== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Executing [623@from-trunk:1] NoOp("SIP/623-00000029", "Catch-All DID Match - Found 623 - You probably want a DID for this.") in new stack
-- Executing [623@from-trunk:2] Log("SIP/623-00000029", "WARNING,Friendly Scanner from 192.168.200.1") in new stack
[2016-08-16 15:24:33] WARNING[13995][C-00000017]: Ext. 623:2 @ from-trunk: Friendly Scanner from 192.168.200.1
-- Executing [623@from-trunk:3] Set("SIP/623-00000029", "__FROM_DID=623") in new stack
-- Executing [623@from-trunk:4] Goto("SIP/623-00000029", "ext-did,s,1") in new stack
-- Goto (ext-did,s,1)
-- Executing [s@ext-did:1] ExecIf("SIP/623-00000029", "0?Set(__FROM_DID=s)") in new stack
-- Executing [s@ext-did:2] Gosub("SIP/623-00000029", "sub-record-check,s,1(in,s,no)") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/623-00000029", "0?initialized") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/623-00000029", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/623-00000029", "NOW=1471353873") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/623-00000029", "__DAY=16") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/623-00000029", "__MONTH=08") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/623-00000029", "__YEAR=2016") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/623-00000029", "__TIMESTR=20160816-152433") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/623-00000029", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/623-00000029", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/623-00000029", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/623-00000029", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/623-00000029", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/623-00000029", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/623-00000029", "2?checkaction") in new stack
-- Goto (sub-record-check,s,17)
-- Executing [s@sub-record-check:17] GotoIf("SIP/623-00000029", "1?sub-record-check,in,1") in new stack
-- Goto (sub-record-check,in,1)
-- Executing [in@sub-record-check:1] NoOp("SIP/623-00000029", "Inbound Recording Check to s") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/623-00000029", "FROMEXTEN=unknown") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/623-00000029", "12?Set(FROMEXTEN=017********)") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/623-00000029", "recordcheck,1(no,in,s)") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/623-00000029", "Starting recording check against no") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/623-00000029", "no") in new stack
-- Goto (sub-record-check,recordcheck,12)
-- Executing [recordcheck@sub-record-check:12] Set("SIP/623-00000029", "__REC_POLICY_MODE=NO") in new stack
-- Executing [recordcheck@sub-record-check:13] Return("SIP/623-00000029", "") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/623-00000029", "") in new stack
-- Executing [s@ext-did:3] Set("SIP/623-00000029", "CDR(did)=623") in new stack
-- Executing [s@ext-did:4] ExecIf("SIP/623-00000029", "1 ?Set(CALLERID(name)=017*******)") in new stack
-- Executing [s@ext-did:5] Set("SIP/623-00000029", "CHANNEL(musicclass)=default") in new stack
-- Executing [s@ext-did:6] Set("SIP/623-00000029", "__MOHCLASS=default") in new stack
-- Executing [s@ext-did:7] Ringing("SIP/623-00000029", "") in new stack
-- Executing [s@ext-did:8] Set("SIP/623-00000029", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [s@ext-did:9] GotoIf("SIP/623-00000029", "1?post-reverse-charge") in new stack
-- Goto (ext-did,s,11)
-- Executing [s@ext-did:11] NoOp("SIP/623-00000029", "") in new stack
