[gelöst] Hylafax bricht nach Senden Übertragung ab
sammlerjaeger
2 Aug 2006
habe Hylafax 5.2.9 und IAXMODEM am Start, aber die Übertragung wird nach dem erfolgreichen Empfang abgebrochen, so dass die Gegenstellen noch einmal zu senden beginnt.
Hier das log:
Oct 02 18:07:50.88: [12264]: SESSION BEGIN 000000030 +49
Oct 02 18:07:50.88: [12264]: HylaFAX (tm) Version 5.2.9
Oct 02 18:07:50.88: [12264]: CallID: '0' '' '<NONE>' '8'
Oct 02 18:07:50.88: [12264]: <-- [4:ATA\r]
Oct 02 18:07:54.60: [12264]: --> [7:CONNECT]
Oct 02 18:07:54.60: [12264]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX0'
Oct 02 18:07:54.60: [12264]: RECV FAX: begin
Oct 02 18:07:54.60: [12264]: <-- data [32]
Oct 02 18:07:54.60: [12264]: <-- data [2]
Oct 02 18:07:55.56: [12264]: --> [7:CONNECT]
Oct 02 18:07:55.56: [12264]: <-- data [23]
Oct 02 18:07:55.56: [12264]: <-- data [2]
Oct 02 18:07:56.30: [12264]: --> [7:CONNECT]
Oct 02 18:07:56.30: [12264]: <-- data [13]
Oct 02 18:07:56.30: [12264]: <-- data [2]
Oct 02 18:07:56.88: [12264]: --> [2:OK]
Oct 02 18:07:56.88: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:07:57.60: [12264]: --> [7:CONNECT]
Oct 02 18:07:58.91: [12264]: --> [2:OK]
Oct 02 18:07:58.91: [12264]: RECV recv TSI (sender id)
Oct 02 18:07:58.91: [12264]: REMOTE TSI "+49"
Oct 02 18:07:58.91: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:07:59.19: [12264]: --> [7:CONNECT]
Oct 02 18:07:59.24: [12264]: --> [2:OK]
Oct 02 18:07:59.24: [12264]: RECV recv DCS (command signal)
Oct 02 18:07:59.24: [12264]: REMOTE wants 9600 bit/s
Oct 02 18:07:59.24: [12264]: REMOTE wants A4 page width (215 mm)
Oct 02 18:07:59.24: [12264]: REMOTE wants unlimited page length
Oct 02 18:07:59.24: [12264]: REMOTE wants 3.85 line/mm
Oct 02 18:07:59.24: [12264]: REMOTE wants 1-D MH
Oct 02 18:07:59.24: [12264]: REMOTE wants T.30 Annex A, 256-byte ECM
Oct 02 18:07:59.24: [12264]: RECV training at v.29 9600 bit/s
Oct 02 18:07:59.24: [12264]: <-- [10:AT+FRM=96\r]
Oct 02 18:07:59.55: [12264]: --> [7:CONNECT]
Oct 02 18:08:01.08: [12264]: RECV: TCF 1820 bytes, 1% non-zero, 1799 zero-run
Oct 02 18:08:01.08: [12264]: --> [10:NO CARRIER]
Oct 02 18:08:01.08: [12264]: <-- [9:AT+FRS=7\r]
Oct 02 18:08:01.12: [12264]: --> [2:OK]
Oct 02 18:08:01.12: [12264]: TRAINING succeeded
Oct 02 18:08:01.12: [12264]: <-- [9:AT+FTH=3\r]
Oct 02 18:08:01.14: [12264]: --> [7:CONNECT]
Oct 02 18:08:01.14: [12264]: <-- data [3]
Oct 02 18:08:01.14: [12264]: <-- data [2]
Oct 02 18:08:02.17: [12264]: --> [2:OK]
Oct 02 18:08:02.17: [12264]: <-- [10:AT+FRM=96\r]
Oct 02 18:08:02.91: [12264]: --> [7:CONNECT]
Oct 02 18:08:03.53: [12264]: RECV received frame number 0
Oct 02 18:08:03.73: [12264]: RECV received frame number 1
Oct 02 18:08:03.95: [12264]: RECV received frame number 2
Oct 02 18:08:04.16: [12264]: RECV received frame number 3
Oct 02 18:08:04.38: [12264]: RECV received frame number 4
Oct 02 18:08:04.58: [12264]: RECV received frame number 5
Oct 02 18:08:04.78: [12264]: RECV received frame number 6
Oct 02 18:08:05.00: [12264]: RECV received frame number 7
Oct 02 18:08:05.20: [12264]: RECV received frame number 8
Oct 02 18:08:05.40: [12264]: RECV received frame number 9
Oct 02 18:08:05.62: [12264]: RECV received frame number 10
Oct 02 18:08:06.01: [12264]: RECV received frame number 11
Oct 02 18:08:06.23: [12264]: RECV received frame number 12
Oct 02 18:08:06.45: [12264]: RECV received frame number 13
Oct 02 18:08:06.66: [12264]: RECV received frame number 14
Oct 02 18:08:06.85: [12264]: RECV received frame number 15
Oct 02 18:08:07.07: [12264]: RECV received frame number 16
Oct 02 18:08:07.28: [12264]: RECV received frame number 17
Oct 02 18:08:07.47: [12264]: RECV received frame number 18
Oct 02 18:08:07.69: [12264]: RECV received frame number 19
