fritz fon WLAN become Fritz wlan SL :-) SOLVED
hoppala00
16 Mrz 2005
Hi Everybody
today I want to update my fritz fon wlan ( english - Annex A- with modification .. origin was German - Annex B )
well the old version was
08.04.02
and I updated with
fritz.box_fon_wlan.annexa.en.08.04.21.image
( I am %1000000000000 sure that I only use that image )
and after that I could not reach the fritz fon wlan but I gave fixed ip dan reach the box at
192.168.178.254
well the estonishing result was
my fritz fon wlan became a
Fritz WLAN sl WITH VERSION
10.04.21
I tried to recover it with exe file
but the result was
Searching FRITZ!Box Fon WLAN (Annex A) at: 192.168.178.2
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN
Bootstrap: 89
Firmware: 10.04.21
FRITZ!Box Fon WLAN firmware is incompatible with the recovery firmware
so any solution will be appreciated
thanks
hoppala00
Has ist lost the Fon-Features?
yes I lost the fon features .. and now I can not even call the web- interface ...
bot the box can still be pinged
well I think I need to change the firmware version but I have no idea how
I need help :-(
regards
hoppala00
When the Webui says "sl" then the HWRevision doesn't match.
cat /proc/avalanche/env
cat /etc/init.d/rc.init
MfG Oliver
Hi
Thanks Oliver,
thanks for your answer .. but I can not run the telnet .. yes I can ping th box and when I try to recover it with fritz.box_fon_wlan.annexa.en.04.01.recover-image
Bootstrap: 89
Firmware: 10.04.21
I have no idea how the new firmware " fritz.box_fon_wlan.annexa.en.08.04.21.image" change my box to version 10.04.21
I try to find this version but there is no such version at AVM.de
well I will be glad if you can give me instruction what I need to do
many thanks in advance
regards
hoppala00
At startup the file /etc/init.d/rc.init is parsed. When there is no matching HWRevision then you will get the failsafe:
HW=all OEM=all _PRODUKT_NAME=Boot#Error:#running#as#FRITZ!Box#SL
You have to know what HWRevision, Annex and firmware_version your Box has. Obviously, this is not matching to that of the Firmware on the box.
How was this firmware flashed onto the box? Recover?
Greets, Oliver
Solution
If you are having the same problem like I described above here is the solution ( may be was a solution for me .. hope for you too )
first read below ...
copied from another posting
Zuerst musste ich noch
- meinem Laptop LAN port eine statische Adresse geben (192.168.178.2)
- den Laptop LAN port mit dem BOXs LAN port verbinden
Dann konnte ich per telnet 192.168.178.1 21 (sofort nach power-cycle) auf die box connecten und per "SETENV firmware_version,avm" die Variable wieder zurechtbiegen.
220 ADAM2 FTP Server ready.
USER adam2
331 Password required for adam2.
PASS adam2
230 User adam2 successfully logged in.
GETENV firmware_version
firmware_version avme
200 GETENV command successful
200 SETENV command successful
REBOOT
221-Thank you for using the FTP service on ADAM2.
221 Goodbye.
after you do that
get the recovery EXE for German version from AVM's ftp .. and run its process .. after that you will recover your box again
but of course it will be again german version ..
regards
Hoppala00
PatrickSt91
