FRITZ!Box 7170 Firmware 29.04.67 English
kunio
29 Dez 2008
Hi all,
sorry i cant speek German but i need your help please
i have updated my fritz!box with the latest firmwrae 29.04.67 but it's German language only, i am looking this same firmware but in English???
or how i can get a downgrade to another firmware, example 29.04.57en??
Thanks in advance kunio
Hi kunio!
Please check out this link.
Or this one for recovery.
Joe
... or how i can get a downgrade to another firmware, example 29.04.57en??
Look [post=1251497]here[/post]
Just today I helped nono11 to solve his problem. It was nearly the same as yours.
Good luck!
hi thankyou for your help but dosent work i have this message
Searching FRITZ!Box Fon WLAN 7170 at: 192.168.178.1
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN 7170
Bootstrap: 1136
Firmware: 29.04.67
FRITZ!Box Fon WLAN 7170 firmware is incompatible with the recovery firmware
You can learn german. Then you must not downgrade ;)
i have tested all possibility but i cant downgrade please some one can help me???
@kunio:
In order to help you, we need to know what happens to your FritzBox.
The values of the following environment parameters are of special interest:
- parameter annex (value can be "B" or "A")
- parameter HWRevision (value can be "94" or "127")
- parameter firmware_version (value can be "avm" or "avme")
- parameter kernel_args (value can be "not set" or "annex=A")
These parameter are accessible by using the command "quote GETENV" via ftp / adam2.
Access is possible via telnet, too. Here you need the command "cat /proc/sys/urlader/environment"
Try to find out the present value of these parameters and post them here.
hi, this my info
quote GETENV HWRevision 94.1.0.0
quote GETENV ProductID Fritz_box_7170
quote GETENV annex B
quote GETENV firmware_version avm
quote GETENV firmware_info 24.04.59
quote GETENV bootloaderVersion 1.136
quote GETENV urlader-version 1136
quote GETENV prompt AVM_Ar7
quote GETENV kernel_args annex=B
@kunio:
That looks fine! These values are correct to recover with firmware AnnexB in german.
In order to downgrade to english firmware 24.04.57 you must change the parameter "firmware_version" from "avm" to "avme". This is what the pseudo image "fritz_as_avme_newer.tar" does, too.
If you want AnnexB, don't change any more.
If you want AnnexA, set the parameter "kernel_args" to the value "annex=A"
To change the parameters with ftp / adam2, use the command "quote SETENV".
With the new values, run recovery file "... 24.04.57.en.recover-image.exe"
Good luck!
OK thankyou to ALL finaly it's WORKING yeahhh!!
thanks again
see you later ;)
@all:
Please avoid your fullquotes! Thanks!
i need to change from Annex B to annex A some one can help me please???
... change from Annex B to annex A ...
You already know! (see postings #10 to #13):
Enter ftp/adam2 and set "kernel_args annex=A"
You can do it loading "fritz_as_annex_a_kernel_args_newer.tar", too.
yes i now i have changed but dosen't work i cant upgrade i have same message this firmware is uncompatible...
... i cant upgrade i have same message this firmware is uncompatible ...
Please decribe your problem! You said "finaly it's WORKING yeahhh!!!" - so what is the problem?
If you refer to the error message while upgrading with "fritz_as_annex_a...": Just ignore it and continue! The error message is normal.
i want to change from "annex B to annex A" i am on annex B firmware 29.04.57en
but i want to change annex A firmware 58.04.57en but dosen't work i
My info
quote GETENV firmware_version avme
quote GETENV firmware_info 29.04.57
quote GETENV kernel_args annex=a
