fritz!box fon + asterisk (english)
trkostas
23 Mai 2006
hello,
i want to install asterisk to my fritz bon (the box with the 1 ethernet )
i am trying to enable telnet but it doesnt by dialing #96*7*
i had also try several images found on this site but i havent managed to enabled yet
i have firmware no 06.04.49
any advice?
thanks
hello,
any advice?
thanks
ok solved! found an image on wiki for fritz box fon and finally i have enabled telnet
now i can install succesfully asterisk 1.4 or 1.6 but when i run the comand "./cfg_asterisk14 start" my fritz box restart after 1min and asterisk never runs
is there any solution for my problem???
thanx
This numbers depend to the kernel versions running on your Box.
1.4 == kernel V4
1.6 == kernel V6
Joe
thanks joe
how do i find out my kenrnel version?
and how come that i had tried both of them and none worked correctly?
thanks.. great forum
ok... now i need some help
1. i found that asterisk doesn start
i am getting the following message
"Unable to connect to remote asterisk (does /var/run/asterisk/asterisk.ctl
exist?"
i am stacked here...i need some help
