[freetz-1.0.3] libftdi lässt sich nicht übersetzen
3PO
3 Jun 2005
Bei bricht der Compiler bei libftdi ab.
tar -C source -v -xzf dl/libftdi-0.14.tar.gz
libftdi-0.14/
libftdi-0.14/doc/
libftdi-0.14/doc/Makefile.am
libftdi-0.14/doc/Makefile.in
libftdi-0.14/doc/Doxyfile.in
libftdi-0.14/src/
libftdi-0.14/src/ftdi.c
libftdi-0.14/src/ftdi.h
libftdi-0.14/src/Makefile.am
libftdi-0.14/src/Makefile.in
libftdi-0.14/depcomp
libftdi-0.14/libftdi.pc.in
libftdi-0.14/aclocal.m4
libftdi-0.14/COPYING.LIB
libftdi-0.14/README
libftdi-0.14/ltmain.sh
libftdi-0.14/configure
libftdi-0.14/configure.in
libftdi-0.14/config.guess
libftdi-0.14/install-sh
libftdi-0.14/config.sub
libftdi-0.14/missing
libftdi-0.14/Makefile.am
libftdi-0.14/Makefile.in
libftdi-0.14/config.h.in
libftdi-0.14/libftdi-config.in
libftdi-0.14/libftdi.spec.in
libftdi-0.14/AUTHORS
libftdi-0.14/examples/
libftdi-0.14/examples/simple.c
libftdi-0.14/examples/find_all.c
libftdi-0.14/examples/Makefile.am
libftdi-0.14/examples/Makefile.in
libftdi-0.14/examples/bitbang_ft2232.c
libftdi-0.14/examples/bitbang2.c
libftdi-0.14/examples/bitbang_cbus.c
libftdi-0.14/examples/bitbang.c
libftdi-0.14/ChangeLog
shopt -s nullglob; for i in make/libs/patches/*.libftdi.patch; do tools/freetz_patch source/libftdi-0.14 $i; done
touch source/libftdi-0.14/.unpacked
( cd source/libftdi-0.14;  rm -f config.{cache,status} ;  source /var/freetz/freetz-1.0.3/make/config.mipsel ;  PATH="/var/freetz/freetz-1.0.3/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" CC="/var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc" CXX="/var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS=""  ./configure   --cache-file=/var/freetz/freetz-1.0.3/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls  --enable-shared --enable-static )
configure: loading cache /var/freetz/freetz-1.0.3/make/config.cache
checking for a BSD-compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... (cached) /bin/mkdir -p
checking for gawk... (cached) gawk
checking whether make sets $(MAKE)... (cached) yes
checking for mipsel-linux-strip... (cached) mipsel-linux-strip
checking for mipsel-linux-gcc... (cached) /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... (cached) o
checking whether we are using the GNU C compiler... (cached) yes
checking whether /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc accepts -g... (cached) yes
checking for /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc option to accept ISO C89... (cached) none needed
checking for style of include used by make... GNU
checking dependency style of /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc... (cached) gcc3
checking build system type... (cached) i386-pc-linux-gnu
checking host system type... (cached) mipsel-unknown-linux-gnu
checking for a sed that does not truncate output... (cached) /bin/sed
checking for grep that handles long lines and -e... (cached) /bin/grep
checking for egrep... (cached) /bin/grep -E
checking for ld used by /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc... (cached) /var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking if the linker (/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld... (cached) yes
checking for /var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld option to reload object files... (cached) -r
checking for BSD-compatible nm... (cached) /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... (cached) pass_all
checking how to run the C preprocessor... (cached) /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -E
checking for ANSI C header files... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for memory.h... (cached) yes
checking for strings.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for unistd.h... (cached) yes
checking for dlfcn.h... (cached) yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc accepts -g... (cached) yes
checking dependency style of /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc... (cached) gcc3
checking how to run the C++ preprocessor... (cached) /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -E
checking for mipsel-linux-g77... no
checking for mipsel-linux-xlf... no
checking for mipsel-linux-f77... no
checking for mipsel-linux-frt... no
checking for mipsel-linux-pgf77... no
checking for mipsel-linux-cf77... no
checking for mipsel-linux-fort77... no
checking for mipsel-linux-fl32... no
checking for mipsel-linux-af77... no
checking for mipsel-linux-xlf90... no
checking for mipsel-linux-f90... no
checking for mipsel-linux-pgf90... no
checking for mipsel-linux-pghpf... no
checking for mipsel-linux-epcf90... no
checking for mipsel-linux-gfortran... no
checking for mipsel-linux-g95... no
checking for mipsel-linux-xlf95... no
checking for mipsel-linux-f95... no
checking for mipsel-linux-fort... no
checking for mipsel-linux-ifort... no
checking for mipsel-linux-ifc... no
checking for mipsel-linux-efc... no
checking for mipsel-linux-pgf95... no
checking for mipsel-linux-lf95... no
checking for mipsel-linux-ftn... no
checking for g77... (cached) gfortran
