freetz-devel-5489: dropbear wird nicht gefunden
ao
Aktives Mitglied
15 Aug 2005
seit dem Update auf freetz-devel-5489 wird dropbear (bzw. irgendwelche keys) nicht mehr gefunden, obwohl es im Image ist (externalisiert, aber die anderen externalisierten Sachen sind da):
Aug 13 06:57:30 fb1 authpriv.warn dropbear[2090]: Failed reading '/mod/etc/ssh/dss_host_key', disabling DSS
Aug 13 06:57:30 fb1 authpriv.info dropbear[2090]: premature exit: No hostkeys available[
/var/log/external.log:
Waiting for mod-startup: ................................done.
### mounting /var/media/ftp/uStor01 @ 13.08.2010 - 06:57,31
dropbear SSH server is started via inetd.
vsftpd is disabled.
Demnach müsste dropbear da sein.
Weshalb die o.g. keys fehlen, verstehe ich überhaupt nicht. Ich habe nichts entfernt.
/var/log/mod.log:
rc.mod version freetz-devel-5489
Starting crond...done.
AVM telnetd is disabled.
Starting Freetz webinterface...done.
swap is disabled.
Starting syslogd...done.
Updating inetd config for dropbear: active.
Updating inetd config for rrdstats (webcfg-one): active.
Updating inetd config for rrdstats (webcfg-rrd): active.
Updating inetd config for telnetd: inactive.
Updating inetd config for vsftpd: inactive.
Updating inetd config for webcfg: inactive.
Updating inetd config for wol: active.
Reloading inetd...not running.
Writing /var/flash/freetz...done.
43520 bytes written.
Starting inetd...done.
Setting up virtual network interface...done.
Setting up SSH authorized_keys for root...done.
dropbear will be started by external.
Starting dnsmasq...already running.
Starting openntpd...done.
Reading AVM's phone book...done.
Starting callmonitor...done.
Starting rrdstats...done.
Starting Serial to Network Proxy...done.
vsftpd will be started by external.
wol webinterface is started via inetd.
/var/log/mod_net.log:
Starting dnsmasq...done.
/var/log/mod_load.log:
Loading /var/flash/freetz...done.
Loading users, groups and passwords...done.
Loading hosts...done.
Loading config...done.
Loading modules...done.
EDIT:
Mache ich jetzt die Pferde scheu? Sorry, dropbear geht jetzt, vielleicht hatte ich zu früh nach dem Box-Neustart das ssh versucht, als die Box etc. noch nicht ganz da war. Und da hat dann evtl. den o.g. Syslog-Eintrag verursacht. Jedenfalls funktioniert ssh 2 Minuten nach dem Reboot. Ich mache noch einmal einen Neustart - ohne ssh zu früh zu versuchen - und schaue noch einmal ins Syslog rein.
Ich denke auch, dass der mit dem Erstellen der Keys noch nicht fertig war. Das dauert etwas und bei inetd scheint die Reihenfolge "Keys erstellen -> dropbear starten" nicht zu greifen.
MfG Oliver
Macht es Sinn, dazu ein Ticket zu eröffnen (ich kenne mich damit nicht so aus)?
Durch die Externalisierung dauert es ggf. auch etwas länger.
Wenn ich den Stick nicht mit "uStor01" labele, was passiert dann mit dem Freetz-automount-Eintrag?
Partitionname (falls vorhanden) als Mountpoint
Präfix für Mountpoints (uStor) : uStor
Wenn ich den Stick also z.B. "external" nenne, soll dann unter "Mountpoint" trotzdem noch "uStor" als Präfix stehen, z.B. damit andere angesteckte USB-Sticks dann "uStor01, uStor02" etc. heißen?
stego88
