[Problem] Freetz-Build-Error bei External
xsapling
30 Jan 2005
Beim Bau mit der Freetz-Version Revision 11627 friert der Bau nach folgender Fehlermeldung ein:
  wol-0.7.1 ....................    6.64 Kb
  wol-cgi-0.6 ..................    2.99 Kb
  xmail-1.27 ...................  205.77 Kb
  zabbix-2.0.10 ................  576.68 Kb
invoking custom script
processing mod base options
  setting colored style as default
  patching security level (0)
  integrated external
  integrated FREETZMOUNT
  integrated Box-Info
  integrated FREETZ-Info
  integrated .config (stripped)
stripping leftover unstripped binaries
    build/modified/filesystem/usr/lib/freetz/libpcre.so.1.2.1
    build/modified/filesystem/usr/sbin/oamd
    build/modified/filesystem/usr/sbin/oamctl
    build/modified/filesystem/usr/share/ctlmgr/libplcctlmgr.so
    build/modified/filesystem/usr/share/ctlmgr/libwlan.so
    build/modified/filesystem/lib/libdslsmiface.so.0.0.0
    build/modified/filesystem/lib/libm-0.9.32.1.so
    build/modified/filesystem/lib/librt-0.9.32.1.so
    build/modified/filesystem/lib/libluadsl.so.1.0.0
    build/modified/filesystem/lib/ld-uClibc-0.9.32.1.so
    build/modified/filesystem/lib/libthread_db-0.9.32.1.so
    build/modified/filesystem/lib/libutil-0.9.32.1.so
    build/modified/filesystem/lib/libluaplc.so
    build/modified/filesystem/lib/libcrypt-0.9.32.1.so
    build/modified/filesystem/lib/libuClibc-0.9.32.1.so
    build/modified/filesystem/lib/libdl-0.9.32.1.so
    build/modified/filesystem/lib/libwlancsi.so
    build/modified/filesystem/lib/libpthread-0.9.32.1.so
    build/modified/filesystem/lib/libwlanparams.so
    build/modified/filesystem/bin/wlancfgconv
    build/modified/filesystem/bin/wlancfgctl
[B]processing external[/B]
[B]cat: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/.ppp: Datei oder Verzeichnis nicht gefunden[/B]
[B]/home/freetz/7490/freetz-7490-test/tools/external: Zeile 53: cd: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/ppp-/root/: Datei oder Verzeichnis nicht gefunden[/B]
Die config
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6840 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_V2 is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7390 is not set
FREETZ_TYPE_7490=y
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_FIRMWARE_05_5X is not set
# FREETZ_TYPE_FIRMWARE_06_XX is not set
FREETZ_TYPE_FIRMWARE_LABOR=y
FREETZ_TYPE_LANGUAGE="de"
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# Remove piglet
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_AHA is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_MYFRITZ is not set
# FREETZ_REMOVE_FHEM is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
FREETZ_REMOVE_CHRONYD=y
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_NTFS is not set
FREETZ_REMOVE_PRINTSERV=y
# FREETZ_REMOVE_PRINTSERV_MODULE is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SAMBA is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
FREETZ_REMOVE_AVM_E2FSPROGS=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_VCC is not set
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_GSMVOICE is not set
FREETZ_PATCH_SIGNED=y
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_EXT4=y
FREETZ_AUTOMOUNT_FAT=y
FREETZ_AUTOMOUNT_HFS=y
FREETZ_AUTOMOUNT_HFS_PLUS=y
FREETZ_AUTOMOUNT_LUKS=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_AUTOMOUNT_REISER_FS=y
FREETZ_AUTOMOUNT_LINUXSWAP=y
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_MODIFY_UMTSD is not set
FREETZ_CUSTOM_UDEV_RULES=y
# Replacement patches --------------------
# Replace OpenSSL libraries (not available, requires openssl-0.9.8)
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
FREETZ_AVMDAEMON_DISABLE_IGM=y
# FREETZ_AVMDAEMON_DISABLE_TR069 is not set
FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS=y
FREETZ_AVMDAEMON_DISABLE_DNS=y
FREETZ_AVMDAEMON_DISABLE_DHCP=y
FREETZ_AVMDAEMON_DISABLE_LLMNR=y
# Additional components ------------------
# Packages
# Debug helpers
FREETZ_PACKAGE_GDB=y
# binaries
FREETZ_PACKAGE_GDB_GDB=y
FREETZ_PACKAGE_GDB_GDBSERVER=y
FREETZ_PACKAGE_GDB_HOST=y
# FREETZ_GDB_VERSION_6_8 is not set
FREETZ_GDB_VERSION_7_6=y
FREETZ_PACKAGE_INOTIFY_TOOLS=y
FREETZ_PACKAGE_LDD=y
# FREETZ_PACKAGE_LSOF is not set
FREETZ_PACKAGE_LTRACE=y
# FREETZ_PACKAGE_NANO_SHELL is not set
FREETZ_PACKAGE_PCIUTILS=y
FREETZ_PACKAGE_PCIUTILS_IDS=y
FREETZ_PACKAGE_STRACE=y
# FREETZ_PACKAGE_TARGET_TESTER is not set
FREETZ_PACKAGE_USBUTILS=y
FREETZ_PACKAGE_USBUTILS_IDS=y
FREETZ_PACKAGE_USBUTILS_IDS_UPDATE=y
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
FREETZ_PACKAGE_COMGT=y
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
FREETZ_PACKAGE_CURL=y
# FREETZ_PACKAGE_CURL_STATIC is not set
FREETZ_PACKAGE_DANTE=y
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
FREETZ_PACKAGE_DIGITEMP=y
# FREETZ_PACKAGE_DIGITEMP_DS2490 is not set
# FREETZ_PACKAGE_DIGITEMP_DS9097U is not set
FREETZ_PACKAGE_DIGITEMP_DS9097=y
FREETZ_PACKAGE_DNS2TCP=y
FREETZ_PACKAGE_DNSMASQ=y
# HINT: Don't forget to enable a dns/dhcp server.
FREETZ_PACKAGE_DNSMASQ_DISABLE_DNS=y
FREETZ_PACKAGE_DNSMASQ_DISABLE_DHCP=y
# FREETZ_PACKAGE_DOSFSTOOLS is not set
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY=y
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
FREETZ_PACKAGE_DROPBEAR_UTMP=y
FREETZ_PACKAGE_DROPBEAR_WTMP=y
FREETZ_PACKAGE_DROPBEAR_STATIC=y
# FREETZ_PACKAGE_DROPBEAR_NONFREETZ is not set
# FREETZ_PACKAGE_DTACH is not set
FREETZ_PACKAGE_DVBSNOOP=y
# FREETZ_PACKAGE_DVBSTREAM is not set
FREETZ_PACKAGE_DVBTUNE=y
FREETZ_PACKAGE_E2FSPROGS=y
FREETZ_PACKAGE_E2FSPROGS_STATIC=y
FREETZ_PACKAGE_E2FSPROGS_E2FSCK=y
FREETZ_PACKAGE_E2FSPROGS_E2MAKING=y
FREETZ_PACKAGE_E2FSPROGS_E2TUNING=y
FREETZ_PACKAGE_E2FSPROGS_E2DEBUG=y
FREETZ_PACKAGE_E2FSPROGS_E2FIXING=y
FREETZ_PACKAGE_E2FSPROGS_E2RESIZE=y
FREETZ_PACKAGE_EMAILRELAY=y
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_ESPEAK=y
# FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES is not set
# FREETZ_PACKAGE_FFMPEG is not set
FREETZ_PACKAGE_FORTUNE=y
# FREETZ_PACKAGE_FOWSR is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_HASERL_WITH_LUA=y
FREETZ_PACKAGE_HD_IDLE=y
FREETZ_PACKAGE_HOL=y
FREETZ_PACKAGE_HTML2TEXT=y
FREETZ_PACKAGE_HTOP=y
FREETZ_PACKAGE_HTPDATE=y
FREETZ_PACKAGE_HTTPRY=y
# FREETZ_PACKAGE_HTTPRY_REMOVE_WEBIF is not set
FREETZ_PACKAGE_HTTPTUNNEL=y
FREETZ_PACKAGE_IFSTAT=y
FREETZ_PACKAGE_IFTOP=y
FREETZ_PACKAGE_IGMPPROXY=y
# FREETZ_PACKAGE_IMAGEMAGICK is not set
FREETZ_PACKAGE_INADYN_MT=y
FREETZ_PACKAGE_INADYN_OPENDNS=y
