FritzBox 5140 Dialing Rules.
CidiRome
3 Mrz 2011
Hi there.
To start:
- sorry for writting in English.
- This was the only forum that seem to be able to help me on this AVM product.
I'm trying to configure my box for this scenario:
I have an AVM Fritzbox 5140
I have 2 diferent providers with 2 numbers each;
Each number has its own SIP account that allows one comunication.
I want to create dialling rules like this:
- When dialing to numbers starting by 2 the call shell go to the 1st provider and 1st account, but if the first account is busy with an existing call (incoming or outgoing) the 2nd account of the 1st provider shel be used.
- When dialing all other numbers the call shell go through the 2nd provider using the same kind a rule for busy account as the first rule.
I've tried to put to equal rules configured with both accounts of the same provider, but the second is denied because conflicts with the first.
Any help would be appreciated.
PS: Asterisk/freepbx can do this very well, but this router is not asterisk...
Best Regards.
Hi.
After so long without any reply I must think that my goal was not understood:
In other words what I need is to be able to select more than one destination trunk/sip account for each dialing/election rule.
For example: If I have 3 different providers, for a specific destination I want to be able to define all 3 starting from the cheapest and ending with the more expensive one in a way that if the first is not available or is busy the second or the third is used.
Basically what asterisk Outbound routes do...
Of course this must be done for each specific destination because, provider A may be cheaper for fixed line calling but provided B may be best to call cell phones.
Best Regards.
MANNI86
