gelöst fehlermeldung im mod_load.log 7170 ds0.2.7
heini66
Gesperrt
12 Mrz 2005
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:145: member traffic_class not found in ST_struct vcc_config
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:145: member traffic_class not in vcc_config, try to recover
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:146: member pcr not found in ST_struct vcc_config
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:146: member pcr not in vcc_config, try to recover
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:147: member scr not found in ST_struct vcc_config
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:147: member scr not in vcc_config, try to recover
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:148: member priority not found in ST_struct vcc_config
2002-09-08 14:00:09 ar7cfgctl: /var/flash/ar7.cfg:148: member priority not in vcc_config, try to recover
2002-09-08 14:00:09 ar7cfgctl: load_config(ar7): warning: converted
done.
hat das noch jemand, btw kanns einer erklärten?
(edit)
gelöst:
beta firmware 4007 drauf gehabt, downgrade auf 06 gemacht.
sind neue einträge, mit denen die alte firm nicht kann.
aber was ???
holh-66