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
FREETZ_PACKAGE_IODINE=y
FREETZ_PACKAGE_IPSEC_TOOLS=y
FREETZ_PACKAGE_IPSEC_TOOLS_STATIC=y
FREETZ_PACKAGE_IPSEC_TOOLS_WITH_LZO=y
FREETZ_PACKAGE_IPSEC_TOOLS_WITH_PLAINRSAGEN=y
FREETZ_PACKAGE_IPSEC_TOOLS_WITH_RACOONCTL=y
FREETZ_PACKAGE_IPTRAF=y
FREETZ_PACKAGE_IPTRAF_RVNAMED=y
FREETZ_PACKAGE_IPUTILS=y
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
FREETZ_PACKAGE_JS=y
FREETZ_PACKAGE_KNOCK=y
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
FREETZ_PACKAGE_MADPLAY=y
FREETZ_PACKAGE_MATRIXTUNNEL=y
FREETZ_PACKAGE_MC=y
# Configuration
FREETZ_PACKAGE_MC_WITH_NCURSES=y
# FREETZ_PACKAGE_MC_WITH_SLANG is not set
FREETZ_PACKAGE_MC_WITH_BACKGROUND=y
FREETZ_PACKAGE_MC_WITH_CHARSET=y
FREETZ_PACKAGE_MC_WITH_EDIT=y
FREETZ_PACKAGE_MC_WITH_DIFF_VIEWER=y
FREETZ_PACKAGE_MC_WITH_SUBSHELL=y
FREETZ_PACKAGE_MC_WITH_VFS=y
FREETZ_PACKAGE_MC_WITH_VFS_CPIO=y
FREETZ_PACKAGE_MC_WITH_VFS_EXTFS=y
FREETZ_PACKAGE_MC_WITH_VFS_FTP=y
FREETZ_PACKAGE_MC_WITH_VFS_SFS=y
FREETZ_PACKAGE_MC_WITH_VFS_TAR=y
FREETZ_PACKAGE_MC_WITH_HELP=y
FREETZ_PACKAGE_MC_WITH_SYNTAX=y
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
FREETZ_PACKAGE_MICROPERL=y
FREETZ_PACKAGE_MICROPERL_MODULES=""
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
FREETZ_PACKAGE_MTR=y
FREETZ_PACKAGE_NAGIOS=y
FREETZ_PACKAGE_NANO=y
# Nano additional features
FREETZ_PACKAGE_NANO_TINY=y
FREETZ_PACKAGE_NANO_MULTIBUFFER=y
FREETZ_PACKAGE_NANO_NANORC=y
FREETZ_PACKAGE_NANO_COLOR_SYNTAX=y
# Nano syntax highlighting files
FREETZ_PACKAGE_NANO_SYNTAX_FILE_SH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_NANORC=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_C=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_CSS=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_HTML=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PHP=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_TEX=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PATCH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_XML=y
FREETZ_PACKAGE_NC6=y
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NETATALK is not set
FREETZ_PACKAGE_NETCAT=y
# FREETZ_PACKAGE_NETPBM is not set
FREETZ_PACKAGE_NETSNMP=y
FREETZ_PACKAGE_NETSNMP_WITH_OPENSSL=y
FREETZ_PACKAGE_NETSNMP_WITH_ZLIB=y
FREETZ_PACKAGE_NETSNMP_WITH_APPLICATIONS=y
# Select Net-SNMP applications
# Please select Net-SNMP applications to include ---
FREETZ_PACKAGE_NETSNMP_encode_keychange=y
FREETZ_PACKAGE_NETSNMP_snmpbulkget=y
FREETZ_PACKAGE_NETSNMP_snmpbulkwalk=y
FREETZ_PACKAGE_NETSNMP_snmpdelta=y
FREETZ_PACKAGE_NETSNMP_snmpdf=y
FREETZ_PACKAGE_NETSNMP_snmpget=y
FREETZ_PACKAGE_NETSNMP_snmpgetnext=y
FREETZ_PACKAGE_NETSNMP_snmpset=y
FREETZ_PACKAGE_NETSNMP_snmpstatus=y
FREETZ_PACKAGE_NETSNMP_snmptable=y
FREETZ_PACKAGE_NETSNMP_snmptest=y
FREETZ_PACKAGE_NETSNMP_snmptranslate=y
FREETZ_PACKAGE_NETSNMP_snmptrap=y
FREETZ_PACKAGE_NETSNMP_snmptrapd=y
FREETZ_PACKAGE_NETSNMP_snmpusm=y
FREETZ_PACKAGE_NETSNMP_snmpvacm=y
FREETZ_PACKAGE_NETSNMP_snmpwalk=y
FREETZ_PACKAGE_NFSROOT=y
FREETZ_PACKAGE_NFS_UTILS=y
# FREETZ_PACKAGE_NGIRCD is not set
FREETZ_PACKAGE_NMAP=y
# nmap options
FREETZ_PACKAGE_NMAP_VERSION_4=y
# FREETZ_PACKAGE_NMAP_VERSION_5 is not set
# databases
FREETZ_PACKAGE_NMAP_mac_prefixes=y
FREETZ_PACKAGE_NMAP_os_db=y
FREETZ_PACKAGE_NMAP_protocols=y
FREETZ_PACKAGE_NMAP_rpc=y
FREETZ_PACKAGE_NMAP_service_probes=y
FREETZ_PACKAGE_NMAP_services=y
FREETZ_PACKAGE_NMAP_WITH_SHARED_LUA=y
FREETZ_PACKAGE_NMAP_WITH_SHARED_PCRE=y
# FREETZ_PACKAGE_NMAP_STATIC is not set
FREETZ_PACKAGE_NOIP=y
# FREETZ_PACKAGE_OBEXFTP is not set
FREETZ_PACKAGE_OIDENTD=y
FREETZ_PACKAGE_OPENCONNECT=y
FREETZ_PACKAGE_OPENDD=y
FREETZ_PACKAGE_OPENDD_WITH_SSL=y
FREETZ_PACKAGE_OPENNTPD=y
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
FREETZ_PACKAGE_OPENSSH_sshd=y
FREETZ_PACKAGE_OPENSSH_ssh=y
FREETZ_PACKAGE_OPENSSH_scp=y
FREETZ_PACKAGE_OPENSSH_CLIENTUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_add=y
FREETZ_PACKAGE_OPENSSH_ssh_agent=y
FREETZ_PACKAGE_OPENSSH_KEYUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_keygen=y
FREETZ_PACKAGE_OPENSSH_ssh_keysign=y
FREETZ_PACKAGE_OPENSSH_ssh_keyscan=y
FREETZ_PACKAGE_OPENSSH_sftp=y
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# Build statically linked binaries ---
FREETZ_PACKAGE_OPENSSH_STATIC=y
FREETZ_PACKAGE_OPENSSL=y
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_2 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
# FREETZ_PACKAGE_OPENVPN_POLARSSL is not set
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
FREETZ_PACKAGE_OPENVPN_USE_V2_CGI=y
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
FREETZ_PACKAGE_PHP=y
# FREETZ_PHP_VERSION_5_3 is not set
FREETZ_PHP_VERSION_5_4=y
# FREETZ_PHP_VERSION_5_5 is not set
# PHP features
# FREETZ_PACKAGE_PHP_WITH_CURL is not set
# FREETZ_PACKAGE_PHP_WITH_GD is not set
# FREETZ_PACKAGE_PHP_WITH_ICONV is not set
# FREETZ_PACKAGE_PHP_WITH_JSON is not set
# FREETZ_PACKAGE_PHP_WITH_PCNTL is not set
FREETZ_PACKAGE_PHP_WITH_SESSION=y
# FREETZ_PACKAGE_PHP_WITH_SOCKETS is not set
# FREETZ_PACKAGE_PHP_WITH_SQLITE3 is not set
# FREETZ_PACKAGE_PHP_WITH_SSL is not set
# FREETZ_PACKAGE_PHP_WITH_SYSVIPC is not set
# FREETZ_PACKAGE_PHP_WITH_LIBXML is not set
# FREETZ_PACKAGE_PHP_WITH_ZLIB is not set
# FREETZ_PACKAGE_PHP_WITH_ZIP is not set
# FREETZ_PACKAGE_PHP_STATIC is not set
FREETZ_PACKAGE_PINGTUNNEL=y
FREETZ_PACKAGE_POLIPO=y
# FREETZ_PACKAGE_POLIPO_STATIC is not set
FREETZ_PACKAGE_PORTMAP=y
FREETZ_PACKAGE_PPP=y
FREETZ_PACKAGE_PPPD=y
FREETZ_PACKAGE_PPPD_CHAT=y
FREETZ_PACKAGE_PPTP=y
FREETZ_PACKAGE_PPTPD=y
FREETZ_PACKAGE_PRIVOXY=y
FREETZ_PACKAGE_PRIVOXY_WITH_ADBLOCK=y
FREETZ_PACKAGE_PRIVOXY_WITH_SHARED_PCRE=y
FREETZ_PACKAGE_PRIVOXY_WITH_ZLIB=y
FREETZ_PACKAGE_PYLOAD=y
FREETZ_PACKAGE_PYLOAD_VERSION_LATEST_TESTED=y
# FREETZ_PACKAGE_PYLOAD_VERSION_LATEST_GIT is not set
FREETZ_PACKAGE_PYLOAD_EXTRACT=y
FREETZ_PACKAGE_PYLOAD_WITH_TESSERACT=y
FREETZ_PACKAGE_PYLOAD_WITH_LIGHTWEIGHT_WSGI_SERVER=y
FREETZ_PACKAGE_PYTHON=y
FREETZ_PACKAGE_PYTHON_PYC=y
# FREETZ_PACKAGE_PYTHON_PY is not set
FREETZ_PACKAGE_PYTHON_COMPRESS_PYC=y
# FREETZ_PACKAGE_PYTHON_STATIC is not set
# Python binary modules (extensions)
FREETZ_PACKAGE_PYTHON_MOD_AUDIODEV=y
FREETZ_PACKAGE_PYTHON_MOD_AUDIOOP=y
FREETZ_PACKAGE_PYTHON_MOD_BSDDB=y
FREETZ_PACKAGE_PYTHON_MOD_CMATH=y
FREETZ_PACKAGE_PYTHON_MOD_CPROFILE=y
FREETZ_PACKAGE_PYTHON_MOD_CRYPT=y
FREETZ_PACKAGE_PYTHON_MOD_CSV=y
FREETZ_PACKAGE_PYTHON_MOD_CTYPES=y
FREETZ_PACKAGE_PYTHON_MOD_CURSES=y
FREETZ_PACKAGE_PYTHON_MOD_EASTERN_CODECS=y
FREETZ_PACKAGE_PYTHON_MOD_ELEMENTTREE=y