configure: WARNING: In the future, Autoconf will not detect cross-tools
whose name does not start with the host triplet.  If you think this
configuration is useful to you, please write to [email protected].
checking whether we are using the GNU Fortran 77 compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking the maximum length of command line arguments... (cached) 32768
checking command to parse /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-nm -B output from /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc object... (cached) ok
checking for objdir... (cached) .libs
checking for mipsel-linux-ar... (cached) mipsel-linux-ar
checking for mipsel-linux-ranlib... (cached) mipsel-linux-ranlib
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc supports -fno-rtti -fno-exceptions... (cached) no
checking for /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc option to produce PIC... -fPIC
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc PIC flag -fPIC works... yes
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc static flag -static works... yes
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc supports -c -o file.o... (cached) yes
checking whether the /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc linker (/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc... (cached) /var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking whether the /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc linker (/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking for /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc option to produce PIC... -fPIC
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc PIC flag -fPIC works... yes
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc static flag -static works... no
checking if /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-g++-uc supports -c -o file.o... (cached) yes
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... (cached) yes
checking whether the gfortran linker (/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking for libusb-config... /var/freetz/freetz-1.0.3/toolchain/target/bin/libusb-config
checking if libusb version is >= 0.1.7... yes
checking for doxygen... /usr/bin/doxygen
configure: updating cache /var/freetz/freetz-1.0.3/make/config.cache
configure: creating ./config.status
config.status: creating libftdi-config
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing default commands
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating examples/Makefile
config.status: creating doc/Doxyfile
config.status: creating doc/Makefile
config.status: creating libftdi.pc
config.status: creating libftdi.spec
config.status: config.h is unchanged
touch source/libftdi-0.14/.configured
PATH=/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin:/bin:/sbin:/usr/bin:/usr/sbin \
           make -j2 -C source/libftdi-0.14 all
make[1]: Entering directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14'
make  all-recursive
make[2]: Entering directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14'
Making all in src
make[3]: Entering directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14/src'
/bin/sh ../libtool --tag=CC   --mode=compile /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I..     -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -MT ftdi.lo -MD -MP -MF .deps/ftdi.Tpo -c -o ftdi.lo ftdi.c
mkdir .libs
 /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I.. -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -MT ftdi.lo -MD -MP -MF .deps/ftdi.Tpo -c ftdi.c  -fPIC -DPIC -o .libs/ftdi.o
 /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I.. -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -MT ftdi.lo -MD -MP -MF .deps/ftdi.Tpo -c ftdi.c -o ftdi.o >/dev/null 2>&1
mv -f .deps/ftdi.Tpo .deps/ftdi.Plo
/bin/sh ../libtool --tag=CC   --mode=link /var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc  -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -version-info 15:0:14   -o libftdi.la -rpath /usr/lib ftdi.lo  -lusb
/var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared  .libs/ftdi.o  /usr/lib/libusb.so  -march=4kc -Wl,-soname -Wl,libftdi.so.1 -o .libs/libftdi.so.1.14.0
/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.2.1/../../../../mipsel-linux-uclibc/bin/ld: skipping incompatible /lib/libusb.so when searching for /lib/libusb.so
/var/freetz/freetz-1.0.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.2.1/../../../../mipsel-linux-uclibc/bin/ld: cannot find /lib/libusb.so
collect2: ld returned 1 exit status
make[3]: *** [libftdi.la] Fehler 1
make[3]: Leaving directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14/src'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14'
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/var/freetz/freetz-1.0.3/source/libftdi-0.14'
make: *** [source/libftdi-0.14/src/.libs/libftdi.so.1.14.0] Fehler 2
freetz@vdr02 /var/freetz/freetz-1.0.3 $
libusb ist aber installiert, - zumindest mal wurde es heruntergeladen und existeiert im source-, und im toolchain Verzeichnis...
