Fritz!Card PCI + Ubuntu Linux
Lazybone
29 Okt 2005
Moin
hat einer ne gute Anleitung wie ich meine Fritz!Card PCI unter Ubuntu Linux mit Asterisk betreiben kann? Vorzugsweise Deutsch.
Lazybone
hab das jetzt soweit alles gemacht auch die einträge in der extensions.conf nur leider reagiert asterisk garnicht. Kann man auf der Linux ebene testen ob die Fritz!Card überhaupt richtig läuft?
Zeige mal deine Konfiguration bitte!
Martin
capi.conf
; CAPI config
; general section
[general]
chan_capi.so=yes
nationalprefix=0
internationalprefix=00
rxgain=1.0       ;linear receive gain (1.0 = no change)
txgain=1.0       ;linear transmit gain (1.0 = no change)
language=de      ;set default language
;ulaw=yes        ;set this, if you live in u-law world instead of a-law
;jb.....         ;with Asterisk 1.4 you can configure jitterbuffer,
                 ;see Asterisk documentation for all jb* setting available.
;mohinterpret=default ;Asterisk 1.4: default music on hold class when placed on hold.
; interface sections ...
[ISDN1]          ;this example interface gets name 'ISDN1' and may be any
                 ;name not starting with 'g' or 'contr'.
                 ;Use one interface section for each isdn port!
;ntmode=yes      ;if isdn card operates in nt mode, set this to yes
isdnmode=msn     ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
                 ;when using NT-mode, 'DID' should be set in any case
incomingmsn=0231*******    ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123  ;set a default caller id to that interface for dial-out,
                 ;this caller id will be used when dial option 'd' is set.
;controller=0    ;ISDN4BSD default
;controller=7    ;ISDN4BSD USB default
controller=1     ;capi controller number of this interface/port
group=1          ;dialout group
;prefix=0        ;set a prefix to calling number on incoming calls
softdtmf=on      ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on     ;in addition to softdtmf, you can use relaxed dtmf detection
faxdetect=off    ;enable faxdetection and redirection to EXTEN 'fax' for incoming and/or
                 ;outgoing calls. (default='off', possible values: 'incoming','outgoing','both')
accountcode=     ;PBX accountcode to use in CDRs
;amaflags=default;AMA flags for CDR ('default', 'omit', 'billing', or 'documentation')
context=capi-in  ;context for incoming calls
;holdtype=hold   ;when the PBX puts the call on hold, ISDN HOLD will be used. If
                 ;set to 'local' (default value), no hold is done and the PBX may
                 ;play MOH.
;immediate=yes   ;DID: immediate start of pbx with extension 's' if no digits were
                 ;     received on incoming call (no destination number yet)
                 ;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
                 ;     info like REDIRECTINGNUMBER may be lost, but this is necessary for
                 ;     drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1   ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes  ;EICON DIVA SERVER (CAPI) echo cancelation (yes=g165)
                 ;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64     ;echo cancel tail setting (default=0 for maximum)
;echocancelnlp=1 ;activate non-linear-processing; this improves echo cancel ratio, but might
                 ;incorporate variable gain in the signal path.
;bridge=yes      ;native bridging (CAPI line interconnect) if available
;callgroup=1     ;PBX call group
;pickupgroup=1   ;PBX pickup group (which call groups are we allowed to pickup)
;language=de     ;set language for this device (overwrites default language)
;disallow=all    ;RTP codec selection (valid with Eicon DIVA Server only)
;allow=all       ;RTP codec selection (valid with Eicon DIVA Server only)
devices=2        ;number of concurrent calls (b-channels) on this controller
                 ;(2 makes sense for single BRI, 30/23 for PRI/T1)
;qsig=1           ;enable use of Q.SIG extensions. ECMA Variant
;qsig_prnum=1234  ;enable inbound bridging - this should be an QSIG-network-wide unique number
extensions.conf
(ankommend ist meine SIP/ eingehend festnetz)
[general]
static=yes
chan_capi.so=yes
writeprotect=no
;[echotest]
;exten => 81,1,answer
;exten => 81,2,wait,1
;exten => 81,3,playback,demo-echotest
;exten => 81,4,echo
;exten => 81,5,playback,demo-echodone
;exten => 81,6,hangup
[mailbox]
exten => 80,1,VoiceMailMain(${CALLERID(num)},s)
[local]
exten => _3X,1,NoCDR()
exten => _3X,n,Dial,SIP/${EXTEN}|55|Ttr
[arcor_out]
exten => _0.,1,Dial,SIP/${EXTEN}@arcor|45|Ttr
[ankommend]
exten => 0231*****,1,Dial(SIP/30|30|r)
exten => 0231*****,n,Playback(/var/lib/asterisk/mysounds/ansage)
exten => 0231*****,n,voicemail,s30
exten => 0231*****,n,Hangup
[eingehend]
exten => 0231****,1,Dial(SIP/30,20)
exten => 0231****,n,VoiceMail(30)
[default]
;include => echotest
include => mailbox
include => local
include => arcor_out
include => ankommend
include => eingehend
1. Wenn Du einen Mehrgeräteanschluß hast, dann bitte nicht die volle Rufnummer eintragen, sondern nur die MSN's.
2. Es existiert kein Kontext capi-in, dort gehen laut deiner capi.conf die eingehenden Rufe ein siehe:
deshalb musst Du bspw. dein Kontext " ankommend " nach " capi-in " ändern!
3. Außerdem die Rufnummern (0231...) im Kontext ankommend bzw. capi-in wie in der capi.conf anpassen. Siehe Punkt 1.
Martin
ah cool danke es geht.
jetzt noch ne Frage undzwar ist es möglich wenn ich eine zweite ISDN Karte habe dort ein ISDN Telefon anzuschließen? So das es dan klingelt?
Dafür brauchst Du dann aber eine Karte die den NT Modus unterstützt. Das sind spezielle Karten und keine AVM Fritz PCI. Und ich meine gehört zu haben, dass dein ISDN Telefon dann auch eine eigene Stromversorgung braucht, denn diese kann nicht von der Karte bezogen werden.
Martin
hmm ok danke ich werd mir denk ich mal dan ne Fritz!Box Fon kaufen
nochmal ne frage undzwar soll ich ja linux-restricted-modules installieren aber welches genau es gibt ja etliche davon.
Das kommt drauf an welchen Rechner Du hast. Das sicherste ist, du schaust nach welche bei der Installation installiert wurde und nimmst dann einfach nur das Metapaket.
Beispielsweise hast Du einen i386 Kernel nach der Neuinstallation, dann installierst du:
linux-restricted-modules-386
Bei einem generic:
linux-restricted-modules-generic
usw.
Martin
BMatzy