FREETZ_PACKAGE_PYTHON_MOD_GRP=y
FREETZ_PACKAGE_PYTHON_MOD_HOTSHOT=y
FREETZ_PACKAGE_PYTHON_MOD_JSON=y
FREETZ_PACKAGE_PYTHON_MOD_MULTIPROCESSING=y
FREETZ_PACKAGE_PYTHON_MOD_MMAP=y
FREETZ_PACKAGE_PYTHON_MOD_READLINE=y
FREETZ_PACKAGE_PYTHON_MOD_SPWD=y
FREETZ_PACKAGE_PYTHON_MOD_SQLITE=y
FREETZ_PACKAGE_PYTHON_MOD_SSL=y
FREETZ_PACKAGE_PYTHON_MOD_SYSLOG=y
FREETZ_PACKAGE_PYTHON_MOD_TERMIOS=y
FREETZ_PACKAGE_PYTHON_MOD_TEST=y
FREETZ_PACKAGE_PYTHON_MOD_UNICODEDATA=y
FREETZ_PACKAGE_PYTHON_MOD_UNITTEST=y
FREETZ_PACKAGE_PYTHON_MOD_WSGIREF=y
# 3rd-party modules
FREETZ_PACKAGE_PYTHON_BJOERN=y
FREETZ_PACKAGE_PYTHON_IMAGING_LIBRARY=y
FREETZ_PACKAGE_PYTHON_MECHANIZE=y
FREETZ_PACKAGE_PYTHON_PYCRYPTO=y
FREETZ_PACKAGE_PYTHON_PYCURL=y
FREETZ_PACKAGE_PYTHON_PYOPENSSL=y
FREETZ_PACKAGE_PYTHON_PYRRD=y
FREETZ_PACKAGE_PYTHON_PYSERIAL=y
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SAMBA is not set
FREETZ_PACKAGE_SCREEN=y
FREETZ_PACKAGE_SER2NET=y
FREETZ_PACKAGE_SHELLINABOX=y
# FREETZ_PACKAGE_SHELLINABOX_STATIC is not set
FREETZ_PACKAGE_SHELLINABOX_SSL=y
FREETZ_PACKAGE_SIPROXD=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_DEFAULTTARGET=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_FIX_BOGUS_VIA=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_LOGCALL=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_PREFIX=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_REGEX=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_SHORTDIAL=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_STUN=y
FREETZ_PACKAGE_SIPROXD_PLUGIN_DEMO=y
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
FREETZ_PACKAGE_SMSTOOLS3=y
# FREETZ_PACKAGE_SMUSBUTIL is not set
FREETZ_PACKAGE_SOCAT=y
FREETZ_PACKAGE_SOCAT_WITHTERMIOS=y
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
FREETZ_PACKAGE_SSLH=y
FREETZ_PACKAGE_STREAMRIPPER=y
FREETZ_PACKAGE_STREAMRIPPER_WITH_OGGVORBIS=y
FREETZ_PACKAGE_STUNNEL=y
FREETZ_PACKAGE_STUNNEL_STATIC=y
# FREETZ_PACKAGE_SUBVERSION is not set
FREETZ_PACKAGE_SUNDTEK=y
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
FREETZ_PACKAGE_TCPDUMP=y
# FREETZ_PACKAGE_TCPDUMP_MINI is not set
FREETZ_PACKAGE_TCPPROXY=y
FREETZ_PACKAGE_TCP_WRAPPERS=y
FREETZ_PACKAGE_TESSERACT_AVAILABLE=y
FREETZ_PACKAGE_TESSERACT=y
# You need a box with at least 64MB RAM to run Tesseract
# Languages
FREETZ_PACKAGE_TESSERACT_ENG=y
FREETZ_PACKAGE_TESSERACT_DEU=y
FREETZ_PACKAGE_TESSERACT_tesseract=y
FREETZ_PACKAGE_TESSERACT_ambiguous_words=y
FREETZ_PACKAGE_TESSERACT_classifier_tester=y
FREETZ_PACKAGE_TESSERACT_cntraining=y
FREETZ_PACKAGE_TESSERACT_combine_tessdata=y
FREETZ_PACKAGE_TESSERACT_dawg2wordlist=y
FREETZ_PACKAGE_TESSERACT_mftraining=y
FREETZ_PACKAGE_TESSERACT_shapeclustering=y
FREETZ_PACKAGE_TESSERACT_unicharset_extractor=y
FREETZ_PACKAGE_TESSERACT_wordlist2dawg=y
FREETZ_PACKAGE_TIFF=y
FREETZ_PACKAGE_TIFF_bmp2tiff=y
FREETZ_PACKAGE_TIFF_fax2ps=y
FREETZ_PACKAGE_TIFF_fax2tiff=y
FREETZ_PACKAGE_TIFF_gif2tiff=y
FREETZ_PACKAGE_TIFF_ppm2tiff=y
FREETZ_PACKAGE_TIFF_raw2tiff=y
FREETZ_PACKAGE_TIFF_tiff2bw=y
FREETZ_PACKAGE_TIFF_tiff2pdf=y
FREETZ_PACKAGE_TIFF_tiff2ps=y
FREETZ_PACKAGE_TIFF_tiffinfo=y
FREETZ_PACKAGE_TIFF_tiffsplit=y
FREETZ_PACKAGE_TINC=y
# FREETZ_PACKAGE_TINC_STATIC is not set
FREETZ_PACKAGE_TINYPROXY=y
FREETZ_PACKAGE_TINYPROXY_WITH_TRANSPARENT_PROXY=y
FREETZ_PACKAGE_TINYPROXY_WITH_FILTER=y
FREETZ_PACKAGE_TINYPROXY_WITH_UPSTREAM=y
FREETZ_PACKAGE_TINYPROXY_WITH_REVERSE=y
FREETZ_PACKAGE_TINYPROXY_STATIC=y
# FREETZ_PACKAGE_TMUX is not set
FREETZ_PACKAGE_TOR=y
FREETZ_PACKAGE_TOR_GEOIP=y
# FREETZ_PACKAGE_TOR_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION=y
FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
FREETZ_PACKAGE_TRANSMISSION_CREATE=y
FREETZ_PACKAGE_TRANSMISSION_EDIT=y
FREETZ_PACKAGE_TRANSMISSION_SHOW=y
# FREETZ_PACKAGE_TRANSMISSION_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# unfs3 (not available, you have selected incompatible package nfsd)
FREETZ_PACKAGE_UNRAR=y
# FREETZ_PACKAGE_UNRAR_STATIC is not set
FREETZ_PACKAGE_USBIP=y
FREETZ_PACKAGE_USBIP_WRAPPER=y
FREETZ_PACKAGE_USBROOT=y
FREETZ_PACKAGE_USBROOT_E2FSCK=y
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
FREETZ_PACKAGE_VIM=y
# FREETZ_PACKAGE_VIM_TINY is not set
FREETZ_PACKAGE_VIM_NORMAL=y
# FREETZ_PACKAGE_VIM_HUGE is not set
FREETZ_PACKAGE_VNSTAT=y
FREETZ_PACKAGE_VNSTAT_DAEMON=y
FREETZ_PACKAGE_VNSTAT_IMAGE=y
FREETZ_PACKAGE_VPNC=y
FREETZ_PACKAGE_VPNC_WITH_HYBRID_AUTH=y
FREETZ_PACKAGE_VPNC_NAT_SUPPORT=y
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
FREETZ_PACKAGE_WGET_USE_GNUTLS=y
FREETZ_PACKAGE_WGET_STATIC=y
FREETZ_PACKAGE_WOL=y
# FREETZ_PACKAGE_WPUT is not set
FREETZ_PACKAGE_XMAIL=y
# FREETZ_PACKAGE_XMAIL_WITH_SSL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Unstable
FREETZ_PACKAGE_ASTERISK=y
FREETZ_PACKAGE_ASTERISK_LOWMEMORY=y
# FREETZ_PACKAGE_ASTERISK_DEBUG is not set
# FREETZ_PACKAGE_ASTERISK_EMBED_MODULES is not set
# FREETZ_PACKAGE_ASTERISK_GUI is not set
# Asterisk modules
# Add-ons
FREETZ_PACKAGE_ASTERISK_CHAN_OOH323=y
FREETZ_PACKAGE_ASTERISK_FORMAT_MP3=y
# Applications
FREETZ_PACKAGE_ASTERISK_APP_ADSIPROG=y
FREETZ_PACKAGE_ASTERISK_APP_ALARMRECEIVER=y
FREETZ_PACKAGE_ASTERISK_APP_AMD=y
FREETZ_PACKAGE_ASTERISK_APP_AUTHENTICATE=y
FREETZ_PACKAGE_ASTERISK_APP_CDR=y
FREETZ_PACKAGE_ASTERISK_APP_CELGENUSEREVENT=y
FREETZ_PACKAGE_ASTERISK_APP_CHANISAVAIL=y
FREETZ_PACKAGE_ASTERISK_APP_CHANNELREDIRECT=y
FREETZ_PACKAGE_ASTERISK_APP_CHANSPY=y
FREETZ_PACKAGE_ASTERISK_APP_CONFBRIDGE=y
FREETZ_PACKAGE_ASTERISK_APP_CONTROLPLAYBACK=y
FREETZ_PACKAGE_ASTERISK_APP_DB=y
FREETZ_PACKAGE_ASTERISK_APP_DIAL=y
FREETZ_PACKAGE_ASTERISK_APP_DICTATE=y
FREETZ_PACKAGE_ASTERISK_APP_DIRECTED_PICKUP=y
FREETZ_PACKAGE_ASTERISK_APP_DIRECTORY=y
FREETZ_PACKAGE_ASTERISK_APP_DISA=y
FREETZ_PACKAGE_ASTERISK_APP_DUMPCHAN=y
FREETZ_PACKAGE_ASTERISK_APP_ECHO=y
FREETZ_PACKAGE_ASTERISK_APP_EXEC=y
FREETZ_PACKAGE_ASTERISK_APP_EXTERNALIVR=y
FREETZ_PACKAGE_ASTERISK_APP_FESTIVAL=y
FREETZ_PACKAGE_ASTERISK_APP_FOLLOWME=y
FREETZ_PACKAGE_ASTERISK_APP_FORKCDR=y
FREETZ_PACKAGE_ASTERISK_APP_GETCPEID=y
FREETZ_PACKAGE_ASTERISK_APP_ICES=y
FREETZ_PACKAGE_ASTERISK_APP_IMAGE=y
FREETZ_PACKAGE_ASTERISK_APP_MACRO=y
FREETZ_PACKAGE_ASTERISK_APP_MILLIWATT=y
FREETZ_PACKAGE_ASTERISK_APP_MINIVM=y
FREETZ_PACKAGE_ASTERISK_APP_MIXMONITOR=y
FREETZ_PACKAGE_ASTERISK_APP_MORSECODE=y
FREETZ_PACKAGE_ASTERISK_APP_MP3=y
FREETZ_PACKAGE_ASTERISK_APP_NBSCAT=y
FREETZ_PACKAGE_ASTERISK_APP_ORIGINATE=y
FREETZ_PACKAGE_ASTERISK_APP_PAGE=y
FREETZ_PACKAGE_ASTERISK_APP_PARKANDANNOUNCE=y
FREETZ_PACKAGE_ASTERISK_APP_PLAYBACK=y