-- Executing [s@ext-did:12] Set("SIP/623-00000029", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [s@ext-did:13] Set("SIP/623-00000029", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [s@ext-did:14] Set("SIP/623-00000029", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [s@ext-did:15] Set("SIP/623-00000029", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [s@ext-did:16] NoOp("SIP/623-00000029", "CallerID Entry Point") in new stack
-- Executing [s@ext-did:17] Goto("SIP/623-00000029", "from-did-direct,10,1") in new stack
-- Goto (from-did-direct,10,1)
-- Executing [10@from-did-direct:1] Set("SIP/623-00000029", "__RINGTIMER=15") in new stack
-- Executing [10@from-did-direct:2] Macro("SIP/623-00000029", "exten-vm,novm,10,0,0,0") in new stack
-- Executing [s@macro-exten-vm:1] Macro("SIP/623-00000029", "user-callerid,") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/623-00000029", "TOUCH_MONITOR=1471353873.41") in new stack
-- Executing [s@macro-user-callerid:2] Set("SIP/623-00000029", "AMPUSER=0176*******") in new stack
-- Executing [s@macro-user-callerid:3] GotoIf("SIP/623-00000029", "0?report") in new stack
-- Executing [s@macro-user-callerid:4] ExecIf("SIP/623-00000029", "1?Set(REALCALLERIDNUM=017********)") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/623-00000029", "AMPUSER=") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/623-00000029", "0?limit") in new stack
-- Executing [s@macro-user-callerid:7] Set("SIP/623-00000029", "AMPUSERCIDNAME=") in new stack
-- Executing [s@macro-user-callerid:8] GotoIf("SIP/623-00000029", "1?report") in new stack
-- Goto (macro-user-callerid,s,14)
-- Executing [s@macro-user-callerid:14] GotoIf("SIP/623-00000029", "0?continue") in new stack
-- Executing [s@macro-user-callerid:15] Set("SIP/623-00000029", "__TTL=64") in new stack
-- Executing [s@macro-user-callerid:16] GotoIf("SIP/623-00000029", "1?continue") in new stack
-- Goto (macro-user-callerid,s,27)
-- Executing [s@macro-user-callerid:27] Set("SIP/623-00000029", "CALLERID(number)=017**********") in new stack
-- Executing [s@macro-user-callerid:28] Set("SIP/623-00000029", "CALLERID(name)=017*********") in new stack
-- Executing [s@macro-user-callerid:29] Set("SIP/623-00000029", "CDR(cnum)=017*******") in new stack
-- Executing [s@macro-user-callerid:30] Set("SIP/623-00000029", "CDR(cnam)=017********") in new stack
-- Executing [s@macro-user-callerid:31] Set("SIP/623-00000029", "CHANNEL(language)=en") in new stack
-- Executing [s@macro-exten-vm:2] Set("SIP/623-00000029", "RingGroupMethod=none") in new stack
-- Executing [s@macro-exten-vm:3] Set("SIP/623-00000029", "__EXTTOCALL=10") in new stack
-- Executing [s@macro-exten-vm:4] Set("SIP/623-00000029", "__PICKUPMARK=10") in new stack
-- Executing [s@macro-exten-vm:5] Set("SIP/623-00000029", "RT=") in new stack
-- Executing [s@macro-exten-vm:6] Gosub("SIP/623-00000029", "sub-record-check,s,1(exten,10,dontcare)") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/623-00000029", "12?initialized") in new stack
-- Goto (sub-record-check,s,10)
-- Executing [s@sub-record-check:12] Set("SIP/623-00000029", "REC_POLICY_MODE_SAVE=NO") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/623-00000029", "5?checkaction") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/623-00000029", "1?sub-record-check,exten,1") in new stack
-- Goto (sub-record-check,exten,1)
-- Executing [exten@sub-record-check:1] NoOp("SIP/623-00000029", "Exten Recording Check between 017****** and 10") in new stack
-- Executing [exten@sub-record-check:2] Set("SIP/623-00000029", "CALLTYPE=external") in new stack
-- Executing [exten@sub-record-check:3] ExecIf("SIP/623-00000029", "0?Set(CALLTYPE=)") in new stack
-- Executing [exten@sub-record-check:4] Set("SIP/623-00000029", "CALLEE=dontcare") in new stack
-- Executing [exten@sub-record-check:5] ExecIf("SIP/623-00000029", "0?Set(CALLEE=dontcare)") in new stack
