[Info] FRITZ!Box 7560 Fritz!OS 149.07.00-en-de-es-it-fr-pl - Release vom 29.08.2018
18 Apr 2008
Checkpoint: 60668 (deutsche Version vom 08.08.2018 hat 60102)
# New Features in FRITZ!OS 7.00
##Internet:
- **NEW** register for regular status updates for your FRITZ!Box (MyFRITZ! report)
- **NEW** MyFRITZ! internet access to the FRITZ!Box without a warning from the browser (SSL certificate from Let's Encrypt)
##Telephony:
- **NEW** The FRITZ!Box configured as Mesh Master transfers your telephone numbers to an additional FRITZ!Box as a Mesh Repeater.
- **NEW** Scheduling function for call diversion
- **NEW** Telephone numbers can be blocked or added to your contacts directly from the call list
- **NEW** Support for Deutsche Telekom SIP Trunking (DeutschlandLAN SIP Trunk / SIP Trunk Pooling)
##DECT:
- **NEW** FRITZ!Fon phone number display shows region and country area codes
- **NEW** Now five different ring tones of your own can be selected for FRITZ!Fon
- **NEW** FRITZ!Fon start screen event log: received faxes are displayed
- **NEW** FRITZ!Fon Smart Home start screen now scrollable to display more Smart Home devices
- **NEW** Expanded registration mode for (re-)registration of all devices known to the FRITZ!Box, for instance, after switching to a new FRITZ!Box
- **NEW** FRITZ!Box supports software updates for compatible handsets from other manufacturers (CAT-iq SUOTA)
- **NEW** FRITZ!Fon supports updates for FRITZ!Box (can also be protected with a PIN)
- **NEW** Separate volume controls for the alarm sound
- **NEW** FRITZ!Fon media player: save and load playlists as .xsfp files via FRITZ!NAS
- **NEW ** Jump to next/last title when playing podcasts on your FRITZ!Fon
- **NEW** Support for Speedphone 11 from Deutsche Telekom
##Home network:
- **NEW** User interface with new Home Network -> "Mesh" menu for all settings concerning Mesh
- **NEW** Mesh Home Network Overview also shows telephone and Smart Home connections complete with topology and connection quality
- **NEW** In the ex works settings, a second FRITZ!Box connected via Ethernet becomes a Mesh repeater at the push of a button (WPS)
- **NEW** Switch for IP client or router operation in the network settings area
- **NEW** Switch for the function of the FRITZ!Box in the home network (Mesh operating mode) as Mesh Master or Mesh Repeater in the Home Network>Mesh>Mesh Settings and WLAN areas
- **NEW** Mesh events added to the event messages
- **NEW** The settings for push services, auto updates and AVM services are applied to the entire Mesh WiFi
More information on the new features for Mesh is presented at "New features for Mesh"
More information on configuration and using Mesh is presented at en.avm.de/mesh-faq
##Wireless:
- ** NEW** With a "FRITZ! Hotspot it's easier than ever to give guests WiFi access in public places such as bars, restaurants, doctor's practices etc. For details, see Wireless / Guest Access.
- **NEW** Improved wireless security through support of activated Protected Management Frames (PMF)
##Smart Home:
- **NEW** Support for DECT ULE/HAN FUN
With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
# Additional improvements in FRITZ!OS 7.00
## Powerline:
- **IMPROVED** Option for checking and, if necessary, remedying detected interference from powerline to VDLS
## Internet
- **IMPROVED** Display of internet connections on the Overview page also includes WAN connections
- **IMPROVED** Simplified display for internet connections on the Overview page under Connections
- **IMPROVED** Function for removing the FRITZ!Box from the MyFRITZ! account (myfritz.net)
- **IMPROVED** Optimizations for data throughput
- **IMPROVED** Optimizations for DNS resolution
- **Improved** Optimized registration with MyFRITZ! (myfritz.net) also possible without enabling MyFRITZ! internet access, under Internet > MyFRITZ! Account
- *IMPROVED** SHA-2 support for VPN connections
- **IMPROVED** Filter for port 25 (unsecured mail sending) also effective for the Guest Access (Wireless LAN/LAN)
- **CHANGE** Connections to 1&1 lines also with Internet Protocol version 6 (IPv6 and IPv4 Dual Stack)
- **CHANGE** Connections to Vodafone lines also with Internet Protocol version 6 (IPv6 and IPv4 Dual Stack)
- **CHANGE** Type of internet connection "existing connection via wireless LAN" also supports non-encrypted wireless LAN
- **CHANGE** Parental controls no longer differentiate between Windows users
- **CHANGE** Devices blocked for internet use in the parental controls can be reached via VPN
- **CHANGE** Internet service provider "GMX" removed
- **CHANGE** FRITZ!Box devices in IP client mode (as for connection to existing network) can be registered with myfritz.net
- **CHANGE** Certificate signed by letsencrypt.org (for MyFRITZ! addresses)