FREETZ_PACKAGE_ASTERISK_APP_PLAYTONES=y
FREETZ_PACKAGE_ASTERISK_APP_PRIVACY=y
FREETZ_PACKAGE_ASTERISK_APP_QUEUE=y
FREETZ_PACKAGE_ASTERISK_APP_READ=y
FREETZ_PACKAGE_ASTERISK_APP_READEXTEN=y
FREETZ_PACKAGE_ASTERISK_APP_RECORD=y
FREETZ_PACKAGE_ASTERISK_APP_SAYUNIXTIME=y
FREETZ_PACKAGE_ASTERISK_APP_SENDDTMF=y
FREETZ_PACKAGE_ASTERISK_APP_SENDTEXT=y
FREETZ_PACKAGE_ASTERISK_APP_SMS=y
FREETZ_PACKAGE_ASTERISK_APP_SOFTHANGUP=y
FREETZ_PACKAGE_ASTERISK_APP_SPEECH_UTILS=y
FREETZ_PACKAGE_ASTERISK_APP_STACK=y
FREETZ_PACKAGE_ASTERISK_APP_SYSTEM=y
FREETZ_PACKAGE_ASTERISK_APP_TALKDETECT=y
FREETZ_PACKAGE_ASTERISK_APP_TEST=y
FREETZ_PACKAGE_ASTERISK_APP_TRANSFER=y
FREETZ_PACKAGE_ASTERISK_APP_URL=y
FREETZ_PACKAGE_ASTERISK_APP_USEREVENT=y
FREETZ_PACKAGE_ASTERISK_APP_VERBOSE=y
FREETZ_PACKAGE_ASTERISK_APP_VOICEMAIL=y
FREETZ_PACKAGE_ASTERISK_APP_WAITFORRING=y
FREETZ_PACKAGE_ASTERISK_APP_WAITFORSILENCE=y
FREETZ_PACKAGE_ASTERISK_APP_WAITUNTIL=y
FREETZ_PACKAGE_ASTERISK_APP_WHILE=y
FREETZ_PACKAGE_ASTERISK_APP_ZAPATELLER=y
# Bridging Modules
FREETZ_PACKAGE_ASTERISK_BRIDGE_BUILTIN_FEATURES=y
FREETZ_PACKAGE_ASTERISK_BRIDGE_MULTIPLEXED=y
FREETZ_PACKAGE_ASTERISK_BRIDGE_SIMPLE=y
FREETZ_PACKAGE_ASTERISK_BRIDGE_SOFTMIX=y
# Call Detail Recording
FREETZ_PACKAGE_ASTERISK_CDR_CSV=y
FREETZ_PACKAGE_ASTERISK_CDR_CUSTOM=y
FREETZ_PACKAGE_ASTERISK_CDR_MANAGER=y
FREETZ_PACKAGE_ASTERISK_CDR_SQLITE3_CUSTOM=y
FREETZ_PACKAGE_ASTERISK_CDR_SYSLOG=y
# Channel Event Logging
FREETZ_PACKAGE_ASTERISK_CEL_CUSTOM=y
FREETZ_PACKAGE_ASTERISK_CEL_MANAGER=y
FREETZ_PACKAGE_ASTERISK_CEL_SQLITE3_CUSTOM=y
# Channel Drivers
FREETZ_PACKAGE_ASTERISK_CHAN_AGENT=y
FREETZ_PACKAGE_ASTERISK_CHAN_BRIDGE=y
FREETZ_PACKAGE_ASTERISK_CHAN_IAX2=y
FREETZ_PACKAGE_ASTERISK_CHAN_LOCAL=y
FREETZ_PACKAGE_ASTERISK_CHAN_MGCP=y
FREETZ_PACKAGE_ASTERISK_CHAN_MOTIF=y
FREETZ_PACKAGE_ASTERISK_CHAN_MULTICAST_RTP=y
FREETZ_PACKAGE_ASTERISK_CHAN_PHONE=y
FREETZ_PACKAGE_ASTERISK_CHAN_SIP=y
FREETZ_PACKAGE_ASTERISK_CHAN_SKINNY=y
FREETZ_PACKAGE_ASTERISK_CHAN_UNISTIM=y
# Codec Translators
FREETZ_PACKAGE_ASTERISK_CODEC_A_MU=y
FREETZ_PACKAGE_ASTERISK_CODEC_ADPCM=y
FREETZ_PACKAGE_ASTERISK_CODEC_ALAW=y
FREETZ_PACKAGE_ASTERISK_CODEC_G722=y
FREETZ_PACKAGE_ASTERISK_CODEC_G726=y
FREETZ_PACKAGE_ASTERISK_CODEC_GSM=y
FREETZ_PACKAGE_ASTERISK_CODEC_ILBC=y
FREETZ_PACKAGE_ASTERISK_CODEC_LPC10=y
FREETZ_PACKAGE_ASTERISK_CODEC_RESAMPLE=y
FREETZ_PACKAGE_ASTERISK_CODEC_SPEEX=y
FREETZ_PACKAGE_ASTERISK_CODEC_ULAW=y
# Format Interpreters
FREETZ_PACKAGE_ASTERISK_FORMAT_G719=y
FREETZ_PACKAGE_ASTERISK_FORMAT_G723=y
FREETZ_PACKAGE_ASTERISK_FORMAT_G726=y
FREETZ_PACKAGE_ASTERISK_FORMAT_G729=y
FREETZ_PACKAGE_ASTERISK_FORMAT_GSM=y
FREETZ_PACKAGE_ASTERISK_FORMAT_H263=y
FREETZ_PACKAGE_ASTERISK_FORMAT_H264=y
FREETZ_PACKAGE_ASTERISK_FORMAT_ILBC=y
FREETZ_PACKAGE_ASTERISK_FORMAT_JPEG=y
FREETZ_PACKAGE_ASTERISK_FORMAT_PCM=y
FREETZ_PACKAGE_ASTERISK_FORMAT_SIREN14=y
FREETZ_PACKAGE_ASTERISK_FORMAT_SIREN7=y
FREETZ_PACKAGE_ASTERISK_FORMAT_SLN=y
FREETZ_PACKAGE_ASTERISK_FORMAT_VOX=y
FREETZ_PACKAGE_ASTERISK_FORMAT_WAV=y
FREETZ_PACKAGE_ASTERISK_FORMAT_WAV_GSM=y
# Dialplan Functions
FREETZ_PACKAGE_ASTERISK_FUNC_AES=y
FREETZ_PACKAGE_ASTERISK_FUNC_AUDIOHOOKINHERIT=y
FREETZ_PACKAGE_ASTERISK_FUNC_BASE64=y
FREETZ_PACKAGE_ASTERISK_FUNC_BLACKLIST=y
FREETZ_PACKAGE_ASTERISK_FUNC_CALLCOMPLETION=y
FREETZ_PACKAGE_ASTERISK_FUNC_CALLERID=y
FREETZ_PACKAGE_ASTERISK_FUNC_CDR=y
FREETZ_PACKAGE_ASTERISK_FUNC_CHANNEL=y
FREETZ_PACKAGE_ASTERISK_FUNC_CONFIG=y
FREETZ_PACKAGE_ASTERISK_FUNC_CURL=y
FREETZ_PACKAGE_ASTERISK_FUNC_CUT=y
FREETZ_PACKAGE_ASTERISK_FUNC_DB=y
FREETZ_PACKAGE_ASTERISK_FUNC_DEVSTATE=y
FREETZ_PACKAGE_ASTERISK_FUNC_DIALGROUP=y
FREETZ_PACKAGE_ASTERISK_FUNC_DIALPLAN=y
FREETZ_PACKAGE_ASTERISK_FUNC_ENUM=y
FREETZ_PACKAGE_ASTERISK_FUNC_ENV=y
FREETZ_PACKAGE_ASTERISK_FUNC_EXTSTATE=y
FREETZ_PACKAGE_ASTERISK_FUNC_FRAME_TRACE=y
FREETZ_PACKAGE_ASTERISK_FUNC_GLOBAL=y
FREETZ_PACKAGE_ASTERISK_FUNC_GROUPCOUNT=y
FREETZ_PACKAGE_ASTERISK_FUNC_HANGUPCAUSE=y
FREETZ_PACKAGE_ASTERISK_FUNC_ICONV=y
FREETZ_PACKAGE_ASTERISK_FUNC_JITTERBUFFER=y
FREETZ_PACKAGE_ASTERISK_FUNC_LOCK=y
FREETZ_PACKAGE_ASTERISK_FUNC_LOGIC=y
FREETZ_PACKAGE_ASTERISK_FUNC_MATH=y
FREETZ_PACKAGE_ASTERISK_FUNC_MD5=y
FREETZ_PACKAGE_ASTERISK_FUNC_MODULE=y
FREETZ_PACKAGE_ASTERISK_FUNC_PITCHSHIFT=y
FREETZ_PACKAGE_ASTERISK_FUNC_PRESENCESTATE=y
FREETZ_PACKAGE_ASTERISK_FUNC_RAND=y
FREETZ_PACKAGE_ASTERISK_FUNC_REALTIME=y
FREETZ_PACKAGE_ASTERISK_FUNC_SHA1=y
FREETZ_PACKAGE_ASTERISK_FUNC_SHELL=y
FREETZ_PACKAGE_ASTERISK_FUNC_SPEEX=y
FREETZ_PACKAGE_ASTERISK_FUNC_SPRINTF=y
FREETZ_PACKAGE_ASTERISK_FUNC_SRV=y
FREETZ_PACKAGE_ASTERISK_FUNC_STRINGS=y
FREETZ_PACKAGE_ASTERISK_FUNC_SYSINFO=y
FREETZ_PACKAGE_ASTERISK_FUNC_TIMEOUT=y
FREETZ_PACKAGE_ASTERISK_FUNC_URI=y
FREETZ_PACKAGE_ASTERISK_FUNC_VERSION=y
FREETZ_PACKAGE_ASTERISK_FUNC_VMCOUNT=y
FREETZ_PACKAGE_ASTERISK_FUNC_VOLUME=y
# PBX Modules
FREETZ_PACKAGE_ASTERISK_PBX_AEL=y
FREETZ_PACKAGE_ASTERISK_PBX_CONFIG=y
FREETZ_PACKAGE_ASTERISK_PBX_DUNDI=y
FREETZ_PACKAGE_ASTERISK_PBX_LOOPBACK=y
FREETZ_PACKAGE_ASTERISK_PBX_REALTIME=y
FREETZ_PACKAGE_ASTERISK_PBX_SPOOL=y
# Resource Modules
FREETZ_PACKAGE_ASTERISK_RES_ADSI=y
FREETZ_PACKAGE_ASTERISK_RES_AEL_SHARE=y
FREETZ_PACKAGE_ASTERISK_RES_AGI=y
FREETZ_PACKAGE_ASTERISK_RES_CALENDAR=y
FREETZ_PACKAGE_ASTERISK_RES_CLIALIASES=y
FREETZ_PACKAGE_ASTERISK_RES_CLIORIGINATE=y
FREETZ_PACKAGE_ASTERISK_RES_CONFIG_CURL=y
FREETZ_PACKAGE_ASTERISK_RES_CONFIG_SQLITE3=y
FREETZ_PACKAGE_ASTERISK_RES_CONVERT=y
FREETZ_PACKAGE_ASTERISK_RES_CRYPTO=y
FREETZ_PACKAGE_ASTERISK_RES_CURL=y
FREETZ_PACKAGE_ASTERISK_RES_FAX=y
FREETZ_PACKAGE_ASTERISK_RES_FAX_SPANDSP=y
FREETZ_PACKAGE_ASTERISK_RES_FORMAT_ATTR_CELT=y
FREETZ_PACKAGE_ASTERISK_RES_FORMAT_ATTR_H263=y
FREETZ_PACKAGE_ASTERISK_RES_FORMAT_ATTR_H264=y
FREETZ_PACKAGE_ASTERISK_RES_FORMAT_ATTR_SILK=y
FREETZ_PACKAGE_ASTERISK_RES_HTTP_WEBSOCKET=y
FREETZ_PACKAGE_ASTERISK_RES_LIMIT=y
FREETZ_PACKAGE_ASTERISK_RES_MONITOR=y
FREETZ_PACKAGE_ASTERISK_RES_MUSICONHOLD=y
FREETZ_PACKAGE_ASTERISK_RES_MUTESTREAM=y
FREETZ_PACKAGE_ASTERISK_RES_PHONEPROV=y
FREETZ_PACKAGE_ASTERISK_RES_PKTCCOPS=y
FREETZ_PACKAGE_ASTERISK_RES_REALTIME=y
FREETZ_PACKAGE_ASTERISK_RES_RTP_ASTERISK=y
FREETZ_PACKAGE_ASTERISK_RES_RTP_MULTICAST=y
FREETZ_PACKAGE_ASTERISK_RES_SECURITY_LOG=y
FREETZ_PACKAGE_ASTERISK_RES_SMDI=y
FREETZ_PACKAGE_ASTERISK_RES_SPEECH=y
FREETZ_PACKAGE_ASTERISK_RES_SRTP=y
FREETZ_PACKAGE_ASTERISK_RES_STUN_MONITOR=y
FREETZ_PACKAGE_ASTERISK_RES_TIMING_PTHREAD=y
FREETZ_PACKAGE_ASTERISK_RES_XMPP=y
