Hello!
I use my Fritz in Russia. The connection to provider is over Ethernet port.
But a lot of providers in Russia, and mine too, use PPTP for authorization. So Fritz should make PPTP VPN connection to provider's server over ethernet with login and password. And use this PPTP as WAN.
IP addresses on ethernet interface are static, on PPTP interface are received from DHCP.
Has somebody solved such problems? Is it possible to make any modification to Fritz to support this?
Thanks.
Thanks.
