Fritzbox 7360 FritzOS und Firmware können nicht geupdated werden
mani1995
10 Aug 2015
Guten Tag,
ich habe die Fritzbox 7360 von m-net und möchte nun die neuen Updates der FritzOS und der Firmware updaten.
1. Im Routermenü gibt es den Menüunterpunkt "Update" nirgends. Er fehlt also.
2. Wie kann ich nun die beiden Updates updaten?
3. auf der Seite speedguide.net:8080 bekomme ich diese Werte heraus:
[TABLE="class: t1, width: 1"]
[TR]
[TD]TCP options string = 0204058401010402
[/TD]
[/TR]
[TR]
[TD]MTU = 1452
MTU is not fully optimized for broadband. Consider increasing your MTU to 1500 for better throughput. If you are using a router, it could be limiting your MTU regardless of Registry settings.
[/TD]
[/TR]
[TR]
[TD]MSS = 1412
MSS is not optimized for broadband. Consider increasing your MTU value.
[/TD]
[/TR]
[TR]
[TD]Default TCP Receive Window (RWIN) = 64952
RWIN Scaling (RFC1323) = 0 bits
Unscaled TCP Receive Window = 64952
In Windows 7, unless "TCP/IP Auto-Tuning" is disabled, only the Current TCP Window is displayed. Use the latest TCP Optimizer for tweaking.
You seem to be using Google Chrome. Note that Chrome can modify the TCP Window for sockets it creates under some OSes, and therefore servers may not get your correct RWIN value. You may want to test with a different browser. FAQ
RWIN is a multiple of MSS
Other RWIN values that might work well with your current MTU/MSS:
64952 (up to 2 Mbit lines, depending on latency. MSS * 46) <-- current value
129904 (1-5 Mbit lines, depending on latency. MSS * 46 * 2)
259808 (2-14 Mbit lines, depending on latency. MSS * 46 * 2^2)
519616 (8-30 Mbit lines, depending on latency. MSS * 46 * 2^3)
1039232 (25-60 Mbit lines depending on latency. MSS * 46 * 2^4)
[/TD]
[/TR]
[TR]
[TD]bandwidth * delay product (Note this is not a speed test):
Your TCP Window limits you to: 2598 kbps (325 KBytes/s) @ 200ms
Your TCP Window limits you to: 1039 kbps (130 KBytes/s) @ 500ms
[/TD]
[/TR]
[TR]
[TD]MTU Discovery (RFC1191) = ON
[/TD]
[/TR]
[TR]
[TD]Time to live left = 51 hops
TTL value is ok.
[/TD]
[/TR]
[TR]
[TD]Timestamps (RFC1323) = OFF[/TD]
[/TR]
[TR]
[TD]Selective Acknowledgements (RFC2018) = ON
[/TD]
[/TR]
[TR]
[TD]IP type of service field (RFC1349) = 00000000 (0)
[/TD]
[/TR]
[/TABLE]
Die Werte der MTU und MSS sind falsch eingestellt, doch wie kann ich diese richtig einstellen?
4. Im Routermenü unter System ist das zu finden:
[TABLE="class: zebra, width: 747"]
[TR]
[TD="bgcolor: #EEEEEE"]Automatische Einrichtung und Updates für dieses Gerät durch den Dienstanbieter nicht möglich: Verbindung zum Autokonfigurationsserver fehlgeschlagen.
[/TD]
[/TR]
[/TABLE]
So viele Fehler treten auf, woran liegt das? Am Router selber oder am Anbieter?
Ich hoffe, mir kann hier geholfen werden,
MFG
Hallo im Forum,
Deine Box wurde vermutlich nicht durch Dich im freien Handel erworben, sondern Dir von Deinem Provider an die Hand gegeben.
Schon mal gegooglet ?
Grüße,
JD.
zu 1) Das ist richtig und auch beabsichtigt.
zu 2) FritzOS und Firmware sind ein und dasselbe. Welche hast du denn zur Verfügung?
zu 3) Diese Werte sind je nach Betriebssystem irgendwo in deinem Rechner gespeichert.
zu 4) Das liegt am Router oder am Anbieter. Wenn du die Fritzbox auf Werkseinstellungen zurücksetzen kannst, werden die Automatische Einrichtung und Updates für dieses Gerät durch den Dienstanbieter neu angestoßen.
@JohnDoe42 Der Router wurde mir vom Anbieter geschickt.