# FREETZ_PACKAGE_ASTERISK_WITH_ALSA is not set
# FREETZ_PACKAGE_ASTERISK_WITH_BLUETOOTH is not set
# FREETZ_PACKAGE_ASTERISK_WITH_COROSYNC is not set
FREETZ_PACKAGE_ASTERISK_WITH_CRYPTO=y
FREETZ_PACKAGE_ASTERISK_WITH_CURL=y
# FREETZ_PACKAGE_ASTERISK_WITH_DAHDI is not set
# FREETZ_PACKAGE_ASTERISK_WITH_FREETDS is not set
# FREETZ_PACKAGE_ASTERISK_WITH_GENERIC_ODBC is not set
# FREETZ_PACKAGE_ASTERISK_WITH_GMIME is not set
FREETZ_PACKAGE_ASTERISK_WITH_GSM=y
# FREETZ_PACKAGE_ASTERISK_WITH_ICAL is not set
FREETZ_PACKAGE_ASTERISK_WITH_ICONV=y
FREETZ_PACKAGE_ASTERISK_WITH_IKSEMEL=y
FREETZ_PACKAGE_ASTERISK_WITH_ILBC=y
# FREETZ_PACKAGE_ASTERISK_WITH_ISDNNET is not set
FREETZ_PACKAGE_ASTERISK_WITH_IXJUSER=y
# FREETZ_PACKAGE_ASTERISK_WITH_JACK is not set
# FREETZ_PACKAGE_ASTERISK_WITH_KQUEUE is not set
# FREETZ_PACKAGE_ASTERISK_WITH_LDAP is not set
# FREETZ_PACKAGE_ASTERISK_WITH_LIBXML2 is not set
# FREETZ_PACKAGE_ASTERISK_WITH_LTDL is not set
# FREETZ_PACKAGE_ASTERISK_WITH_LUA is not set
# FREETZ_PACKAGE_ASTERISK_WITH_MISDN is not set
# FREETZ_PACKAGE_ASTERISK_WITH_NBS is not set
# FREETZ_PACKAGE_ASTERISK_WITH_NEON is not set
# FREETZ_PACKAGE_ASTERISK_WITH_NEON29 is not set
# FREETZ_PACKAGE_ASTERISK_WITH_NETSNMP is not set
# FREETZ_PACKAGE_ASTERISK_WITH_OGG is not set
# FREETZ_PACKAGE_ASTERISK_WITH_OPENR2 is not set
FREETZ_PACKAGE_ASTERISK_WITH_OPENSSL=y
# FREETZ_PACKAGE_ASTERISK_WITH_OSPTK is not set
# FREETZ_PACKAGE_ASTERISK_WITH_OSS is not set
# FREETZ_PACKAGE_ASTERISK_WITH_PGSQL is not set
FREETZ_PACKAGE_ASTERISK_WITH_PJPROJECT=y
# FREETZ_PACKAGE_ASTERISK_WITH_PORTAUDIO is not set
# FREETZ_PACKAGE_ASTERISK_WITH_PRI is not set
# FREETZ_PACKAGE_ASTERISK_WITH_RADIUS is not set
# FREETZ_PACKAGE_ASTERISK_WITH_RESAMPLE is not set
FREETZ_PACKAGE_ASTERISK_WITH_SPANDSP=y
FREETZ_PACKAGE_ASTERISK_WITH_SPEEX=y
FREETZ_PACKAGE_ASTERISK_WITH_SPEEXDSP=y
FREETZ_PACKAGE_ASTERISK_WITH_SPEEX_PREPROCESS=y
# FREETZ_PACKAGE_ASTERISK_WITH_SQLITE is not set
FREETZ_PACKAGE_ASTERISK_WITH_SQLITE3=y
FREETZ_PACKAGE_ASTERISK_WITH_SRTP=y
# FREETZ_PACKAGE_ASTERISK_WITH_SS7 is not set
# FREETZ_PACKAGE_ASTERISK_WITH_SUPPSERV is not set
FREETZ_PACKAGE_ASTERISK_WITH_SYSLOG=y
# FREETZ_PACKAGE_ASTERISK_WITH_TIMERFD is not set
# FREETZ_PACKAGE_ASTERISK_WITH_TONEZONE is not set
# FREETZ_PACKAGE_ASTERISK_WITH_VORBIS is not set
FREETZ_PACKAGE_ASTERISK_WITH_ZLIB=y
# Asterisk 3rd-party modules
FREETZ_PACKAGE_ASTERISK_CHAN_CAPI=y
FREETZ_PACKAGE_ASTERISK_CHAN_DONGLE=y
FREETZ_PACKAGE_ASTERISK_CHAN_SCCP=y
FREETZ_PACKAGE_COLLECTD=y
# plugins
FREETZ_PACKAGE_COLLECTD_PLUGIN_apache=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_contextswitch=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_cpu=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_csv=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_df=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_disk=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_entropy=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_exec=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_fritzbox=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_interface=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_irq=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_load=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_memory=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_network=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_ping=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_rrdtool=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_syslog=y
FREETZ_PACKAGE_COLLECTD_PLUGIN_uptime=y
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC=y
# Misc
FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH=y
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY=y
FREETZ_PACKAGE_DTMFBOX_CGI=y
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
FREETZ_PACKAGE_IPTABLES_CGI=y
FREETZ_PACKAGE_NHIPT=y
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
# FREETZ_MODULE_nf_conntrack is not set
# FREETZ_MODULE_nf_conntrack_ftp is not set
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
# FREETZ_MODULE_nf_conntrack_ipv4 is not set
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
# FREETZ_MODULE_nf_conntrack_tftp is not set
# FREETZ_MODULE_nf_defrag_ipv4 is not set
# FREETZ_MODULE_nf_nat is not set
# FREETZ_MODULE_nf_nat_ftp is not set
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
# FREETZ_MODULE_nf_nat_tftp is not set
FREETZ_MODULE_iptable_filter=y
# FREETZ_MODULE_iptable_mangle is not set
# FREETZ_MODULE_iptable_nat is not set
# FREETZ_MODULE_iptable_raw is not set
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
# FREETZ_MODULE_ipt_ttl is not set
# FREETZ_MODULE_ipt_TTL is not set
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
# FREETZ_MODULE_xt_NFQUEUE is not set
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
# FREETZ_MODULE_xt_statistic is not set
# FREETZ_MODULE_xt_string is not set
FREETZ_MODULE_xt_tcpudp=y
# FREETZ_MODULE_xt_tcpmss is not set
# FREETZ_MODULE_xt_time is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
# FREETZ_LIB_libipt_SAME is not set
FREETZ_LIB_libipt_SNAT=y
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
FREETZ_LIB_libipt_ULOG=y
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
# FREETZ_LIB_libxt_comment is not set
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
# FREETZ_LIB_libxt_statistic is not set
# FREETZ_LIB_libxt_string is not set
# FREETZ_LIB_libxt_tcpmss is not set
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
# FREETZ_LIB_libxt_time is not set
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
FREETZ_PACKAGE_MINI_FO=y
FREETZ_PACKAGE_MINI_FO_JFFS2=y
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
FREETZ_PACKAGE_SQUID=y
# FREETZ_PACKAGE_TRUECRYPT is not set
FREETZ_PACKAGE_VIRTUALIP_CGI=y
FREETZ_PACKAGE_ZABBIX=y
FREETZ_PACKAGE_ZABBIX_agentd=y
FREETZ_PACKAGE_ZABBIX_server=y
FREETZ_PACKAGE_ZABBIX_proxy=y
FREETZ_PACKAGE_ZABBIX_sender=y
FREETZ_PACKAGE_ZABBIX_get=y
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
# FREETZ_PACKAGE_AVM_FORWARDING is not set
FREETZ_PACKAGE_DNSD_CGI=y
FREETZ_PACKAGE_DOWNLOADER=y
FREETZ_PACKAGE_NFSD_CGI=y
FREETZ_PACKAGE_ONLINECHANGED_CGI=y
FREETZ_PACKAGE_OPENVPN_V2_CGI=y
FREETZ_PACKAGE_PHPXMAIL=y
FREETZ_PACKAGE_PPP_CGI=y
FREETZ_PACKAGE_PPP_CGI_COMGT=y
FREETZ_PACKAGE_RRDSTATS=y
FREETZ_PACKAGE_RRDSTATS_CABLEMODEM=y
FREETZ_PACKAGE_RRDSTATS_CABLEMODEM_WGET=y
FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD=y
FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD_SUNDTEK=y
FREETZ_PACKAGE_RRDSTATS_STORAGE=y
FREETZ_PACKAGE_RRDSTATS_NETWORK=y
