[Gelöst] Fritzbox 7390 startet seit gestern nach 1-2 Stunden neu.
R0cket
20 Sep 2009
seit ein paar tagen startet meine Fritzbox 7390 nach 1-2 stunden neu.
Hier ist der Carsh.log:
2020-09-30 18:34:14(1) [Bus error] dsld([1596]) CRASHED at 0+0x2ab24500 (/lib/libavmcsock.so.2 at 00064500) accessing aa121b22
SIGNO 10 ERRNO 0 CODE 2
Version: 06.86
Watchdog triggered 3 seconds ago
No bugmsg
ze: 00000000 at: 801754e8 v0: 2aedb590 v1: 0000002f
a0: aa121b22 a1: 00000002 a2: 000001b6 a3: 00000000
t0: 00000000 t1: 7fcd6208 t2: 00000000 t3: fffffff4
t4: 00000d9e t5: 444c4e41 t6: 444f432f t7: 00000000
s0: aa121b22 s1: 2ab50000 s2: 00000000 s3: 2aedb590
s4: 000001b6 s5: 00000002 s6: 2aee0500 s7: 2ab20000
t8: 00000000 t9: 2adb8140 k0: 03e75152 k1: 00000000
gp: 2ab518c0 sp: 7fcd6120 fp: 7fcd6120 ra: 2aae84d4
FA aa121b22 (stack overflow)
PC 2ab24500 0+0x2ab24500 (/lib/libavmcsock.so.2 at 00064500)
PC Code: 00000000 1000000b 24030059 <82020000> 1043fffe 26100001 2610ffff 14400007 8f998980
RA 2aae84d4 0+0x2aae84d4 (/lib/libavmcsock.so.2 at 000284d4)
RA Code: 8f9980cc 0320f809 00000000 <ae020008> 04410048 8fbc0018 8f998bdc 0320f809 00000000
[bt]  2ab24500 [2ab24478] <0+0x2ab24478>+0x88 (/lib/libavmcsock.so.2 at 00064478/0x64500)
[bt]  2aae84cc [2aae8490] <0+0x2aae8490>+0x3c (/lib/libavmcsock.so.2 at 00028490/0x284cc)
                        Code: 1040002b 240601b6 8f9980cc <0320f809> 00000000 ae020008 04410048 8fbc0018 8f998bdc
[bt]  2aae8ba0 cmmap_getaddr+0x30 (/lib/libavmcsock.so.2 at 00028b70/0x28ba0)
                        Code: 00808021 8f9980d4 27398490 <0411fe3b> 00000000 8fbf001c 8e020010 8fb00018 03e00008
[bt]  2ad25020 [2ad24fbc] <0+0x2ad24fbc>+0x64 (/lib/libar7cfg.so.1 at 00023fbc/0x24020)
                        Code: 00001021 00402021 8f9982b8 <0320f809> 00000000 00408021 1040fff8 8fbc0010 8c420000
[bt]  2ad265ec [2ad265b4] <0+0x2ad265b4>+0x38 (/lib/libar7cfg.so.1 at 000255b4/0x255ec)
                        Code: afbf002c afb20028 00a08821 <0411fa73> 00808021 8fbc0010 8fa60018 1040001e 8fa7001c
[bt]  2ad266dc StatisticPeriodicUpdate+0x4c (/lib/libar7cfg.so.1 at 00025690/0x256dc)
                        Code: 273955b4 00809021 00e08821 <0411ffb5> 00c08021 8fbc0010 8fbf002c 02602821 8f998038
[bt]  0040fae8 [0040fa20] <0+0x40fa20>+0xc8 (dsld at 0040fa20/0x40fae8)
                        Code: 08103ebd 8fbf009c 8f998a58 <0320f809> 00000000 8fbf009c 8fb40098 8fb30094 8fb20090
[bt]  00414b38 [00414b18] <0+0x414b18>+0x20 (dsld at 00414b18/0x414b38)
                        Code: 24040001 afbc0020 afbf0034 <0c103e88> afb10030 8e020014 10400058 8fbc0020 8f998778
[bt]  2ab27ec0 timercb_docallouts+0x1e4 (/lib/libavmcsock.so.2 at 00067cdc/0x67ec0)
                        Code: 30830001 00951026 0043200b <0320f809> 00000000 8fbc0010 8f9988c0 0320f809 02802021
[bt]  2ab06528 csock_select_with_msecs+0x498 (/lib/libavmcsock.so.2 at 00046090/0x46528)
                        Code: 00000000 8fbc0010 8f998508 <0320f809> 00000000 8fbc0010 8f998264 0320f809 00000000
[bt]  00428878 dsld_main+0x2e94 (dsld at 004259e4/0x428878)
                        Code: 8fbc0028 afc01c48 8f998908 <0320f809> 00000000 8e040810 10800005 8fbc0028 8f998254
[bt]  2aea3540 __uClibc_main+0x2c0 (/lib/libc.so.0 at 00060280/0x60540)
                        Code: 27a20018 ac628c40 8f828ab0 <0320f809> 8c460000 1000001c 8fbc0010 8f908970 8e1900c8
[bt] finished.