@KunterBunter Zurzeit habe ich FritzOS 6.20 drauf. Es gibt aber die neue Version 6.30.
Wie stelle ich den richtigen MTU im Router ein? Sodass auch auf Konsolen der richtige MTU übernommen wird?
Die neue Version 6.30 wird seit 6 Tagen von M-net verteilt. Hast du schon auf die Werkseinstellungen zurück gesetzt? Du kannst aber auch im M-net Forum darum bitten, dass dir die Firmware aufgespielt wird.
Die FritzOS wurde nach dem Zurücksetzen der Werkseinstellung übernommen.
Wie kriege ich jetzt noch MTU und MSS auf den perfekten Stand?
Hast du DS-Lite? Dann kannst du es vergessen, da wird jedes IPv4-Paket in ein IPv6-Paket gepackt und das dann in ein PPPoE-Paket
Ja ich habe DS-Lite
@andiling Es stört mich, da ich mein Internet perfekt konfiguriert haben möchte.
Welchen MTU Wert muss ich nun beispielsweise bei der Ps4 eingeben?
Dabei hilft es dann wahrscheinlich, wenn man sich einfach mal selbst das notwendige Wissen anliest und nicht auf irgendwelche Aussagen in einem "TCP Analyzer" zurückgreift. Der analysiert tatsächlich richtig, aber er kennt eben Deine konkrete Situation mit dem DS-Lite-Anschluß und der dabei notwendigen Reservierung von Platz für die zusätzlichen Informationen zur Kapselung in IPv6-Pakete nicht.
Wenn man gar nicht versteht, was einem dieser Test sagen soll, schadet er offenbar (zumindest der Gesundheit, wenn man jetzt schlechter schläft) mehr, als er nutzt ...
Den richtigen ... oder Du verläßt Dich einfach darauf, daß das vom Protokoll schon ziemlich gut gemanaged wird in der heutigen Zeit. Die Möglichkeit der Einstellung einer abweichenden MTU stammt noch aus der Zeit, wo zu große Pakete mit "DNF"-Flag zu einem Problem wurden und soll in erster Linie dazu dienen, die MTU nach unten zu korrigieren, damit da Probleme umgangen werden können.
Wenn - wie bei Dir offensichtlich - die MTU-Discovery funktioniert, dann ist es das Dümmste, was Du tun kannst, dort mit gefährlichem Halbwissen dazwischen zu funken. Auch hast Du offenbar die Angaben auf der Seite von speedguide.net nur sehr selektiv und nur im Dir genehmen Kontext wahrgenommen ... vielleicht überlegst/liest Du ja doch noch ein wenig. Die Angaben dort sind ja nicht falsch, nur die von Dir daraus gezogenen Schlußfolgerungen sind es.
Diese Mentalität (ich will das letzte Bit aus meiner Leitung/Internetverbindung herausholen und habe eigentlich gar keine Ahnung, was ich da mache) ist jedenfalls netzwerkgestützte Selbstbefriedigung (meine Meinung), genauso wie bei den Leuten, die mit allen möglichen Tricks (und ohne Verständnis der technischen Grundlagen, ich sage nicht, daß man nichts optimieren könnte, wenn man weiß/verstanden hat, was man da tut und die "Reserven" des Anbieters ausschöpfen möchte) die max. theoretische Bandbreite ihrer DSL-Verbindung erhöhen und am Ende wegen steigender Fehlerraten und Wiederholungen doch nur einen geringeren tatsächlichen Durchsatz erreichen.
@PeterPawn Welcher MTU-Wert ist denn dann der richtige? 1452, 1492 oder doch 1500? Vielleicht doch ein anderer? Welchen muss ich denn angeben?
@mani1995:
Ganz einfach: keiner ... wenn das bei der PS4 auch heißt, das dort "PMTU Discovery" (RFC 1191) verwendet werden soll. Ob das so ist, erfährst Du am ehesten bei den "Machern" des dort verwendeten Betriebssystems, mithin beim Sony-Kundendienst.
Warum willst Du da unbedingt von Hand einen Wert festlegen, wenn das automatisch (in aller Regel, nur für die Ausnahmen von dieser Regel braucht man die Einstellmöglichkeit) viel besser geht? Wenn Du keinen Schimmer hast, was das ist und wie das geht, findest Du im Internet garantiert eine Seite, wo das schon einmal erläutert wurde.
domitrader
