FritzBox ADSL/POTS cable wiring
murkle
15 Jul 2007
does anyone know where there is a diagram showing which wires do what on the Y cable used by the FritzBox to connect to the ADSL & Telephone ports.
I cut my cable a few months ago to make it shorter, and now can't remember which pins are used for analogue POTS connections.. :-)
sorry, I did search, but searched the wrong forum...
Thanks!
no problem, I made it favourite ;-)
If it´s done, you should edit your first post in order to set the titel to "solved".
Patrick89