-- Executing [exten@sub-record-check:6] GotoIf("SIP/623-00000029", "1?callee") in new stack
-- Goto (sub-record-check,exten,11)
-- Executing [exten@sub-record-check:11] Gosub("SIP/623-00000029", "recordcheck,1(dontcare,external,10)") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/623-00000029", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/623-00000029", "dontcare") in new stack
-- Goto (sub-record-check,recordcheck,3)
-- Executing [recordcheck@sub-record-check:3] Return("SIP/623-00000029", "") in new stack
-- Executing [exten@sub-record-check:12] Return("SIP/623-00000029", "") in new stack
-- Executing [s@macro-exten-vm:7] GotoIf("SIP/623-00000029", "1?macrodial") in new stack
-- Goto (macro-exten-vm,s,13)
-- Executing [s@macro-exten-vm:13] GosubIf("SIP/623-00000029", "0?clrheader,1()") in new stack
-- Executing [s@macro-exten-vm:14] Macro("SIP/623-00000029", "dial-one,,Ttr,10") in new stack
-- Executing [s@macro-dial-one:1] Set("SIP/623-00000029", "DEXTEN=10") in new stack
-- Executing [s@macro-dial-one:2] Set("SIP/623-00000029", "DIALSTATUS_CW=") in new stack
-- Executing [s@macro-dial-one:3] GosubIf("SIP/623-00000029", "0?screen,1()") in new stack
-- Executing [s@macro-dial-one:4] GosubIf("SIP/623-00000029", "0?cf,1()") in new stack
-- Executing [s@macro-dial-one:5] GotoIf("SIP/623-00000029", "1?skip1") in new stack
-- Goto (macro-dial-one,s,8)
-- Executing [s@macro-dial-one:8] GotoIf("SIP/623-00000029", "0?nodial") in new stack
-- Executing [s@macro-dial-one:9] GotoIf("SIP/623-00000029", "0?continue") in new stack
-- Executing [s@macro-dial-one:10] Set("SIP/623-00000029", "EXTHASCW=ENABLED") in new stack
-- Executing [s@macro-dial-one:11] GotoIf("SIP/623-00000029", "0?next1:cwinusebusy") in new stack
-- Goto (macro-dial-one,s,23)
-- Executing [s@macro-dial-one:23] GotoIf("SIP/623-00000029", "0?next3:continue") in new stack
-- Goto (macro-dial-one,s,25)
-- Executing [s@macro-dial-one:25] GotoIf("SIP/623-00000029", "0?nodial") in new stack
-- Executing [s@macro-dial-one:26] GosubIf("SIP/623-00000029", "1?dstring,1():dlocal,1()") in new stack
-- Executing [dstring@macro-dial-one:1] Set("SIP/623-00000029", "DSTRING=") in new stack
-- Executing [dstring@macro-dial-one:2] Set("SIP/623-00000029", "DEVICES=10") in new stack
-- Executing [dstring@macro-dial-one:3] ExecIf("SIP/623-00000029", "0?Return()") in new stack
-- Executing [dstring@macro-dial-one:4] ExecIf("SIP/623-00000029", "0?Set(DEVICES=0)") in new stack
-- Executing [dstring@macro-dial-one:5] Set("SIP/623-00000029", "LOOPCNT=1") in new stack
-- Executing [dstring@macro-dial-one:6] Set("SIP/623-00000029", "ITER=1") in new stack
-- Executing [dstring@macro-dial-one:7] Set("SIP/623-00000029", "THISDIAL=10") in new stack
-- Executing [dstring@macro-dial-one:8] GosubIf("SIP/623-00000029", "1?zap2dahdi,1()") in new stack
-- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/623-00000029", "0?Return()") in new stack
-- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/623-00000029", "NEWDIAL=") in new stack
-- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/623-00000029", "LOOPCNT2=1") in new stack
-- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/623-00000029", "ITER2=1") in new stack
-- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/623-00000029", "THISPART2=10") in new stack
-- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/623-00000029", "0?Set(THISPART2=DAHDI)") in new stack
-- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/623-00000029", "NEWDIAL=10&") in new stack
-- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/623-00000029", "ITER2=2") in new stack
-- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/623-00000029", "0?begin2") in new stack
-- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/623-00000029", "THISDIAL=10") in new stack
-- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/623-00000029", "") in new stack
-- Executing [dstring@macro-dial-one:9] GotoIf("SIP/623-00000029", "1?docheck") in new stack
-- Goto (macro-dial-one,dstring,12)
-- Executing [dstring@macro-dial-one:12] GotoIf("SIP/623-00000029", "0?skipset") in new stack
-- Executing [dstring@macro-dial-one:13] Set("SIP/623-00000029", "DSTRING=10&") in new stack
-- Executing [dstring@macro-dial-one:14] Set("SIP/623-00000029", "ITER=2") in new stack
-- Executing [dstring@macro-dial-one:15] GotoIf("SIP/623-00000029", "0?begin") in new stack
-- Executing [dstring@macro-dial-one:16] ExecIf("SIP/623-00000029", "0?Return()") in new stack
-- Executing [dstring@macro-dial-one:17] Set("SIP/623-00000029", "DSTRING=10") in new stack
-- Executing [dstring@macro-dial-one:18] Return("SIP/623-00000029", "") in new stack
-- Executing [s@macro-dial-one:27] GotoIf("SIP/623-00000029", "0?nodial") in new stack
-- Executing [s@macro-dial-one:28] GotoIf("SIP/623-00000029", "0?skiptrace") in new stack
-- Executing [s@macro-dial-one:29] GosubIf("SIP/623-00000029", "1?ctset,1():ctclear,1()") in new stack
-- Executing [ctset@macro-dial-one:1] Set("SIP/623-00000029", "DB(CALLTRACE/10)=017*********") in new stack
-- Executing [ctset@macro-dial-one:2] Return("SIP/623-00000029", "") in new stack
-- Executing [s@macro-dial-one:30] Set("SIP/623-00000029", "D_OPTIONS=Ttr") in new stack
-- Executing [s@macro-dial-one:31] NoOp("SIP/623-00000029", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack
-- Executing [s@macro-dial-one:32] ExecIf("SIP/623-00000029", "0?Set(ALERT_INFO=)") in new stack
-- Executing [s@macro-dial-one:33] ExecIf("SIP/623-00000029", "0?Set(ALERT_INFO=)") in new stack
-- Executing [s@macro-dial-one:34] ExecIf("SIP/623-00000029", "0?Set(ALERT_INFO=)") in new stack
-- Executing [s@macro-dial-one:35] GosubIf("SIP/623-00000029", "0?func-set-sipheader,s,1(Alert-Info,)") in new stack
-- Executing [s@macro-dial-one:36] ExecIf("SIP/623-00000029", "1?Set(CHANNEL(musicclass)=default)") in new stack
-- Executing [s@macro-dial-one:37] GosubIf("SIP/623-00000029", "0?qwait,1()") in new stack
-- Executing [s@macro-dial-one:38] Set("SIP/623-00000029", "__CWIGNORE=") in new stack
-- Executing [s@macro-dial-one:39] Set("SIP/623-00000029", "__KEEPCID=TRUE") in new stack
-- Executing [s@macro-dial-one:40] GotoIf("SIP/623-00000029", "0?usegoto,1") in new stack
-- Executing [s@macro-dial-one:41] GotoIf("SIP/623-00000029", "1?godial") in new stack
-- Goto (macro-dial-one,s,46)
-- Executing [s@macro-dial-one:46] Macro("SIP/623-00000029", "dialout-one-predial-hook,") in new stack
-- Executing [s@macro-dialout-one-predial-hook:1] MacroExit("SIP/623-00000029", "") in new stack
-- Executing [s@macro-dial-one:47] Dial("SIP/623-00000029", "10,,Ttrb(func-apply-sipheaders^s^1)") in new stack
[2016-08-16 15:24:36] WARNING[13995][C-00000017]: app_dial.c:2371 dial_exec_full: Dial argument takes format (technology/resource)
== Spawn extension (macro-dial-one, s, 47) exited non-zero on 'SIP/623-00000029' in macro 'dial-one'
== Spawn extension (macro-exten-vm, s, 14) exited non-zero on 'SIP/623-00000029' in macro 'exten-vm'
== Spawn extension (from-did-direct, 10, 2) exited non-zero on 'SIP/623-00000029'
-- Executing [h@from-did-direct:1] Macro("SIP/623-00000029", "hangupcall,") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("SIP/623-00000029", "1?theend") in new stack
-- Goto (macro-hangupcall,s,3)
-- Executing [s@macro-hangupcall:3] ExecIf("SIP/623-00000029", "0?Set(CDR(recordingfile)=)") in new stack
-- Executing [s@macro-hangupcall:4] Hangup("SIP/623-00000029", "") in new stack
== Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/623-00000029' in macro 'hangupcall'
== Spawn extension (from-did-direct, h, 1) exited non-zero on 'SIP/623-00000029'
