ALLOCATE (ALLO)
This command may be required by some servers to reserve
sufficient storage to accommodate the new file to be
transferred. The argument shall be a decimal integer
representing the number of bytes (using the logical byte
size) of storage to be reserved for the file. For files
sent with record or page structure a maximum record or page
size (in logical bytes) might also be necessary; this is
indicated by a decimal integer in a second argument field of
the command. This second argument is optional, but when
present should be separated from the first by the three
Telnet characters <SP> R <SP>. This command shall be
followed by a STORe or APPEnd command. The ALLO command
should be treated as a NOOP (no operation) by those servers
which do not require that the maximum size of the file be
declared beforehand, and those servers interested in only
the maximum record or page size should accept a dummy value
in the first argument and ignore it.
