Fritzbox SL WLAN ANNEX A
fritzek
22 Mai 2010
Hi
How do Fritzbox SL WLAN ANNEX A?
I need to neostrada.
Thanks for your help.
Sorry, i don't understand your question.
Do you need an Annex-A- Firmware for your box ?
fritz_als_avm_annex_A_new.tar (10,0 KB, 9716x aufgerufen)
I try, but don't work.
sorry but then you must modify your image, but i have no idea how it work.
Please wait if an other user could help you.
It could be that the ruKernelTool can modify your image, but it didn't try to test it.
Sorry, fritzek, but this is pure nonsense - this tar debrands a branded box - and is valid only for VERY old firmwares! But even if you tried it with the correct ..tar for annex changes "fritz_as_annex_a_kernel_args_newer.tar" it will not work as "SL WLan" contains ONLY the dsl-b-driver.
First important information to give you some advice is: which fw on your box??
ruKernelTool will not work either as there is no Annex A firmware for SL WLan.
Why fritz SL works with annex A and SL Fritz wlan not working?
I have the latest firmware is 04.09.34.
You got a FRITZ SL? Which Fw did it have? You got it work on Annex A? How? Then simply do the same on SL WLan!
Your fw should be 09.04.34 - not 04.09.34? writing error?
Is actually a firmware 09.04.34;)
I Neostrada which works only ANEX A.
Might try it with the "fritz_as...." tar I mentioned. If your dsl line is good enough it might work - more bad than good but it could.
After uploading TAR error pops up the tab but the integration of the DSL is still the word ANEX B.
Exact words of error? Many users believe the message "Firmware Upgrade ist fehlgeschlagen, Fehler: KEIN FEHLER" means an error. THIS is NOT an ERROR - it means everything went well.
Annex will always say "B" - look after "kernel_args annex" in export file. What does it say there?
ich möchte den Thread hier nochmal aufnehmen...
Ich hab die SL WLAN [HWRevision 60, Firmare_version 09.04.34] und hab die als erstes mal von 1und1 debranded mit der *.tar-Methode.
Danach hab ich wie in [URL="http://www.ip-phone-forum.de/showthread.php?t=202529&p=1427267&viewfull=1#post1427267[/URL] beschrieben meine Umgebungsvariablen auf annex A gesetzt und recoverd (Ja mist ist bewusst, dass es keine annexA FW für die SL WLAN gibt).
Nach dem erstellen des Support files, sagt mir die Box als kernel_args "annex=A"
Läuft die Box jetzt auf dem geänderten Frequenzspektrum?
Hintergrund ist, dass ich die Box in Finnland (Ausschließlich AnnexA) verwenden will und es hier wohl schlecht testen kann, oder?
Dannke für die Hilfe
Sollte laufen. Aber mehr schlecht als recht.
Besser ist, eine alte 7170 zu kaufen und mit dem ruKernel tool die Englische Firmware aufzuspielen.
Mit "Echtem" Annex A Treiber hast Du keine Verluste.
Mit der SL kann eine 10000er Linie nur für 7000 gut sein. (Habe schon zig Fritzboxen in Spanien getestet)
Habe den Rat befolgt und mir heute eine generalüberholte FB 7170 geholt.
Ich muss aber sagen, dass ich die Beschreibung für die 7170 unter AnnexA 7170 gegeben ist etwas verwirrend.
Hab ich das richtig verstanden, dass ich lediglich das fritz_as_avm_annex_a_kernel_args.tar eifnach als Firware hochlad nach dem Backup meiner Firmare und gut ist?
Nein, benutze das ru Kernel Tool und mach eine Echte Annex A Box daraus. Firmware version 58.04.84 Englisch
Ist innerhalb von ein paar Minuten erledigt. Aber vorher LESEN!!
Auf der Homepage gibt es dazu ein bebildertes How-To: klick mich
Geht Euch wohl
R@iner
Tolles How-To !
Sehr ausführlich und detailiert erklärt.
Kleine Frage zu den Einstellungen...muss die Box avme gebranded werden? Ich weiß nicht was für ein Unterschied durchs Branden ensteht, aber ich fühl mich normal "wohler", wenn die Box ohne Branding sein könnte.
Gruß und vielen Dank nochmal für das Tutorial an alle Mitwirkenden :cool:
DiamondExchangeNetwork
