Fritz!Box 7170 reboot loop, recovery
arapax
13 Aug 2012
Hello,
Sorry, my German isn't that good so i rather speak english to make myself clear, i hope this is not a problem. The other day i was playing around with my old 7170 first trying to install OpenWRT on it, without succes and flashed it back to the orignal firmware using adam ftp and i could acces the original firmware again.
Somehow after repeating the procure a few times with different builds of OpenWRT i must have accidently touched something essential and now the modem starts booting, but after a while it shuts down a reboots again. My guess is that mtd3 and/or mtd4 are damaged. I hooked up a serial cable this is the printenv output:
Eva_AVM >printenv
HWRevision            127.1.1.0
ProductID             Fritz_Box_7170_AnnexA
SerialNumber          0000000000000000
annex                 A
autoload              yes
bootloaderVersion     1.347
bootserport           tty0
cpufrequency          211968000
firstfreeaddress      0x946C0D14
firmware_version      avm
firmware_info         58.04.84
flashsize             0x00800000
jffs2_size            14
maca                  00:1C:4A:16:2E:C8
macb                  00:1C:4A:16:2E:C9
macwlan               00:1C:4A:03:D0:7F
macdsl                00:1C:4A:16:2E:CA
memsize               0x02000000
modetty0              38400,n,8,1,hw
modetty1              38400,n,8,1,hw
mtd0                  0x90000000,0x90000000
mtd1                  0x90010000,0x90780000
mtd2                  0x90000000,0x90010000
mtd3                  0x90780000,0x907C0000
mtd4                  0x907C0000,0x90800000
my_ipaddress          192.168.178.1
prompt                Eva_AVM
req_fullrate_freq     125000000
sysfrequency          125000000
urlader-version       1347
usb_board_mac         00:1C:4A:16:2E:CB
usb_rndis_mac         00:1C:4A:16:2E:CC
usb_device_id         0x3D00
usb_revision_id       0x0200
usb_manufacturer_name  AVM
wlan_cal              03EE,03F9,0007,00E0,010A,00E1,010A,032B,031B
When i try to recover with the recovery .exe file from avm it says the firmware is not compatible with the recovery firmware. Is there any way to find out if mtd3/4 are damaged and how can i recover them. I don't have any backup files of these partitions.
I can still ftp to adam ftp during startup so i can flash the mtd if needed. If you wish i can include a dump of the boot sequence from serial console.
Could anyone help me recover this box?
Hi after some issues with the network adapter in ruKernelTool i got it working with a hub in between the fritzbox and the pc to get the nic up. I flashed the router with the latest firmware using ruKernelTool and the box is back up and running. Thanx!
