# ./transmission-daemon --help
Transmission 2.75 (13675)
http://www.transmissionbt.com/
A fast and easy BitTorrent client
transmission-daemon is a headless Transmission session
that can be controlled via transmission-remote
or the web interface.
Usage: transmission-daemon [options]
Options:
-h --help Display this help page and exit
-a --allowed <list> Allowed IP addresses. (Default:
127.0.0.1)
-b --blocklist Enable peer blocklists
-B --no-blocklist Disable peer blocklists
-c --watch-dir <directory> Where to watch for new .torrent files
-C --no-watch-dir Disable the watch-dir
--incomplete-dir <directory> Where to store new torrents until
they're complete
--no-incomplete-dir Don't store incomplete torrents in a
different location
--finish-dir <directory> Where to move torrents after they
reached a specific ratio
--no-finish-dir Don't move torrents to a different
location after they reached a specific
ratio
-d --dump-settings Dump the settings and exit
-e --logfile <filename> Dump the log messages to this filename
-f --foreground Run in the foreground instead of
daemonizing
-g --config-dir <path> Where to look for configuration files
-p --port <port> RPC port (Default: 9091)
-t --auth Require authentication
-T --no-auth Don't require authentication
-u --username <username> Set username for authentication
-v --password <password> Set password for authentication
-V --version Show version number and exit
--log-error Show error messages
--log-info Show error and info messages
--log-debug Show error, info, and debug messages
-w --download-dir <path> Where to save downloaded data
--paused Pause all torrents on startup
-o --dht Enable distributed hash tables (DHT)
-O --no-dht Disable distributed hash tables (DHT)
-y --lpd Enable local peer discovery (LPD)
-Y --no-lpd Disable local peer discovery (LPD)
--utp Enable uTP for peer connections
--no-utp Disable uTP for peer connections
-P --peerport <port> Port for incoming peers (Default:
51413)
-m --portmap Enable portmapping via NAT-PMP or UPnP
-M --no-portmap Disable portmapping
-L --peerlimit-global <limit> Maximum overall number of peers
(Default: 240)
-l --peerlimit-torrent <limit> Maximum number of peers per torrent
(Default: 60)
-er --encryption-required Encrypt all peer connections
-ep --encryption-preferred Prefer encrypted peer connections
-et --encryption-tolerated Prefer unencrypted peer connections
-i --bind-address-ipv4 <ipv4 addr> Where to listen for peer connections
-I --bind-address-ipv6 <ipv6 addr> Where to listen for peer connections
-r --rpc-bind-address <ipv4 addr> Where to listen for RPC connections
-gsr --global-seedratio ratio All torrents, unless overridden by a
per-torrent setting, should seed until
a specific ratio
-GSR --no-global-seedratio All torrents, unless overridden by a
regardless of ratio
-x --pid-file <pid-file> Enable PID file