Oct 02 18:08:07.90: [12264]: RECV received frame number 20
Oct 02 18:08:08.09: [12264]: RECV received frame number 21
Oct 02 18:08:08.32: [12264]: RECV received frame number 22
Oct 02 18:08:08.53: [12264]: RECV received frame number 23
Oct 02 18:08:08.72: [12264]: RECV received frame number 24
Oct 02 18:08:08.93: [12264]: RECV received frame number 25
Oct 02 18:08:09.35: [12264]: RECV received frame number 26
Oct 02 18:08:09.57: [12264]: RECV received frame number 27
Oct 02 18:08:09.77: [12264]: RECV received frame number 28
Oct 02 18:08:09.97: [12264]: RECV received frame number 29
Oct 02 18:08:10.19: [12264]: RECV received frame number 30
Oct 02 18:08:10.36: [12264]: RECV received frame number 31
Oct 02 18:08:10.36: [12264]: RECV received frame number 32
Oct 02 18:08:10.36: [12264]: RECV received RCP frame
Oct 02 18:08:10.36: [12264]: --> [10:NO CARRIER]
Oct 02 18:08:10.36: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:08:10.55: [12264]: --> [7:CONNECT]
Oct 02 18:08:11.66: [12264]: --> [2:OK]
Oct 02 18:08:11.66: [12264]: RECV recv PPS (partial page signal)
Oct 02 18:08:11.66: [12264]: RECV recv EOP (no more pages or documents)
Oct 02 18:08:11.66: [12264]: RECV received 33 frames of block 1 of page 1
Oct 02 18:08:11.71: [12264]: RECV: 8258 bytes of data, 1170 total lines
Oct 02 18:08:11.72: [12264]: <-- [9:AT+FRS=7\r]
Oct 02 18:08:11.73: [12264]: --> [2:OK]
Oct 02 18:08:11.73: [12264]: RECV send MCF (message confirmation)
Oct 02 18:08:11.73: [12264]: <-- [9:AT+FTH=3\r]
Oct 02 18:08:11.75: [12264]: --> [7:CONNECT]
Oct 02 18:08:11.75: [12264]: <-- data [3]
Oct 02 18:08:11.75: [12264]: <-- data [2]
Oct 02 18:08:12.65: [12264]: --> [2:OK]
Oct 02 18:08:12.65: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:08:16.85: [12264]: --> [7:CONNECT]
Oct 02 18:08:17.98: [12264]: --> [2:OK]
Oct 02 18:08:17.98: [12264]: RECV recv PPS (partial page signal)
Oct 02 18:08:17.98: [12264]: <-- [9:AT+FRS=7\r]
Oct 02 18:08:18.05: [12264]: --> [2:OK]
Oct 02 18:08:18.05: [12264]: <-- [9:AT+FTH=3\r]
Oct 02 18:08:18.06: [12264]: --> [7:CONNECT]
Oct 02 18:08:18.06: [12264]: <-- data [3]
Oct 02 18:08:18.06: [12264]: <-- data [2]
Oct 02 18:08:18.88: [12264]: --> [2:OK]
Oct 02 18:08:18.88: [12264]: RECV send MCF (message confirmation)
Oct 02 18:08:18.88: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:08:23.19: [12264]: --> [7:CONNECT]
Oct 02 18:08:24.30: [12264]: --> [2:OK]
Oct 02 18:08:24.30: [12264]: RECV recv PPS (partial page signal)
Oct 02 18:08:24.30: [12264]: <-- [9:AT+FRS=7\r]
Oct 02 18:08:24.37: [12264]: --> [2:OK]
Oct 02 18:08:24.37: [12264]: <-- [9:AT+FTH=3\r]
Oct 02 18:08:24.39: [12264]: --> [7:CONNECT]
Oct 02 18:08:24.39: [12264]: <-- data [3]
Oct 02 18:08:24.39: [12264]: <-- data [2]
Oct 02 18:08:25.17: [12264]: --> [2:OK]
Oct 02 18:08:25.17: [12264]: RECV send MCF (message confirmation)
Oct 02 18:08:25.17: [12264]: <-- [9:AT+FRH=3\r]
Oct 02 18:08:29.50: [12264]: --> [7:CONNECT]
Oct 02 18:08:30.51: [12264]: --> [2:OK]
Oct 02 18:08:30.51: [12264]: RECV recv DCN (disconnect)
Oct 02 18:08:30.51: [12264]: RECV FAX (000000030): from +49, page 1 in 0:00:17, INF, 3.85 line/mm, 1-D MH, 9600 bit/s
Oct 02 18:08:31.51: [12264]: RECV FAX: bin/faxrcvd 'recvq/fax000000028.tif' 'ttyIAX0' '000000030' '' '0' '' '<NONE>' '8'
Oct 02 18:08:31.51: [12264]: RECV FAX (000000030): recvq/fax000000028.tif from +49, subaddress <unspecified>, 1 pages in 0:00:36
Oct 02 18:08:31.51: [12264]: RECV FAX: end
Oct 02 18:08:31.51: [12264]: SESSION END
... und was noch auffällt die Übertragung wird nur mit 9600 bit/s ausgeführt.
Wo liegt der Fehler?
Sammlerjäger
EDIT:
hatte IAXMODEM 1.2.0 und habe IAXMODEM 1.1.1 installiert, jetzt geht es.
Ob es an der Version lang, ich weiss es nicht, egal.
Callendaar
