Freetz and AVM 7270
JPAdie
20 Sep 2006
Hi
what config do i choose for a 7270 with Freetz in the menu conigurator? is it 'custom' and if so are there any subsequent choices that are advisable to keep things functional?
thanks
Justin
Hi.
For your 7270 you should choose "7270", I think ;)
greetz cinereous/Silent-Tears
hmmm....
you see in the version that i checked out from the svn last night, there was no 7270 in the menu configurator.
hence my question !! ;-)
I think you should use the "arrow down"-key where you choose your hardware-type. There I can see the 7270 as " Fon WLAN 7270"
@RalfFriedl: None of the patches last night could affect the Config.in in this way I think.
thank you all. i will refresh the checkout and try again. it may be that i was doing something wrong.
Protonator
