BusyBox v1.8.2 (2009-04-22 13:54:57 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# dmesg
Linux version 2.6.13.1-ohio (2895) (gcc-Version 3.4.6) #1 Wed Jan 27 13:20:43 CET 2010
memsize=32 MByte
flashsize=8 MByte
&_end=0x94247784 PFN_ALIGN(&_end)=0x94248000 CPHYSADDR(PFN_ALIGN(&_end))=0x14248000 memsize=0x2000000
CPU revision is: 00018448
[ohio_gpio_init]
Determined physical RAM map:
memory: 00248000 @ 14000000 (reserved)
memory: 01db8000 @ 14248000 (usable)
On node 0 totalpages: 8192
[alloc_node_mem_map] reduce size from 2883616 Bytes to 262176 Bytes
[alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x9424b000-0x9428b020
[alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fcb000-0x9428b020
zone=0 zone_size[j]=0x90112
realsize=8192
DMA zone: 8192 pages, LIFO batch:3
zone=1 zone_size[j]=0x0
realsize=0
Normal zone: 0 pages, LIFO batch:1
zone=2 zone_size[j]=0x0
realsize=0
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: console=ttyS0,38400n8r
[ld_mmu_r4xx0] memcpy((void *)(CAC_BASE + 0x100), &except_vec2_generic, 0x30)
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 8kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions). Base=0x9420a8ac
TLB synthesizer field overflow (simm)
Synthesized TLB load handler fastpath (34 instructions) Base=0x9420e620.
Synthesized TLB store handler fastpath (34 instructions) Base=0x9420e820.
Synthesized TLB modify handler fastpath (33 instructions) Base=0x9420ea20.
PID hash table entries: 256 (order: 8, 4096 bytes)
CPU frequency 211.97 MHz
Using 105.984 MHz high precision timer.
[setup_irq]: irq 255 irqaction->handler 0x940430e0 (no_action+0x0/0x8 )
[register_console] enable commandline console 0
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 30080k/30432k available (1592k kernel code, 320k reserved, 388k data, 116k init, 0k highmem)
totalram_pages= 7528
Calibrating delay loop... 211.35 BogoMIPS (lpj=1056768)
loops_per_jiffy=1056768
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
Calling initcall 0x941fe27c: helper_init+0x0/0x30()
Calling initcall 0x941fe53c: ksysfs_init+0x0/0x3c()
Calling initcall 0x94200468: filelock_init+0x0/0x48()
Calling initcall 0x94200d88: init_script_binfmt+0x0/0xc()
Calling initcall 0x94200d94: init_elf_binfmt+0x0/0xc()
Calling initcall 0x94205c70: netlink_proto_init+0x0/0x2ac()
NET: Registered protocol family 16
Calling initcall 0x9420161c: kobject_uevent_init+0x0/0x50()
Calling initcall 0x942018a4: tty_class_init+0x0/0x34()
Calling initcall 0x941f52c4: frame_info_init+0x0/0xb4()
Can't analyze prologue code at 9418c754
Calling initcall 0x94200158: init_bio+0x0/0x17c()
Calling initcall 0x94201f50: misc_init+0x0/0xc0()
Calling initcall 0x94203b18: genhd_device_init+0x0/0x44()
Calling initcall 0x94204230: init_mtd+0x0/0x48()
Calling initcall 0x94204e40: input_init+0x0/0x1e0()
Calling initcall 0x94205378: proto_init+0x0/0x48()
Calling initcall 0x9420553c: net_dev_init+0x0/0x1dc()
Calling initcall 0x94205b68: pktsched_init+0x0/0xc8()
Calling initcall 0x94205c3c: tc_filter_init+0x0/0x34()
Calling initcall 0x942003bc: init_pipe_fs+0x0/0x6c()
Calling initcall 0x94201734: chr_dev_init+0x0/0xb4()
Calling initcall 0x941fd8a4: create_proc_profile+0x0/0x64()
Calling initcall 0x941fd984: ioresources_init+0x0/0xc4()
Calling initcall 0x941fdb90: uid_cache_init+0x0/0x88()
Calling initcall 0x941fdf6c: param_sysfs_init+0x0/0x208()
Calling initcall 0x941fe174: init_posix_timers+0x0/0x108()
