:
vlan40:
external: true
volumes:
freeswitch_config:
driver: local
fusionpbx_config:
driver: local
editiert im Volume habe ich bereits:
- event_socket.conf.xml
- verto.conf.xml
- vars.xml
TimeoutKilling: 16
Environment variables 'SOUND_RATES' or 'SOUND_TYPES' not defined. Skipping sound files checking.2025-10-08 20:51:49.251637 0.00%
WARNING] sofia.c:5328 rtp-timeout-sec deprecated use media_timeout variable.2025-10-08 20:51:49.251641 0.00%
WARNING] sofia.c:5335 rtp-hold-timeout-sec deprecated use media_hold_timeout variable.2025-10-08 20:51:49.251917 0.00%
WARNING] sofia.c:5328 rtp-timeout-sec deprecated use media_timeout variable.2025-10-08 20:51:49.251921 0.00%
WARNING] sofia.c:5335 rtp-hold-timeout-sec deprecated use media_hold_timeout variable.2025-10-08 20:51:49.252140 0.00%
WARNING] sofia.c:2290 MSG Thread 0 Started2025-10-08 20:51:50.766532 0.00%
WARNING] mod_verto.c:4818 Bind Error!, errno=99, 2025-10-08 20:51:50.766556 0.00%
WARNING] mod_verto.c:4818 Bind Error!, errno=99, 2025-10-08 20:51:50.766562 0.00%
WARNING] mod_verto.c:4985 default-v6 Client Socket Error! No Listeners!2025-10-08 20:51:51.348621 100.00%
ERR] mod_event_socket.c:2960 Cannot get information about IP address ::2025-10-08 20:51:56.388872 99.10%
ERR] mod_signalwire.c:324 SignalWire adoption failed: stun [stun.freeswitch.org] lookup error: Timeout
Könnt ihr mir auf meiner Reise helfen, wie ich eine saubere ipv4 (only) Konfiguration mit 2 Sip-Telefonen hin bekomme.
(Oder zumindest den Server 1x durchstarten, damit ich mit der UI drauf komme)
Hat ansosnten Jemand Erfahrung mit den Köchbücher von 1.06 und 1.08. Sind ja nicht ganz günstig, dafür das die so veraltet sind und ich hätte gerne gewusst ob diese sich lohnen oder mittlerweile die configs wieder ganz anders sind?
LG
Oekel
ieso04
