Hi
thanks to help from this forum and the writers of Freetz, i have now successfully uploaded a new image to my FB7270 based on the new firmware (54.05.55).
my issue now is with openvpn.
the binary is properly installed and i have uploaded the certs and keys through the web interface.
all my VPN's are bridges and i'd like for this one to be the same. i select the relevant options in the configurator and start the service but i do not see the bridge being created (brctl show does not reveal that tap0 has been added to the bridge).
i am also not convinced by some of the configuration settings that the configurator writes to the config file - some of them i would expect to see in a tunnel'd interface rather than a bridged one. is the configurator 'work in progress'? if so i will just upload my own config. similarly does the configurator call an 'up' script so that i can manually script the addition to the bridge? if not, can i add the bridge command to debug.cfg (i.e. does debug.cfg get called AFTER the openvpn service gets started?)
next step is to translate the interface....
thanks, as always, for the help.
Justin
Justin