FREETZ_PACKAGE_RRDSTATS_DIGITEMP=y
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_TRANSMISSION_CGI=y
FREETZ_PACKAGE_VNSTAT_CGI=y
FREETZ_PACKAGE_WOL_CGI=y
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
FREETZ_LIB_STDCXXLIB=y
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
FREETZ_LIB_libstdc__=y
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
FREETZ_LIB_libgpg_error=y
FREETZ_LIB_libgcrypt=y
# Configuration
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
FREETZ_LIB_libgcrypt_WITH_DIGEST_md5=y
FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160=y
FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1=y
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes=y
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa=y
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
FREETZ_LIB_libmatrixssl=y
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
# FREETZ_OPENSSL_VERSION_0 is not set
FREETZ_OPENSSL_VERSION_1=y
FREETZ_OPENSSL_SHLIB_VERSION="1.0.0"
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
FREETZ_LIB_libdb=y
FREETZ_LIB_libsqlite3=y
# File systems
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
FREETZ_LIB_libglib_2=y
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libexif is not set
FREETZ_LIB_libjpeg=y
FREETZ_LIB_liblept=y
FREETZ_LIB_libpng12=y
FREETZ_LIB_libgd=y
# FREETZ_LIB_libopenjpeg is not set
FREETZ_LIB_libtesseract=y
FREETZ_LIB_libtiff=y
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
FREETZ_LIB_libgmp=y
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
FREETZ_LIB_libmad=y
FREETZ_LIB_libogg=y
# FREETZ_LIB_libopus is not set
FREETZ_LIB_libspeex=y
FREETZ_LIB_libspeexdsp=y
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
FREETZ_LIB_libvorbis=y
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
FREETZ_LIB_libid3tag=y
# FREETZ_LIB_libtag is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUS256color=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
FREETZ_LIB_libpanel=y
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
FREETZ_LIB_libcapi20=y
# Misc networking ------------------------
FREETZ_LIB_libdnet=y
FREETZ_LIB_libgsm=y
FREETZ_LIB_libiksemel=y
FREETZ_LIB_libpcap=y
# FREETZ_LIB_libnet is not set
FREETZ_LIB_liboping=y
FREETZ_LIB_libosip2=y
FREETZ_LIB_libosipparser2=y
FREETZ_LIB_libspandsp=y
FREETZ_LIB_libsrtp=y
# PJ Project
FREETZ_PJPROJECT2=y
FREETZ_LIB_libpj=y
FREETZ_LIB_libpjlib_util=y
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
FREETZ_LIB_libpjnath=y
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
FREETZ_LIB_libreadline=y
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
FREETZ_LIB_libpcreposix=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
FREETZ_LIB_libthread_db=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
FREETZ_LIB_libusb_1=y
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
FREETZ_LIB_libcurl=y
FREETZ_LIB_libcurl_WITH_SSL=y
# FREETZ_LIB_libcurl_WITH_CYASSL is not set
FREETZ_LIB_libcurl_WITH_OPENSSL=y
# FREETZ_LIB_libcurl_WITH_POLARSSL is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
FREETZ_LIB_libjs=y
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
FREETZ_LIB_libexpat=y
FREETZ_LIB_libxml2=y
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libconfig=y
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libelf=y
FREETZ_LIB_libev=y
FREETZ_LIB_libevent=y
FREETZ_LIB_libffi=y
FREETZ_LIB_libctlmgr=y
FREETZ_LIB_libmultid=y
FREETZ_LIB_libmultid_WITH_ANYIP=y
FREETZ_LIB_libmultid_WITH_DNS=y
FREETZ_LIB_libmultid_WITH_DHCP=y
FREETZ_LIB_libmultid_WITH_LLMNR=y
FREETZ_LIB_libltdl=y
FREETZ_LIB_liblua=y
# FREETZ_LIB_libpcsclite is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_libpython2=y
FREETZ_LIB_librrd=y
FREETZ_LIB_librrd_th=y
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
FREETZ_LIB_libsysfs=y
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
FREETZ_KERNEL_VERSION_2_6_32_60=y
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_VR9=y
FREETZ_KERNEL_LAYOUT="vr9"
FREETZ_MODULES_KVER="2.6.32.60"
FREETZ_KERNEL_PATCHES="${FREETZ_MODULES_KVER}"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
FREETZ_MODULE_crypto_algapi=y
# FREETZ_MODULE_crypto_blkcipher is not set
FREETZ_MODULE_crypto_hash=y
FREETZ_MODULE_arc4=y
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
FREETZ_MODULE_sha1_generic=y
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
FREETZ_MODULE_ppp_async=y
FREETZ_MODULE_ppp_deflate=y
FREETZ_MODULE_ppp_generic=y
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
FREETZ_MODULE_ppp_mppe_mppc=y
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
FREETZ_MODULE_slhc=y
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
FREETZ_MODULE_usbip=y
FREETZ_MODULE_usbip_common_mod=y
FREETZ_MODULE_usbserial=y
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_btusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
FREETZ_MODULE_option=y
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext2=y
FREETZ_MODULE_ext4=y
# FREETZ_MODULE_fat is not set
FREETZ_MODULE_hfs=y
FREETZ_MODULE_hfsplus=y
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
FREETZ_MODULE_jbd2=y
FREETZ_MODULE_lockd=y
FREETZ_MODULE_mini_fo=y
# FREETZ_MODULE_minix is not set
FREETZ_MODULE_nfsd=y
FREETZ_MODULE_exportfs=y
FREETZ_MODULE_nfs=y
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
FREETZ_MODULE_nls_utf8=y
FREETZ_MODULE_reiserfs=y
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
FREETZ_MODULE_jffs2=y
FREETZ_MODULE_mbcache=y
# lib
FREETZ_MODULE_crc16=y
FREETZ_MODULE_crc_ccitt=y
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
FREETZ_MODULE_sunrpc=y
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
FREETZ_BUSYBOX_FEATURE_UTMP=y
FREETZ_BUSYBOX_FEATURE_WTMP=y
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_BUNZIP2=y
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
# FREETZ_BUSYBOX_FEATURE_TOUCH_NODEREF is not set
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_BASE64 is not set
FREETZ_BUSYBOX_WHO=y
# FREETZ_BUSYBOX_USERS is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
# FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
FREETZ_BUSYBOX_UUENCODE=y
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_FANCY=y
FREETZ_BUSYBOX_WHICH=y
# Editors
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_FEATURE_AWK_GNU_EXTENSIONS is not set
FREETZ_BUSYBOX_CMP=y
FREETZ_BUSYBOX_DIFF=y
# FREETZ_BUSYBOX_FEATURE_DIFF_DIR is not set
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_PATCH=y
