[gelöst] Fehler beim Komilieren von Freetz
freddy4711
7 Jul 2007
Hi...
habe gerade freetz-stable-1.1 kompilieren wollen und habe folgende Fehlermeldung erhalten...kann mir jemand weiterhelfen?
PATH="/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" \
		make -j2 -C source/openssh-5.1p1 sftp-server \
		LDFLAGS="-L. -Lopenbsd-compat/"
make[1]: Betrete Verzeichnis '/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/source/openssh-5.1p1'
(cd openbsd-compat && make)
/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -Wformat-security -fno-builtin-memset  -I. -I.  -DSSHDIR=\"/etc\" -D_PATH_SSH_PROGRAM=\"/usr/bin/ssh\" -D_PATH_SSH_ASKPASS_DEFAULT=\"/usr/lib/ssh-askpass\" -D_PATH_SFTP_SERVER=\"/usr/lib/sftp-server\" -D_PATH_SSH_KEY_SIGN=\"/usr/lib/ssh-keysign\" -D_PATH_SSH_PIDDIR=\"/var/run\" -D_PATH_PRIVSEP_CHROOT_DIR=\"/var/empty\" -DSSH_RAND_HELPER=\"/usr/lib/ssh-rand-helper\" -DHAVE_CONFIG_H -c cipher.c
make[2]: Betrete Verzeichnis '/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/source/openssh-5.1p1/openbsd-compat'
/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Wpointer-arith -Wuninitialized -Wsign-compare -Wno-pointer-sign -Wformat-security -fno-builtin-memset  -I. -I.. -I. -I./..  -DHAVE_CONFIG_H -c fmt_scaled.c
fmt_scaled.c: In function 'scan_scaled':
fmt_scaled.c:170: error: 'LLONG_MAX' undeclared (first use in this function)
fmt_scaled.c:170: error: (Each undeclared identifier is reported only once
fmt_scaled.c:170: error: for each function it appears in.)
make[2]: *** [fmt_scaled.o] Fehler 1
make[2]: Verlasse Verzeichnis '/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/source/openssh-5.1p1/openbsd-compat'
make[1]: *** [openbsd-compat/libopenbsd-compat.a] Fehler 2
make[1]: *** Warte auf noch nicht beendete Prozesse...
make[1]: Verlasse Verzeichnis '/home/andreas/Programme/freetz/speedport.w701v/freetz-stable-1.1/source/openssh-5.1p1'
make: *** [source/openssh-5.1p1/sftp-server] Fehler 2
Meine .config ist im Anhang.
Gruß Andreas
schon wieder so einer Oo
nutz freetz 1.0.2
Hi.
Verwendest du die aktuelle Revision aus dem stable-branch? Mach ma bitte ein "make dirclean" und fang von vorne an.
MfG Oliver
@ichnix: Wieso sollte ich freetz-1.0.2 nutzen...nutze seit Beginn an freetz-stable-1.1 - und hatte noch nie Probleme beim Kompilieren
@olistudent: werde es mit make dirclean probieren
Und welche Rev nutzt du jetzt?
make dirclean hat geholfen...danke
Gruß Andreas
figo12
