Fritz box fon wlan 7170
mamep
6 Jan 2007
Hello,
I have an 7170 from 1&1 Germany annex b..
And i want to use it in Greece with annex a.
Is it possible to change it to annex a?
Oh thanks..
Any how to in English ?
the meaning of " search-function " is you should try the " Suchen " button
And now how can i setup both fixed line and voip using 7170 to work with the same phone?
Conversion is apparently done - to use box also for landline you need to do changes in the cable. There are several posts in German showing how [thread=108051]contacts in FRITZ[/thread] have to be connected to dsl and telephone line. In short: middle contacts (PIN 4+5) in FRITZ-DSL/TEL connector transmit DSL signal - both neighbouring ones (3+6) are contacts for landline analogue telephone signals. You must connect them accordingly to your telephone connector.
atrora