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_FSTRIM is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_F2FS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_RFKILL is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
FREETZ_BUSYBOX_UBIMKVOL=y
FREETZ_BUSYBOX_UBIRMVOL=y
FREETZ_BUSYBOX_UBIRSVOL=y
FREETZ_BUSYBOX_UBIUPDATEVOL=y
# FREETZ_BUSYBOX_WALL is not set
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
FREETZ_BUSYBOX_LAST=y
# FREETZ_BUSYBOX_FEATURE_LAST_SMALL is not set
FREETZ_BUSYBOX_FEATURE_LAST_FANCY=y
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RUNLEVEL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
# FREETZ_BUSYBOX_NC_SERVER is not set
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
FREETZ_BUSYBOX_DNSD=y
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
# FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS is not set
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
FREETZ_BUSYBOX_TELNET=y
# FREETZ_BUSYBOX_FEATURE_TELNET_TTYPE is not set
# FREETZ_BUSYBOX_FEATURE_TELNET_AUTOLOGIN is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
# FREETZ_BUSYBOX_FEATURE_TFTP_GET is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_PUT is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
# FREETZ_BUSYBOX_LSOF is not set
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
# FREETZ_BUSYBOX_FEATURE_UPTIME_UTMP_SUPPORT is not set
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
EXTERNAL_ENABLED=y
# EXTERNAL_DOWNLOADER is not set
EXTERNAL_SUBDIRS=y
EXTERNAL_LINKS=y
EXTERNAL_DYNAMIC=y
EXTERNAL_DYNAMIC_SCRIPTS=y
EXTERNAL_CREATEPAK=y
# EXTERNAL_CREATEPAK_DYNAMIC is not set
EXTERNAL_OWN_FILES=""
# packages
# EXTERNAL_FREETZ_PACKAGE_GDB_GDB is not set
# EXTERNAL_FREETZ_PACKAGE_GDB_GDBSERVER is not set
EXTERNAL_FREETZ_PACKAGE_INOTIFY_TOOLS=y
EXTERNAL_FREETZ_PACKAGE_LDD=y
EXTERNAL_FREETZ_PACKAGE_LTRACE=y
EXTERNAL_FREETZ_PACKAGE_STRACE=y
# EXTERNAL_FREETZ_PACKAGE_USBUTILS is not set
EXTERNAL_FREETZ_PACKAGE_COMGT=y
EXTERNAL_FREETZ_PACKAGE_CURL=y
EXTERNAL_FREETZ_PACKAGE_DIGITEMP=y
EXTERNAL_FREETZ_PACKAGE_DNS2TCP=y
# EXTERNAL_FREETZ_PACKAGE_DROPBEAR is not set
# EXTERNAL_FREETZ_PACKAGE_E2FSPROGS is not set
EXTERNAL_FREETZ_PACKAGE_EMAILRELAY=y
EXTERNAL_FREETZ_PACKAGE_ESPEAK=y
EXTERNAL_FREETZ_PACKAGE_HTML2TEXT=y
EXTERNAL_FREETZ_PACKAGE_HTOP=y
EXTERNAL_FREETZ_PACKAGE_HTTPRY=y
EXTERNAL_FREETZ_PACKAGE_HTTPTUNNEL=y
EXTERNAL_FREETZ_PACKAGE_IFSTAT=y
EXTERNAL_FREETZ_PACKAGE_IFTOP=y
EXTERNAL_FREETZ_PACKAGE_IGMPPROXY=y
EXTERNAL_FREETZ_PACKAGE_IODINE=y
EXTERNAL_FREETZ_PACKAGE_IPTRAF=y
EXTERNAL_FREETZ_PACKAGE_IPTRAF_RVNAMED=y
EXTERNAL_FREETZ_PACKAGE_JS=y
EXTERNAL_FREETZ_PACKAGE_KNOCK=y
EXTERNAL_FREETZ_PACKAGE_MADPLAY=y
EXTERNAL_FREETZ_PACKAGE_MC=y
EXTERNAL_FREETZ_PACKAGE_MICROPERL=y
EXTERNAL_FREETZ_PACKAGE_MTR=y
EXTERNAL_FREETZ_PACKAGE_NANO=y
EXTERNAL_FREETZ_PACKAGE_NC6=y
EXTERNAL_FREETZ_PACKAGE_NETCAT=y
EXTERNAL_FREETZ_PACKAGE_NMAP=y
EXTERNAL_FREETZ_PACKAGE_OIDENTD=y
# EXTERNAL_FREETZ_PACKAGE_OPENDD is not set
# EXTERNAL_FREETZ_PACKAGE_OPENSSH is not set
# EXTERNAL_FREETZ_PACKAGE_OPENSSL is not set
# EXTERNAL_FREETZ_PACKAGE_OPENVPN is not set
EXTERNAL_FREETZ_PACKAGE_PHP=y
EXTERNAL_FREETZ_PACKAGE_PINGTUNNEL=y
EXTERNAL_FREETZ_PACKAGE_POLIPO=y
# EXTERNAL_FREETZ_PACKAGE_PPPD is not set
# EXTERNAL_FREETZ_PACKAGE_PPPD_CHAT is not set
# EXTERNAL_FREETZ_PACKAGE_PPTP is not set
# EXTERNAL_FREETZ_PACKAGE_PPTPD is not set
EXTERNAL_FREETZ_PACKAGE_PRIVOXY=y
EXTERNAL_FREETZ_PACKAGE_PYLOAD=y
EXTERNAL_FREETZ_PACKAGE_PYTHON=y
EXTERNAL_FREETZ_PACKAGE_RRDTOOL=y
EXTERNAL_FREETZ_PACKAGE_SCREEN=y
EXTERNAL_FREETZ_PACKAGE_SHELLINABOX=y
EXTERNAL_FREETZ_PACKAGE_SIPROXD=y
EXTERNAL_FREETZ_PACKAGE_SMSTOOLS3=y
EXTERNAL_FREETZ_PACKAGE_SOCAT=y
# EXTERNAL_FREETZ_PACKAGE_SSLH is not set
EXTERNAL_FREETZ_PACKAGE_STREAMRIPPER=y
EXTERNAL_FREETZ_PACKAGE_STUNNEL=y
EXTERNAL_FREETZ_PACKAGE_TCPDUMP=y
EXTERNAL_FREETZ_PACKAGE_TCPPROXY=y
EXTERNAL_FREETZ_PACKAGE_TCP_WRAPPERS=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT=y
# tesseract
EXTERNAL_FREETZ_PACKAGE_TESSERACT_tesseract=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_ambiguous_words=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_classifier_tester=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_cntraining=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_combine_tessdata=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_dawg2wordlist=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_mftraining=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_shapeclustering=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_unicharset_extractor=y
EXTERNAL_FREETZ_PACKAGE_TESSERACT_wordlist2dawg=y
EXTERNAL_FREETZ_PACKAGE_TIFF=y
EXTERNAL_FREETZ_PACKAGE_TINC=y
EXTERNAL_FREETZ_PACKAGE_TINYPROXY=y
# EXTERNAL_FREETZ_PACKAGE_TOR is not set
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION=y
# transmission
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_CREATE=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_EDIT=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_SHOW=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
EXTERNAL_FREETZ_PACKAGE_UNRAR=y
# EXTERNAL_FREETZ_PACKAGE_USBIP is not set
EXTERNAL_FREETZ_PACKAGE_VIM=y
EXTERNAL_FREETZ_PACKAGE_VNSTAT=y
EXTERNAL_FREETZ_PACKAGE_VNSTAT_DAEMON=y
EXTERNAL_FREETZ_PACKAGE_VNSTAT_IMAGE=y
# EXTERNAL_FREETZ_PACKAGE_WGET is not set
EXTERNAL_FREETZ_PACKAGE_WOL=y
EXTERNAL_FREETZ_PACKAGE_XMAIL=y
EXTERNAL_FREETZ_PACKAGE_ASTERISK=y
EXTERNAL_FREETZ_PACKAGE_COLLECTD=y
EXTERNAL_FREETZ_PACKAGE_DTMFBOX=y
EXTERNAL_FREETZ_PACKAGE_SQUID=y
EXTERNAL_FREETZ_PACKAGE_PPP_CGI=y
# libraries
# EXTERNAL_FREETZ_LIB_libart_lgpl_2 is not set
# EXTERNAL_FREETZ_LIB_libconfig is not set
# EXTERNAL_FREETZ_LIB_libcrypto is not set
# EXTERNAL_FREETZ_LIB_libssl is not set
# EXTERNAL_FREETZ_LIB_libcurl is not set
# EXTERNAL_FREETZ_LIB_libcapi20 is not set
# EXTERNAL_FREETZ_LIB_libdb is not set
# EXTERNAL_FREETZ_LIB_libdnet is not set
# EXTERNAL_FREETZ_LIB_libelf is not set
# EXTERNAL_FREETZ_LIB_libev is not set
# EXTERNAL_FREETZ_LIB_libevent is not set
# EXTERNAL_FREETZ_LIB_libexpat is not set
# EXTERNAL_FREETZ_LIB_libffi is not set
# EXTERNAL_FREETZ_LIB_libncurses is not set
# EXTERNAL_FREETZ_LIB_libpanel is not set
# EXTERNAL_FREETZ_LIB_libfreetype is not set
# EXTERNAL_FREETZ_LIB_libgcrypt is not set
# EXTERNAL_FREETZ_LIB_libgd is not set
# EXTERNAL_FREETZ_LIB_libglib_2 is not set
# EXTERNAL_FREETZ_LIB_libgmp is not set
# EXTERNAL_FREETZ_LIB_libgpg_error is not set
# EXTERNAL_FREETZ_LIB_libgsm is not set
# EXTERNAL_FREETZ_LIB_libreadline is not set
# EXTERNAL_FREETZ_LIB_libid3tag