Freetz mit 7170 Beta Version 29.04.55-10393
staubsauger-nono
Aktives Mitglied
27 Apr 2005
Hallo, wie immer wenn eine neue Fw herauskommt habe ich versucht sie mit Freetz zu verbessern.
Leider bricht make mit u.a. Fehler ab.
Wie kann ich am besten den Fehler suchen?
Oder hat jemand schon einen fix dafür?
feisty@mash:~/freetz/freetz-trunk$ make
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
  created 3735 files
  created 154 directories
  created 282 symlinks
  created 157 devices
  created 0 fifos
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
  applying patches (7170_beta-de)
    applying patch file ./patches/7170_beta/100-webif.sh
  Applying symlinks, deleting additional webinterfaces
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    Hunk #1 succeeded at 63 (offset -14 lines).
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/120-inittab_console.patch
    patching file etc/inittab
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7170_beta/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7170_beta/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/7170_beta/120-rc.S-dev.patch
    applying patch file ./patches/7170_beta/130-rc.S-logging.patch
    applying patch file ./patches/7170_beta/290-replace_websrv-remove_igdd.patch
    applying patch file ./patches/7170_beta/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/7170_beta/de/190-webmenu.patch
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2.inc
    patching file usr/www/all/html/de/menus/menu2_konfig.html
    applying patch file ./patches/7170_beta/de/200-sperre1.patch
    patching file usr/www/all/html/de/fon/sperre1.js
  creating symlinks /tmp, /mod and /home
  setting subversion 'freetz-devel-1930'
    applying patch file ./patches/100-getcons.sh
  removing /bin/getcons
    applying patch file ./patches/100-profile_term_password.sh
    applying patch file ./patches/100-w701v_7170.sh
    applying patch file ./patches/100-w900v_7170.sh
    applying patch file ./patches/110-uclibc.sh
    applying patch file ./patches/140-tr069_cfg.sh
  patching tr069.cfg
    applying patch file ./patches/150-iptables.sh
    applying patch file ./patches/170-rename_ar7login.sh
  renaming ar7login to make way for wrapper script
    applying patch file ./patches/180-printk.sh
  applying printk patch
    applying patch file ./patches/191-webmenu_wol.sh
  applying wol patch
    applying patch file ./patches/cond/de/webmenu-wol-7170_beta.patch
    applying patch file ./patches/195-webmenu_signed.sh
  applying webmenu signed patch
    applying patch file ./patches/196-usbstorage.sh
  applying USB storage patch
    applying patch file ./patches/cond/usbstorage.patch
    patching file etc/hotplug/run_mount
    Hunk #1 FAILED at 28.
    Hunk #2 FAILED at 51.
    Hunk #3 FAILED at 111.
    3 out of 3 hunks FAILED -- saving rejects to file etc/hotplug/run_mount.rej
ERROR: modpatch: Error in patch-file ./patches/cond/usbstorage.patch
make: *** [firmware-nocompile] Fehler 2
Und noch einer. Bitte Revision und .config!
MfG Oliver
Entschuldige :oops:
Revision 1930
Fixed in r1932.
MfG Oliver
Super,
danke Oliver.
Ich hatte es gerade noch mit der 1931 probiert.
1932 funktioniert. Ich muss mich mit diesen Patchen doch mal etwas näher beschäftigen.
Hi!
Ich würde auch gerne mal den Freetz Mod auf meiner 7170 mit mit FW 29.04.55-10393 ausprobieren und bin gerade dabei mich in Materie einzulesen.
Zwei kurze Fragen:
1. Wie wende ich den erwähnten Patch an? Macht man das in menuconfig Menu irgendwie?
2. Kann man später, wenn diese modifizierte FW auf meiner 7170 läuft ganz normal auf eine neue AVM-Firmware updaten oder muß man zuvor den Freetz Mod wieder deinstallieren?
Hi.
1. Du brauchst keinen Patch einspielen. Im svn ist alles drin und funktioniert.
2. Du kannst ganz normal auf eine AVM-Firmware updaten.
MfG Oliver
vapep43913
