Fritz 7270
vortex1
1 Mrz 2010
hi.
i got a fritz 7270 from ebay. how do i find out which version is it?
i need to change it to international from 1&1.
Hi
If the firwre is the 74.04.xx, you have the 7270v3. If it's the 54.04.xx you have the v2 or v1.
If the serial number is smaller than xxxx.304.00.000.001, ist the 7270v1.
Hi. it has the 54.04.xx, so it is v2 or v1.
How do i change it from german to international to accept pstn as well?
Hi.
i tried the tool and it failed.
is there any other way to change the 7270 v1 to international edition?
Why did it failed ? Is there a message comming or some mistakes ?
What exactly (please describe each step) did you do with the ruKernelTool?
And, please tell us which error message occured (screenshot of the error message).
Which exact firmware version is currently installed on the box (it's shown on the "overview page" in the box's Web-Interface)?
Best regards,
Andi
I think you should youse this won : ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/english/
but please wait on the replay of Andi_84. He is the better one for this question.
Edit: It could be that this version will work on your box, too, but i don't know it right now ( ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270_v1/firmware/deutsch/ )
I would try as follow:
1.) update your Box to the latest Fritzbox Firmeware. It should be te xx.xx.86
2.) then start the ruKernelTool
3.) aktivate the "Expertenansicht"
4.) Then you sholud find a Button on the "Tool"-Page where you can switch the annex-Version
5.) switch the Version and make a reboot after that.
I think it should work. If not you can all times recover the Box with the ruKernelTool.
I am trying to follow the thread, but i cannot find anywhere the link to get the tool and the file as well
Download-Link for the ruKernelTool is here: CLICK.
Credentials (Username and password) for the above link can be found here: CLICK.
@binary_dreamer:
Have you already verified (by looking at the box's serial number) if your box is a 7270_v1 or 7270_v2?
Best regards,
Andi
@Andi_84 Hi, which image should i use with the kernel tool? i do not have a clue how to turn it to english version and annex a, if i use the deutch image.
You did not answer yet the question which version! If it is v1 it is NOT possible to flash it with an international firmware. You can get a v1 work with annex A modifying a German firmware - but there are no means to get an international fw flashed onto a 7270 v1!
As to gismotro's #8: YES - There is a BIG difference between v3 and v1: v3= 16 mb flash memory ---- v1=8 mb
OK, I know the different between the memory. But my question was: Are there different in the Annex-Version.
NAS and Co are not inkluded in V1-Image, but ist Annex A and B also missing or are there both inkluded in the Image ?
Maybe Vortex should first answer two questions:
1. Which version (v1 or v2) is your 7270?
1. Do you need international fw (because of English language) or only annex A - or both?
Look at #5: there he said that it is a V1 and he need the internatinl version
So, I repeat my answer to these requirements given in #15:
".......it is NOT possible to flash it with an international firmware. You can get a v1 work with annex A modifying a German firmware - but there are no means to get an international fw flashed onto a 7270 v1!"
Additionally: Even fw 54.04.86 v1 contains ONLY annex B driver
I do have 7270 with v1.
i would like to have it in english and make it work in annex a.
that's all i am looking for
Yheikjhrya