/var/freetz/freetz-1.0.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared  .libs/ftdi.o  [B]/usr/lib/libusb.so[/B]  -march=4kc -Wl,-soname -Wl,libftdi.so.1 -o .libs/libftdi.so.1.14.0
Das /usr/lib/libusb.so gehört da nicht hin (Zweite Zeile, nach rechts Scrollen. Vermutlich muß bei der Installation der libusb noch der Pfad angepaßt werden, damit die richtige libusb gesucht wird und nicht die im System installierte.
Ich habe mal folgendes gemacht....
svn up
make dirclean
make oldconfig
make
...Revision 3320 wurde auch ausgecheckt....
freetz@vdr02 /var/freetz/freetz-1.0.3 $ svn up
Revision 3320.
...aber die Fehlermeldung ist immernoch die selbe:
make  all-recursive
Making all in src
mkdir .libs
make libusb-dirclean
MfG Oliver
Geht auch nicht. :(
Selber Fehler.
make libftdi-dirclean :-)
MfG Oliver
Äh, achso. Du hast wahrscheinlich den Tag ausgecheckt oder? Du musst den stable-1.0 branch auschecken.
MfG Oliver
MfG Oliver
Thx, mit der stable 1.0 ging es. :)
Allerdings hängt er jetzt bei: dns2tcp :(
mkdir -p packages/dns2tcp-0.4.1/root
if test -d make/dns2tcp/files; then tar -c -C make/dns2tcp/files --exclude=.svn . | tar -x -C packages/dns2tcp-0.4.1 ; fi
tools/freetz_download dl .config dns2tcp-0.4.1.tar.gz http://www.hsc.fr/ressources/outils/dns2tcp/download
--2009-05-11 12:56:03--  http://www.hsc.fr/ressources/outils/dns2tcp/download/dns2tcp-0.4.1.tar.gz
Auflösen des Hostnamen »www.hsc.fr«.... 217.174.211.25
Verbindungsaufbau zu www.hsc.fr|217.174.211.25|:80... verbunden.
HTTP Anforderung gesendet, warte auf Antwort... 301 Moved Permanently
Platz: http://www.hsc.fr/ressources/outils/dns2tcp/download/dns2tcp-0.4.3.tar.gz[folge]
--2009-05-11 12:56:03--  http://www.hsc.fr/ressources/outils/dns2tcp/download/dns2tcp-0.4.3.tar.gz
HTTP Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 230596 (225K) [application/x-tar]
In »dl/dns2tcp-0.4.3.tar.gz« speichern.