is not set
# EXTERNAL_FREETZ_LIB_libiksemel is not set
# EXTERNAL_FREETZ_LIB_libjpeg is not set
# EXTERNAL_FREETZ_LIB_libjs is not set
# EXTERNAL_FREETZ_LIB_liblept is not set
# EXTERNAL_FREETZ_LIB_libltdl is not set
# EXTERNAL_FREETZ_LIB_liblzo2 is not set
# EXTERNAL_FREETZ_LIB_libmad is not set
# EXTERNAL_FREETZ_LIB_libmatrixssl is not set
# EXTERNAL_FREETZ_LIB_libogg is not set
# EXTERNAL_FREETZ_LIB_liboping is not set
# EXTERNAL_FREETZ_LIB_libosip2 is not set
# EXTERNAL_FREETZ_LIB_libosipparser2 is not set
# EXTERNAL_FREETZ_LIB_libpj is not set
# EXTERNAL_FREETZ_LIB_libpjlib_util is not set
# EXTERNAL_FREETZ_LIB_libpjnath is not set
# EXTERNAL_FREETZ_LIB_librrd is not set
# EXTERNAL_FREETZ_LIB_librrd_th is not set
# EXTERNAL_FREETZ_LIB_libpcap is not set
# EXTERNAL_FREETZ_LIB_libpcre is not set
# EXTERNAL_FREETZ_LIB_libpcreposix is not set
# EXTERNAL_FREETZ_LIB_libpng12 is not set
# EXTERNAL_FREETZ_LIB_libpython2 is not set
# EXTERNAL_FREETZ_LIB_libspandsp is not set
# EXTERNAL_FREETZ_LIB_libspeex is not set
# EXTERNAL_FREETZ_LIB_libspeexdsp is not set
# EXTERNAL_FREETZ_LIB_libsqlite3 is not set
# EXTERNAL_FREETZ_LIB_libsrtp is not set
# EXTERNAL_FREETZ_LIB_libstdc__ is not set
# EXTERNAL_FREETZ_LIB_libsysfs is not set
# EXTERNAL_FREETZ_LIB_libtesseract is not set
# EXTERNAL_FREETZ_LIB_libtiff is not set
# EXTERNAL_FREETZ_LIB_libusb_1 is not set
# EXTERNAL_FREETZ_LIB_libvorbis is not set
# EXTERNAL_FREETZ_LIB_libxml2 is not set
# EXTERNAL_FREETZ_LIB_libz is not set
# modules
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
FREETZ_SKIN_newfreetz=y
FREETZ_SKIN_phoenix=y
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_CUSTOM_IMAGE_NAME=y
# FREETZ_CUSTOM_IMAGE_NAME_PREFIX is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_32=y
# FREETZ_TARGET_UCLIBC_0_9_33 is not set
# FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
# FREETZ_STDCXXLIB_USE_UCLIBCXX is not set
FREETZ_STDCXXLIB_USE_GNULIBSTDCXX=y
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="libstdcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="4622c6e00b05f6369ed3d777acb57ad2"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="b3d4da39d502edb1efa35930cd612a8c"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="80bab95f103b2ad29e1af07ff0006e20"
FREETZ_DL_SITE="@AVM/beta"
FREETZ_DL_SOURCE="FRITZ.Box_7490_Labor.113.06.02-27324.image"
FREETZ_DL_SOURCE_CONTAINER="fritzbox-labor-7490-27324.zip"
FREETZ_DL_SOURCE_CONTAINER_MD5="5ee01a88920da2265781b4e6500241c7"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_CIFS_SUPPORT_NEEDS_REPLACE_KERNEL=y
FREETZ_CIFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_NEEDS_REPLACE_KERNEL=y
FREETZ_NFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE=y
# FREETZ_AVM_HAS_FW4XX is not set
# FREETZ_AVM_HAS_FW52X is not set
FREETZ_AVM_HAS_FW55X=y
FREETZ_AVM_HAS_FW6XX=y
FREETZ_AVM_HAS_LABOR=y
# FREETZ_AVM_HAS_FWEWE_05_2X is not set
# FREETZ_AVM_HAS_FWEWE_05_5X is not set
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
# FREETZ_AVM_HAS_LANG_EN is not set
# FREETZ_AVM_HAS_LANG_IT is not set
FREETZ_AVM_HAS_AR7CFG_V12_MIN=y
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_PIGLET_ISDN is not set
# FREETZ_AVM_HAS_PIGLET_POTS is not set
FREETZ_AVM_HAS_PTY_SUPPORT=y
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_SOCAT is not set
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE=y
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
# FREETZ_AVM_HAS_JFFS2 is not set
# FREETZ_AVM_HAS_JUNK_BYTES is not set
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_AHA=y
# FREETZ_AVM_HAS_TEMPERATURE_SENSOR is not set
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7490_06_01=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_06_XX_MIN=y
FREETZ_AVM_VERSION_06_XX=y
FREETZ_AVM_VERSION_STRING="7490_06.01"
FREETZ_TYPE_PREFIX="7490"
FREETZ_TYPE_PREFIX_LABOR_FIRMWARE="_labor"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_5X"
Wie komme ich denn hier weiter?
Ursprünglich hatte ich alle PPP-Pakete zur Externalisierung vorgesehen. Nachdem ich die og Fehlermeldung erhielt, nahm ich die PPP-Externalisierung zurück. Die Fehlermeldung bliebt jedoch.
Das klappt auch nicht
freetz@freetz-linux:~/7490/freetz-7490-test$ make ppp-dirclean; make
make: *** Keine Regel, um »ppp-dirclean« zu erstellen. Schluss.
Stimmt, es gibt gar kein Package ppp.
Dann statt dessen "make pppd-clean ppp-cgi-clean; make".
Wenn das nicht funktioniert, deaktiviere mal EXTERNAL_FREETZ_PACKAGE_PPP_CGI, das sind sowieso nur wenige kB und gut komprimierbar.
@xsapling: kommt der Fehler erst seit kurzem oder weißt Du es nicht, weil Du es vor kurzem "ppp" bzw. "external ppp*" ausgewählt hast?
Es gibt in der Tat kein Paket ppp, von daher stellt sich die Frage, wo diese Zeilen herkommen bzw. wodruch verursacht werden (man beachte ppp, obwohl es kein Paket mit dem Namen ppp gibt).
cat: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/.ppp: Datei oder Verzeichnis nicht gefunden
/home/freetz/7490/freetz-7490-test/tools/external: Zeile 53: cd: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/ppp-/root/: Datei oder Verzeichnis nicht gefunden
Also das Problem ist weg, wenn das PPP_CGI nicht externalisiert wird. Aber die Auslagerung von PPPD oder PPPT etc ist mit der zwangsweisen Externalisierung von PPP-CGI verknüpft. D.h. isoliert kann das PPP-CGI nicht nicht externalisiert werden.
Ich kann das Problem mit ppp-cgi un external nachvollziehen:
++ echo ppp
++ '[' '' '!=' y ']'
++ cat build/modified/kernel/var.tar/var/mod/etc/external.pkg
++ '[' y == y ']'
++ for pkg in '$EXTERNAL_SERVICES'
+++ cat ./packages/target-mips_gcc-4.6.4_uClibc-0.9.33.2/.ppp
cat: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.33.2/.ppp: Datei oder Verzeichnis nicht gefunden
++ pkg_ver=ppp-
+++ cd ./packages/target-mips_gcc-4.6.4_uClibc-0.9.33.2/ppp-/root/
/home/oliver/freetz/trunk-test/tools/external: Zeile 53: cd: ./packages/target-mips_gcc-4.6.4_uClibc-0.9.33.2/ppp-/root/: Datei oder Verzeichnis nicht gefunden
+++ find -type f
+++ sed 's|^\.||g'
+++ tr '\n' ' '
--- trunk/make/ppp-cgi/external.services	(revision 11640)
+++ trunk/make/ppp-cgi/external.services	(working copy)
@@ -1 +1 @@
-[ "$EXTERNAL_FREETZ_PACKAGE_PPP_CGI" == "y" ] && EXTERNAL_SERVICES+=" ppp"
+[ "$EXTERNAL_FREETZ_PACKAGE_PPP_CGI" == "y" ] && EXTERNAL_SERVICES+=" ppp-cgi"
also jetzt geht der Bau durch, bei dem alles was mit ppp zu tun hat externalisiert ist.
Aber: Der Platzgewinn beträgt nur 200kb. Sind sämtliche PPP-Pakete in der Summe nicht größer als nur 200kb?
figo12
