[HowTo] FritzBox 7140 and iptables
sbiddo
3 Sep 2013
hello
i have installed freetz on my fritzbox fon wlan 7140
i needed to install a custom firmware to use iptables but i am not sure which option to include when i create the image
i included openvpn, dropbear to have ssh access but i still cannot figure out how to use iptables
can anyone help?
thank you
For iptables is flaged "unstable" you need to be an "expert" to unhide this package (and all other unstable packeges, too ;-)).
ok thanks
i found it now!
cheers
just one last question
i am trying to configure dnsmasq with these options
server=/netflix.com/208.122.23.22
server=/netflix.net/208.122.23.22
server=/nflximg.com/208.122.23.22
server=/nflxext.com/208.122.23.22
so i edit
/var/mod/etc/dnsmasq.conf
and add those lines
the problem is that when i restart dnsmasq from the webinterface it automatically removes those lines
can you tell me where and how to add them so that they are stored in the conf file?
thanks!
I don't use dnsmasq, but all packages are configured by the CGI settings (overwriting any changes done by hand).
Usually you migth add your own settings by putting them into a file /tmp/flash/<package>.extra.
Im this case, extra-file is even shown in the gui, if I see it right in the wiki.
And, following the package description there, there is no need to put upstream servers there, they can be configured in the gui using "Use these upstream nameservers additionally (separated by space)".
So to generate
"Use these upstream nameservers additionally (separated by space)" should be
/netflix.com/208.122.23.22 /netflix.net/208.122.23.22 /nflximg.com/208.122.23.22 /nflxext.com/208.122.23.22
looks like it works!
great!
thanks a lor
figo12
