freetz-6365 download transfer limited to 1Mb/s
avathar
4 Okt 2010
hi
box - 7240
fw - freetz-devel-6365
Since some not quite precision time i noticed that my download transfer through vsftpd and samba is limited to 1Mb/s.
Upload speed isn't constant but it can reach 3Mb/s.
So, is it only my problem or anybody else noticed the same problem ?
translated by google
Da einige nicht ganz präzise Zeit bemerkte ich, dass mein Download-Transfer durch vsftpd und Samba bis 1MB / s begrenzt
Upload-Geschwindigkeit ist nicht konstant, sondern es können 3 Mb / s erreichen
So ist es nur mein Problem oder sonst jemand das gleiche Problem bemerkt?
The google translations are a kind of weird ;)
Ok, please check your transfer rates with another usb harddrive or another stick if this behaviour changes...
What filesystems do you use? What does top show when the transfer is running?
Regards
Oliver
i tested this behavior in several conditions:
executed FRITZ.Box_Fon_WLAN_7240.04.87.recover-image.exe without problems
Then executed FTP connection and transfer is only 1MB/s (something about 1150kbytes/s max). Tested with FAT and
FAT32 file systems.
I also checked my hdd with JMicron adapter. Also checked ext3 filesystem and ntfs.
I notice one thing and i'm not sure that it is correct.
When go to Heimnetz/USB-Gerate i see what is actually discovered by fritz and i see this after placing mouse over the name of usb item:
usb-Anschluss 2.0
Geschwindigkeit 12MBit/s
shouldn't be here 480MBit/s ? 12Mbit/s means only usb 1.1 and max 1500kbytes/s
http://tinyurl.com/48dursz
can anybody tell me, what will happen when you plug into fritz 7240 or 7270 only card reader without any memory inside. What is displayed at Heimnetz/USB-Gerate ,what speed is showed: 12MBit/s or 480 ?
again can anybody tell me just this one thing, what will happen when you plug into fritz 7240 or 7270 only card reader(or usb to sata controler) without any memory (or hdd disc) inside. What is displayed at Heimnetz/USB-Gerate ,what speed is showed: 12MBit/s or 480 ?
Take a look at picture below to know where to look for it.
The problem was in hardware, box was replaced by avm.
Thank you for the response. I will close this thread as your problem is solved.
Regards
Oliver
PatrickSt91