Calling initcall 0x941fe2ac: init_posix_cpu_timers+0x0/0xd4()
Calling initcall 0x941fe4fc: kallsyms_init+0x0/0x40()
Calling initcall 0x941ff7b4: init_per_zone_pages_min+0x0/0x64()
Calling initcall 0x941ffbf8: pdflush_init+0x0/0x28()
Calling initcall 0x941ffc20: cpucache_init+0x0/0x20()
Calling initcall 0x941fff6c: kswapd_init+0x0/0x70()
Calling initcall 0x94200020: procswaps_init+0x0/0x40()
Calling initcall 0x94200060: init_tmpfs+0x0/0x3c()
Calling initcall 0x94200428: fasync_init+0x0/0x40()
Calling initcall 0x94200b2c: aio_setup+0x0/0x8c()
Calling initcall 0x94200bb8: inotify_setup+0x0/0xf4()
Calling initcall 0x94200cac: eventpoll_init+0x0/0xdc()
Calling initcall 0x942012e4: init_devpts_fs+0x0/0x48()
Calling initcall 0x9420132c: init_squashfs_fs+0x0/0xe4()
Squashfs 2.2-r2b (released 2006/02/23) (C) 2002-2005 Phillip Lougher
Calling initcall 0x94201410: init_ramfs_fs+0x0/0xc()
Calling initcall 0x94201428: ipc_init+0x0/0x30()
Calling initcall 0x942017e8: rand_initialize+0x0/0x3c()
Calling initcall 0x942018d8: tty_init+0x0/0x184()
Calling initcall 0x94201a5c: pty_init+0x0/0x4f4()
Calling initcall 0x94202010: avm_net_trace_init+0x0/0x80()
avm_net_trace: Up and running.
Calling initcall 0x94202090: avm_power_init+0x0/0x190()
[avm_power]Ohio250 detected -> overclocking possible
Calling initcall 0x94202220: avm_sammel_init+0x0/0x158()
[avm] configured: watchdog eventled enable shift register enable direct gpio
gpio usage: reset=12 clock=13 store=10 data=9
AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jan 27 2010 13:18:10)
Calling initcall 0x94203168: serial8250_init+0x0/0x10c()
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
[uart_add_one_port]
ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
[uart_add_one_port] dont register console port->type = 16
port->cons = 0x941ce340 port->cons->flags = 0x7
[uart_add_one_port] success
Calling initcall 0x94203b5c: noop_init+0x0/0xc()
io scheduler noop registered
Calling initcall 0x94203b68: cpphy_entry_probe+0x0/0x440()
[cpmac] Version: 1.124 - Revision 538:916 - Mi 27.01.2010 13:19:27
[avm_event_source_trigger]: not registered
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
Calling initcall 0x94204038: net_olddevs_init+0x0/0x100()
Calling initcall 0x942041a0: tun_init+0x0/0x90()
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Calling initcall 0x94204278: cmdline_parser_init+0x0/0xc()
Calling initcall 0x94204284: init_mtdchar+0x0/0xc0()
Calling initcall 0x94204344: init_mtdblock+0x0/0xc()
Calling initcall 0x94204350: cfi_probe_init+0x0/0x24()
Calling initcall 0x94204374: cfi_amdstd_init+0x0/0x30()
Calling initcall 0x942043a4: cfi_intelext_init+0x0/0x4c()
Calling initcall 0x942043f0: jedec_probe_init+0x0/0x24()
Calling initcall 0x94204414: map_ram_init+0x0/0x24()
Calling initcall 0x94204438: init_physmap+0x0/0x170()
physmap flash device: 400000 at 10000000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
RedBoot partition parsing not available
Calling initcall 0x942045a8: platram_init+0x0/0x30()
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Calling initcall 0x942045d8: init_ohio_flash+0x0/0x868()
Ohio flash driver (size->0x400000 mem->0x10000000)
flash_size=0x800000
flash_mask=0xffffff
Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
[genprobe_ident_chips] 4 i 0 j 0
[genprobe_ident_chips] 5 i 0 j 1
Ohio flash memory: Swapping erase regions for broken CFI table.
