Fritx 7150 (to 7170) speed-to-fritz with freetz not working.
-=xXx=-
1 Feb 2009
Hello...
Sorry for my english I don't speak german.
I have made speed-to-fritz firmware for my 7150 Annex A (English) and Also wanted to include freetz in it...Selected all options necessary for it.
Now I have 2 problems Answer machine doesn't work from phone menu only by dialling it's nr. and second problem is even if I include freetz I canèt access it on it address fritz.box:81 ...
Maybe someone know solution for this 2 problems.
Thank you.
My image file is: fw_C_7150_38.04.71-14616_Fritz_Box_7170_AnnexA_58.04.84-20124_freetz-9423M_sp2fr-1477-1294_OEM_avme_annexA_en.image
No solution, but a hint: Especially the second point is surely related to "speed-to-fritz". So it might be more successful to ask in the speed-to-fritz section.
Solution
start speed to fritz and the option 7170 on 7150. activate start freetz with the proposed revisionnumber. Then let work speed-to fritz since the advice to start freetz. here say no to all other options. After start the freetz-trunk downloaded from speed-to-fritz. Put all your options what you like und make a firmware. After copy this firmware into Speed-to-fritz/firmware.orig.
Than start speed-to fritz again, same option 7170 on 7150. First firmware source is these that you copied before in Firmware.orig.
Second firmware is the 7170 Annex A you like. In Options (Expert view) only put use DLS Driver from second firmware and let build the new firmware. Works fine here, even with extern option.
WeKraWe59
