Fritz 7270 Fax English Instructions [solved]
stragr
18 Feb 2009
My Friends,
I am very sorry that i am writing in English. I wonder if there is possibility to send fax from my computer connected wirelless to 7270 , through a PSTN line.
If somebody wants to help, it will be very nice for many other users too.
Thank you in advance
stragr
what do you mean, the internal fax-function of the Box or the Software "Fritz!Fax für Fritz!Box"?
For the Software i wrote a Manual qiuck'n'dirty here... ;)
Thank you a lot, i found my mistake. First i had to enable in teh Fritzbox the capi, #96... After the installation i used and the AVM Netcapi, and i changed many from there. Now is working perfectly.
What a machine? The only bad is that software is in German. Can't they translate it? Anyway very good job. I will thow some machines now.
Thank you my friend.
Best regards
stragr
Welcome! :)
Will you please be so kind and put [solved] in the titel of the Theme => 1.Post/Ändern/Erweitert and then fill in the text in the Titel... ;)
PS: This is only a free give-away from AVM, there is another Software package with Fax, but only for the PCI-Card, klick.
So buy a PCI-Card for 10¤ at ebay and will you get the Package. The Application can also be used with the Fritz!Box, however with Support! :)
JSt Aero