[mtd]: jffs2_size = 7 * 64KByte (0x70000 Bytes)
[ohio_find_hidden_filesystem]: super block found: bytes_used: 0x652461/6628449
[init_ohio_flash] find hidden filesystem size=0x6c7f00 offset=0xb8100
[mtd] configure jffs2 partition
[mtd] fs_size=0x700000 max=0x70000 is=0x70000 max jffs2_size value 7
[mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=0x10000000 size=0x800000
Creating 7 MTD partitions on "Ohio flash memory":
0x000b8100-0x00780000 : "filesystem"
'nor-flash'
'Bits can be cleared (flash)'
'Has an erase function'
mtd: partition "filesystem" doesn't start on an erase block boundary -- force read-only
0x00010000-0x00780000 : "kernel"
'nor-flash'
0x00000000-0x00010000 : "bootloader"
'nor-flash'
0x00780000-0x007c0000 : "tffs (1)"
'nor-flash'
0x007c0000-0x00800000 : "tffs (2)"
'nor-flash'
0x00710000-0x00780000 : "jffs2"
'nor-flash'
0x00010000-0x00710000 : "Kernel without jffs2"
'nor-flash'
partition_info[0]: name=filesystem offset=b8100 size=6c7f00
partition_info[0]: 0xb00b8100: 0x73717368 0x117f
partition_info[1]: name=kernel offset=10000 size=770000
partition_info[1]: 0xb0010000: 0xfeed1281 0xa807d
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=780000 size=40000
partition_info[3]: 0xb0780000: 0x40001 0x7bffffff
partition_info[4]: name=tffs (2) offset=7c0000 size=40000
partition_info[4]: 0xb07c0000: 0x40001 0x7affffff
partition_info[5]: name=jffs2 offset=710000 size=70000
partition_info[5]: 0xb0710000: 0x20031985 0xc
partition_info[6]: name=Kernel without jffs2 offset=10000 size=700000
partition_info[6]: 0xb0010000: 0xfeed1281 0xa807d
Calling initcall 0x94205020: kcapi_init+0x0/0x9c()
Calling initcall 0x94205164: capi_oslib_init+0x0/0x8()
Calling initcall 0x94205c30: blackhole_module_init+0x0/0xc()
Calling initcall 0x94206920: inet_init+0x0/0x504()
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
Calling initcall 0x94209338: init+0x0/0x8()
Calling initcall 0x94209340: bictcp_register+0x0/0xc()
TCP bic registered
Calling initcall 0x9420934c: mcfw_init_module+0x0/0x2c()
mcfw: IGMPv3 fast forwarding
Calling initcall 0x94209378: af_unix_init+0x0/0xa0()
Calling initcall 0x94209418: packet_init+0x0/0x80()
NET: Registered protocol family 17
Calling initcall 0x94209498: br_init+0x0/0x68()
Calling initcall 0x94209554: atm_init+0x0/0xec()
NET: Registered protocol family 8
NET: Registered protocol family 20
Calling initcall 0x942096f8: br2684_init+0x0/0x54()
Calling initcall 0x941f4024: ohio_install_dummy_irq_functions+0x0/0x58()
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
[ohio_late_init]
Calling initcall 0x941f4160: ohio_clk_switch_init+0x0/0x60()
Calling initcall 0x941f43dc: speedup_init+0x0/0x3c()
Calling initcall 0x94201824: seqgen_init+0x0/0x20()
Calling initcall 0x940cef50: avm_event_push_button_init+0x0/0x130()
[avm_new] push_button_gpio=8 value=1 enabled
Calling initcall 0x942029dc: tffs_init+0x0/0x224()
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
Calling initcall 0x9420382c: early_uart_console_switch+0x0/0xb4()
Calling initcall 0x9412bdf8: net_random_reseed+0x0/0x34()
Calling initcall 0x94207e40: ip_auto_config+0x0/0x1120()
[prepare_namespace] new mount root /dev/mtdblock1
use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 116k freed (7557 free)
[setup_irq]: irq 15 irqaction->handler 0x940db17c (serial8250_interrupt+0x0/0x13c )
AR7WDT: System Init UEberwachung 240 Sekunden
TFFS Name Table G
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=5500 key=button_key_2
EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
[piglet]McSP: rFS: 8010 Hz rCLK:2048275 Hz
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
registered device TI Avalanche SAR
tiatm driver (patch_annex=0xc00e40cc)
[tiatm] Set StrictPriority=0
DSP binary filesize = 329848 bytes
[dsl_ur8] dsl serial number successfully set to "465249545a21426f78466f6e574c414e37313730303031463346343046454138"
[tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
[avm_power]#### boostVoltage: DSP Core voltage set to 1,5 V ####
[setup_irq]: irq 23 irqaction->handler 0xc00ca208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
[setup_irq]: irq 31 irqaction->handler 0xc00ca238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
[tiatm]: Powermanagment (States => 1,3,10) supported!
Texas Instruments ATM driver: version:[4.08.01.00]
[tiatm] AvmInterface length: 44
ubik2 driver (ubik2 - 0x10=0xc003efd4)
atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc002cbfc
atm_dsp_register_ubik2: dsp mem pointer 0xa1c10ad0
ubik2_init_interface: DSP-Link Version v3 8480
[ubik2_debug] eof_sync =1
