make bricht beim bauen der libftdi.so mit fehler ab.
Gruß Michael
PATH=/home/slightly/Desktop/freetz/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/bin:/bin:/sbin:/usr/bin:/usr/sbin \
make -j2 -C source/libftdi-0.14 all
make[1]: Entering directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14'
make all-recursive
make[2]: Entering directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14'
Making all in src
make[3]: Entering directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14/src'
/bin/sh ../libtool --tag=CC --mode=link /home/slightly/Desktop/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -version-info 15:0:14 -o libftdi.la -rpath /usr/lib ftdi.lo -lusb
/home/slightly/Desktop/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared .libs/ftdi.o /usr/lib/libusb.so -march=4kc -Wl,-soname -Wl,libftdi.so.1 -o .libs/libftdi.so.1.14.0
/usr/lib/libusb.so: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make[3]: *** [libftdi.la] Fehler 1
make[3]: Leaving directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14/src'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14'
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/home/slightly/Desktop/freetz/freetz-trunk/source/libftdi-0.14'
make: *** [source/libftdi-0.14/src/.libs/libftdi.so.1.14.0] Fehler 2
slightly@StinkyLinux:~/Desktop/freetz/freetz-trunk$
Gruß Michael