100%[=====================================================================================================================================================================>] 230.596     44,7K/s   in 5,0s
2009-05-11 12:56:12 (45,0 KB/s) - »dl/dns2tcp-0.4.3.tar.gz« gespeichert [230596/230596]
Download succeeded - http://www.hsc.fr/ressources/outils/dns2tcp/download/dns2tcp-0.4.1.tar.gz  ->  saved to folder dl
rm -f -r source/dns2tcp-0.4.1
tar -C source -v -xzf dl/dns2tcp-0.4.1.tar.gz
tar: dl/dns2tcp-0.4.1.tar.gz: Kann open nicht ausführen: Datei oder Verzeichnis nicht gefunden
tar: Nicht behebbarer Fehler: Programmabbruch.
tar: Child returned status 2
tar: Fehler beim Beenden, verursacht durch vorhergehende Fehler.
make: *** [source/dns2tcp-0.4.1/.unpacked] Fehler 2
freetz@vdr02 /var/freetz/freetz-stable-1.0 $
Das brachte die Lösung:
cd dl
rm -f dns2tcp-0.4.1.tar.gz
wget http://dsmod.magenbrot.net/dns2tcp-0.4.1.tar.gz
cd ..
make
...Jetzt hängst an: madplay :(
checking for correct ltmain.sh version... no
configure: error:
*** [Gentoo] sanity check failed! ***
*** libtool.m4 and ltmain.sh have a version mismatch! ***
*** (libtool.m4 = 1.5.26, ltmain.sh = 1.5.2) ***
Please run:
  libtoolize --copy --force
if appropriate, please contact the maintainer of this
package (or your distribution) for help.
make[1]: *** [config.status] Fehler 1
make[1]: Leaving directory `/var/freetz/freetz-stable-1.0/source/madplay-0.15.2b'
make: *** [source/madplay-0.15.2b/madplay] Fehler 2
Ich frag mich langsam, wo das Problem an deiner Build-Umgebung herkommt, und ob du nicht vielleicht versuchen solltest, dort erst einmal alles ins Reine zu bringen...
Wenn Du Dir das Problem mit dns2tcp genauer anschaust, wirst Du feststellen, daß zwar die Version 0.4.1 angefordert wurde, aber statt dessen die 0.4.3 geliefert wurde.
Es ist eine Sache, alte Dateien vom Download-Server zu nehmen, aber ungefragt andere Versionen zu liefern, finde ich nicht gut.
Eine ziemlich unfeine Art des Serverbetreibers, ja.
Und wie sollte ich alles "ins Reine" bringen?
Ich verwende Gentoo-Linux und hatte eigentlich bisher keine Probleme mit dem Übersetzen von Code....
Auch hier stellt sich die Frage, was ich denn sonst hätte tun sollen?
BTW:
Ich bin mir ziemlich sicher, dass ich nicht der Einzige bin, bei dem eine falsche Version heruntergeladen wird, oder?
Ich habe mal in der /freetz-stable-1.0/source/madplay-0.15.2b/ltmain.sh den Eintrag "VERSION" gändert:
.....# Constants.
PROGRAM=ltmain.sh
PACKAGE=libtool
#VERSION=1.5.2
VERSION=1.5.26
TIMESTAMP=" (1.1220.2.60 2004/01/25 12:25:08) Debian$Rev: 192 $"
Ob das der richtige Weg ist weis ich leider nicht, aber auf jeden Fall lässt sich madplay damit kompilieren. :)
....Ich bin ja mal gespannt, wo es als nächstes hängen bleibt.... :)
Wie wenn ich's gewusst hätte...:)
Jetzt hängt es an ruby
compiling gdbm
compiling iconv
make[2]: Entering directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/iconv'
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -I. -I../.. -I../../. -I../.././ext/iconv -DICONV_INPTR_CONST  -fPIC -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -c iconv.c
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared -rdynamic -Wl,-export-dynamic   -L'../..' -o ../../.ext/mipsel-linux/iconv.so iconv.o  -liconv  -ldl -lcrypt -lm   -lc
make[2]: Leaving directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/iconv'
compiling io/wait
make[2]: Entering directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/io/wait'
mkdir -p ../../../.ext/mipsel-linux/io
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -I. -I../../.. -I../../../. -I../../.././ext/io/wait -DFIONREAD_HEADER="<sys/ioctl.h>"  -fPIC -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -c wait.c
