It was very hard to build the Freetz using the german instruction, but I'm sure it's worthwhile!!
But I have a question unresolved, so I try to ask in english.
I have a FRITZ!Box Fon WLAN 7270 Firmware version 54.04.76 English.
I have compiled Freetz in a Vmware ubuntu-server-9.10 machine.
It was a looong porcess, because the stable version fritz-1.1.2 was unable to find some files for the Fritz!Box7270:
ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3270/x_misc/opensrc/GPL-Fritz_Box_3270.tar.gz
does not exists; I tryed modify \freetz-1.1.2\make\avm-gpl\avm-gpl.mk
Line 14: AVM_SOURCE__3270_04.76:=$(AVM_SITE__AVM_3270)/GPL-Fritz_Box_3270.tar.gz
to point to:
ftp://ftp.avm.de/fritz.box/fritzbox...itz_box_wlan_3270_source _files .04.80.tar.gz
but other problems arised, so I decided to get from svn the revision 4409 (http://svn.freetz.org/trunk/) and compile it.
Everythink was ok, I flashed the firmware and after some delay..... pointing my browser to
http://fritz.box
I got the usual login page.
The menu displays correctly, and the Fritzbox displays: Firmware version 54.04.76freetz-devel-4401.
There is a new! menu "Freetz"!! I was very excited, but the corresponding link to
http://fritz.box:81
return only "unable to connect".
I verified that the original link corresponding to the menu "Freetz" is indeed:
http://192.168.178.1/cgi-bin/freetz_status
and send for about 1 second to a page that redirects to http://fritz.box:81
ALL the old features of the fritzbox are normally working...
Do I need to build the Freetz firmware including some features?
(I build a basic version, with only "transmission").
Do I need to do something special?
Is it a bug?
Please help me, I am *so close* to the final!!
to point to:
http://fritz.box
http://fritz.box:81
Is it a bug?
