[Frage] fritzbox+spa3000
binary_dreamer
24 Jul 2009
hi.
iam looking for a way to add a second pstn number in my fritzbox. it is altered to freetz or asterfritz.
will it be possible to make use of a spa3000 and get it as a voip provider to the fritzbox?
up to now i had no luck with it
any ideas
you should add a valid signature. Then we know wich kind of fritz.box you arre using. And we can help, maybe.
it will be used in a fritzbox 7170 with the original firmware on it. any ideas on that?
192.168.178.50 is the fritz7170
192.168.178.220 is the spa3000
it does not register at all.
this will not work.
Both settings are client settings.
The SPA3000 must have an internal SIP-Proxy.
so is there any way to have spa3000 with fritz7170?
M.CH.