mkdir -p ../../../.ext/common/io
cp ../../.././ext/io/wait/lib/nonblock.rb ../../../.ext/common/io
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared -rdynamic -Wl,-export-dynamic   -L'../../..' -o ../../../.ext/mipsel-linux/io/wait.so wait.o  -ldl -lcrypt -lm   -lc
make[2]: Leaving directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/io/wait'
compiling nkf
make[2]: Entering directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/nkf'
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -I. -I../.. -I../../. -I../.././ext/nkf  -fPIC -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -c nkf.c
cp ../.././ext/nkf/lib/kconv.rb ../../.ext/common
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared -rdynamic -Wl,-export-dynamic   -L'../..' -o ../../.ext/mipsel-linux/nkf.so nkf.o  -ldl -lcrypt -lm   -lc
make[2]: Leaving directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/nkf'
compiling openssl
make[2]: Entering directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/openssl'
/var/freetz/freetz-stable-1.0/toolchain/target/bin/mipsel-linux-uclibc-gcc -I. -I../.. -I../../. -I../.././ext/openssl -DRUBY_EXTCONF_H=\"extconf.h\"  -fPIC -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -c ossl_hmac.c
In file included from ossl.h:192,
                 from ossl_hmac.c:13:
openssl_missing.h:119: error: conflicting types for 'BN_rand_range'
/var/freetz/freetz-stable-1.0/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.2.1/../../../../mipsel-linux-uclibc/sys-include/openssl/bn.h:411: error: previous declaration of 'BN_rand_range' was here
openssl_missing.h:120: error: conflicting types for 'BN_pseudo_rand_range'
/var/freetz/freetz-stable-1.0/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.2.1/../../../../mipsel-linux-uclibc/sys-include/openssl/bn.h:412: error: previous declaration of 'BN_pseudo_rand_range' was here
make[2]: *** [ossl_hmac.o] Fehler 1
make[2]: Leaving directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/openssl'
make[1]: *** [all] Fehler 1
make[1]: Leaving directory `/var/freetz/freetz-stable-1.0/source/ruby-1.8.6'
make: *** [source/ruby-1.8.6/ruby] Fehler 2
So, das Problem mir ruby konnte ich nun auch lösen.:
Ich habe mal die /freetz-stable-1.0/source/ruby-1.8.6/ext/openssl/openssl_missing.h angepasst.
--- /var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/openssl/openssl_missing.h.orig  2009-05-12 10:06:36.000000000 +0200
+++ /var/freetz/freetz-stable-1.0/source/ruby-1.8.6/ext/openssl/openssl_missing.h       2009-05-12 09:09:22.000000000 +0200
@@ -116,8 +116,10 @@
 int BN_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
 int BN_mod_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
 int BN_mod_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
-int BN_rand_range(BIGNUM *r, BIGNUM *range);
-int BN_pseudo_rand_range(BIGNUM *r, BIGNUM *range);
+//int BN_rand_range(BIGNUM *r, BIGNUM *range);
+//int BN_pseudo_rand_range(BIGNUM *r, BIGNUM *range);
+int    BN_rand_range(BIGNUM *rnd, const BIGNUM *range);
+int    BN_pseudo_rand_range(BIGNUM *rnd, const BIGNUM *range);
 char *CONF_get1_default_config_file(void);
 int PEM_def_callback(char *buf, int num, int w, void *key);
Gefunden habe ich das hier:KLICK
Bin ja mal gespannt, wie es weiter geht... :)
"Jo is denn schon Weihnachten?" :) :) :)
STEP 3: PACK
  Checking for left over Subversion directories
squashfs blocksize
  root filesystem: 65536
packing var.tar
creating filesystem image
merging kernel image
  kernel image size: 14312704 (max: 16121856, free: 1809152)
packing 7270_04.70freetz-1.0-stable-3322.de_20090512-103225.image
Image files can be found in the ./images/ subfolder
done.
FINISHED
FINISHED ?? - Das ging aber schell :)
Rubinek