- **BUG FIX** "Default user already exists" message when configuring parental controls
- **BUG FIX** Possible circumvention of time limits defined in parental controls
- **BUG FIX** Circumvention of parental controls for certain blocked websites
- **BUG FIX** The LAN ports were switched for VPN LAN-LAN linkup
- **BUG FIX** Improved VPN interoperability
- **BUG FIX** VPN user connections not displayed in the home network overview
- **BUG FIX** MyFRITZ! FTP links corrected
- **BUG FIX** MyFRITZ! access or device with MyFRITZ! access could not be deleted under certain circumstances
- **BUG FIX** Error while entering an already assigned IP address for a new device for port sharing
- **BUG FIX** No IPv4 port sharing for devices with IPv6 interface ID during IPv4 internet connection without IPv6
- **BUG FIX** IPv6 NAS sharing link could not be used
- **BUG FIX** Google DynDNS service not supported
- **BUG FIX** Static IP address with /31 network mask not possible
##Telephony:
- **IMPROVED** Redesigned administration of call blocks for incoming calls (telephone numbers)
- **IMPROVED** Optimized management of telephone books
##DECT:
- **IMPROVED** Playback of web radio and podcasts with HTTPS addresses on AVM devices (only if contents can be played back without encryption)
- **BUG FIX** Speedphone 500 could no longer make calls
##Home network:
- **BUG FIX** Possible error message (Error code 1) when IP address entered manually in the Device Details
- **CHANGE** Connection Statistics area for the powerline network moved from the Network Device Details to the Contents>FRITZ!Box Support area
##Wireless:
- **IMPROVED** Band steering for wireless clients that support the 802.11v/k standards
- **IMPROVED** Display of wireless standards 802.11k and 802.11v as "Signal Properties" (for band steering)
- **IMPROVED** Display of frequency bands on Wireless LAN / Radio Channel page in the "Other radio networks in your vicinity" list
- **IMPROVED** Improved changing of SSID in Wireless Assistant during first configuration
- **BuG FIX** Selection of DFS channels in the 5 GHz band possible again in repeater mode
- **BUG FIX** Display of interference sources on Wireless LAN / Radio Channel page in the "Use of the Wireless LAN Channels" list
- **BUG FIX** The entire network environment of the base station is displayed in repeater mode
##Smart Home:
- **IMPROVED** Support for external temperature sensor to determine room temperature
- **IMPROVED** Push notification sent when an interrupted DECT connection is restored
- **IMPROVED** Error while saving Smart Home Device names
##Security:
- **CHANGE** The "Login without password (not recommended) option in the FRITZ!Box user interface now requires pressing a button on the FRITZ!Box
##Diagnostics:
- **IMPROVED** Function diagnostics shows insufficient memory for saving faxes and voice messages when USB storage is full
- **CHANGE** Display of port for Diagnostics & Maintenance
##System:
- **NEW** Additional confirmation for certain changes can now be performed using the Google Authenticator
- **IMPROVED** Redesigned Auto Update page
- **IMPROVED** Event protocol on the Mesh Master also contains all events on the other FRITZ! devices in the Mesh WiFi
- **IMPROVED** Push service sends mail after the update with additional information on the version and update progress
- **IMPROVED** Push service change notice now also includes information on the registration of a new DECT device
- **IMPROVED** Push service change notice on new devices in the home network now also includes information on new Mesh repeaters
- **IMPROVED** "New FRITZ!OS" push service mail now also includes planned time of for auto updates
- **IMPROVED** Optimized time synchronization (NTP) after internet dial-in
- **IMPROVED** Consent to "Diagnostics and Maintenance" does not include permission for software updates
- **IMPROVED** Simplified display for configuration of wireless LAN, LAN and WAN in the Interfaces area of the Overview menu
- **IMPROVED** Redesigned push services overview
- **CHANGE** For security reasons, the preconfigured user "ftpuser" can no longer be granted access from the internet
- **CHANGE** For FRITZ!Box users who are granted access from the Internet, the password must be different from the user name
- **CHANGE** The security of new password assignments must be rated at least "medium" or they will be rejected.
- **CHANGE** Additional confirmation for creating VPN connections
##USB:
- *IMPROVED** Message notifying about possible detriment to FRITZ!Box functions when contents deleted from the FRITZ! folder
- **BUG FIX** System folders no longer indexed for the FRITZ! media server
USB/UMTS:
- **BUG FIX** Internet via mobile network not offered for all detected 3G dongles during first configuration
Download Firmware.image
Download Recovery.exe
Carpati
