[HowTo] FritzBox 7050 SIP port change & VPN
funxlab
21 Sep 2010
Hi Everyone,
First of all I am very sorry for writing in English, as I have no expertise in German, but I hope you guys will help :)
I have a Fritzbox 7050 back in my home country which I want to use in UAE. If you know local ISPs blocks VoIP completely, the one I am using is a bit relax and isn't blocking ports used by PBXEs. I want to know if it is possible to change default port of 5060 on Fritzbox for VoIP. I know and I have tried putting a ":80" at the end of server representing server port but it doesn't help. I want to change it at firmware level as I feel this is the only solution to make it work.
2nd, Is there any VPN client in FritzBox 7050 ? If yes, is it PPTP or L2TP or any other?
Looking forward for your help. :)
Regards.
Jim.
I don't know if it works, when you change the port.
/var/flash/[COLOR=red]voip.cfg[/COLOR]
voipcfg {
        dnsport = 7077;
        rtpport_start = 7078;
        sip_srcport = [COLOR=red]5060[/COLOR];
Thank you for replying, can you please guide how to do it?
mr.panasonic