Signal Bus error in crashdump: show info (2)
2020-09-30 18:34:17(2) [Bus error] *ªšH([2065]) CRASHED at _dl_find_hash+0xc4 (/lib/ld-uClibc.so.0 at 00001a48) accessing db32231e
ze: 00000000 at: 00000000 v0: 2aab1304 v1: 2aab1304
a0: 2ab0d8a2 a1: 2aaaf064 a2: 2aaaf56c a3: 00000001
t0: 00000001 t1: 00000000 t2: ffffffff t3: 2aaa8000
t4: f0000000 t5: 00000001 t6: 00000007 t7: 2ab0ed50
s0: db3222d2 s1: ffffffff s2: 00000000 s3: 2aaaf064
s4: 2aaaf56c s5: 00000000 s6: 2ab22648 s7: 2ab0d8a2
t8: 00000027 t9: 2aaa9984 k0: 004bcbe0 k1: 00000000
gp: 2aac7010 sp: 2ab22418 fp: 2ab22418 ra: 2aaaa370
FA db32231e (stack overflow)
PC 2aaa9a48 _dl_find_hash+0xc4 (/lib/ld-uClibc.so.0 at 00001a48)
PC Code: 00151080 00621021 8c500000 <8e02004c> 30420004 1440000d 00000000 1280000b 00000000
RA 2aaaa370 __dl_runtime_resolve+0x84 (/lib/ld-uClibc.so.0 at 00002370)
RA Code: 24a5003c 0411fd86 24070001 <00408021> 14400010 8fdc0018 8f828070 8f85801c 8f99806c
[bt]  2aaa9a48 _dl_find_hash+0xc4 (/lib/ld-uClibc.so.0 at 00001984/0x1a48)
[bt]  2aaaa368 __dl_runtime_resolve+0x7c (/lib/ld-uClibc.so.0 at 000022ec/0x2368)
                        Code: afa00010 02602021 24a5003c <0411fd86> 24070001 00408021 14400010 8fdc0018 8f828070
[bt]  2aaae460 _dl_runtime_resolve+0x40 (/lib/ld-uClibc.so.0 at 00006420/0x6460)
                        Code: 03002021 00602821 8f998120 <0411efa2> 00000000 8fbc0020 8fbf0024 8fa40010 8fa50014
[bt] caller return <= _ftext: 00000000 00000000 (?)
[bt] finished.
ich habe mit freetz-NG eine neue firmware gebastelt und es getestet, aber nachdem ich neustarts hatte, bin ich wieder zurück auf meine alte freetz Version mit neuester firmware. Aber die neustarts blieben.
Ich habe versucht auszuschließen, dass es an der Firmware liegt, indem ich eine Firmware aus dem letzten Jahr geflasht habe, die bewährt gut lief. Aber auch damit beliebn die neustarts.
Ich habe jetzt wieder eine Firmware aus Mai drauf, die bis jetzt eingelich stabil lief aber jetzt auch neustarts verursacht.
Ich werde aus dem crash.log nicht schlau. Was verursacht die crashs? Was macht lib/libavmcsock.so?
Tausch doch mal das Netzteil aus...
Ich glaube nicht, dass es das Netzteil ist, aber ich habe es mal mit einem anderen von einer 7390 ausgetauscht.
Wenn die Fritz mit der alten stabil laufenden FW trotzdem neuerdings immer wieder neu startet, scheint es was mit der Hardware zu tun zu haben. Da ist das Netzteil der erste Punkt auf der Liste. ;)
Bist du von einer neueren auf eine ältere Firmware gewechselt? Das kann die ar7 durcheinanderbringen. Im Log sieht man libar7cfg. Sicher mal die Einstellungen und mach ein Werksreset via Recovery (löscht auch Freetz Settings)
Gibts Crashs auch mit original Image? Sind die Fehlermeldungen beim alten und neuen Image gleich?
OK hab das Problem gefunden.
Der SSH server auf den ich mich einlogge ist seit ein paar tagen down und meine autossh instanz meldet fehler. Und ssh wird ständig neugestartet, weil autossh keine verbindung erkennt. nach einer Weile habe ich dutzend ssh instanzen und der FB Prozessor ist ausgelastet. nach einer Weile ist das der FB zu viel und die startet neu und alles beginnt von neu.
Ich habe das Problem erkannt, als ich mir die Energie Nutzung angesehen habe. prozessor war bei 100%. Habe die prozesse per ps gecheckt und da waren dutzende ssh sessions. Habe diese gekillt und prozessorauslastung ging sofort runter auf 45% und die Box läuft stabil.
Ich dachte eigentlich autossh macht keine neue Instanz auf sondern versucht immer die gleiche Instanz neu zu verbinden, bis die verbindung erfolgreich ist.
Aber jetzt wo der SSH server down ist und keine erfolgreiche Verbindung aufgebaut wird, scheint autossh sinnlos neue ssh instanzen zu starten. Wenn die erste instanz sich schon nciht verbindet, wie soll dann die nächste Instanz das schaffen?!
Als der Target SSH server aktiv war, hat autossah nur eine Instanz geöffnet und keine weitere.
Ist das Verhalten von autossh normal?
Reaktionen: gismotro
holh-66
