[Gelöst] Patton, Asterisk Rufnummer übergeben (CallerID)
cstux
21 Apr 2007
bin noch recht neu auf dem Gebiet was VOIP angeht. Kann mir jemand erklären wie ich die Rufnummer von der Patton an meinen Asterisk 1.4.3 weitergeben kann.
Bisher zeigt mir mein VOIP Telefon nur den Trunk User an und nicht die Telefonnummer von dem der Anruft.
[CUSTOM]
disallow =
allow = all
dtmfmode = rfc2833
trunk = yes
type = peer
sendrpid = yes
qualify = no
allow = ulaw,alaw
callerid =
contact =
context = DID_CUSTOM
;;dialformat = ${EXTEN:1}
fromdomain =
fromuser = sipgate
;;username = sipgate
group =
;;hasexten = no
;;hasiax = no
;;hasiax2 = no
canreinvite = no
hassip = yes
host = sip0601
port = 5070
provider =
registeriax = no
registersip = yes
secret = ****
trunkname = Custom
trunkstyle = customvoip
insecure = invite
# SN4634/3BIS/UI                                                 #
# R3.20 2006-10-04 H323 SIP BRI                                  #
# 1970-01-01T04:56:37                                            #
# Generated configuration file                                   #
cli version 3.20
dns-relay
webserver port 80 language en
sntp-client
sntp-client server primary 129.132.2.21 port 123 version 4
system
  ic voice 0
    low-bitrate-codec g729
profile napt NAPT_WAN
profile ppp default
profile tone-set default
profile voip default
  codec 1 g711alaw64k rx-length 20 tx-length 20
  codec 2 g711ulaw64k rx-length 20 tx-length 20
profile voip VOIP-ASTERISK
  codec 1 g729 rx-length 20 tx-length 20
  codec 3 g711alaw64k rx-length 20 tx-length 20
  codec 4 g723-6k3 rx-length 30 tx-length 30
  dejitter-max-delay 200
profile pstn default
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface WAN
    ipaddress dhcp
    use profile napt NAPT_WAN
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface LAN
    ipaddress 10.0.1.1 255.255.255.0
context ip router
  route 0.0.0.0 0.0.0.0 10.0.1.10 0
context cs switch
  interface isdn IF-PBX
    route call dest-interface IF-ASTERISK
  interface sip IF-ASTERISK
    bind gateway ASTERISK
    service default
    route call dest-interface IF-PBX
    address-translation outgoing-call from-header user-part fix sipgate host-part call
    use profile voip VOIP-ASTERISK
context cs switch
  no shutdown
gateway sip ASTERISK
  call-signaling-port 5070
  bind interface LAN router
  service default
    authentication sipgate password nx/MNIzoskpr9r/EvL457A== encrypted
    default-server 130.10.10.217 loose-router
    registrar 130.10.10.217
    user sipgate display-name sipgate
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  bind interface WAN router
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  power-feed
  q921
    permanent-layer2
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      encapsulation cc-isdn
      bind interface IF-PBX switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 1
  shutdown
port bri 0 2
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 2
  shutdown
Eingehende Calls funktionieren! Leider bekomm ich nur den Benutzer angezeigt, keine Telefonnummer. Bin mir nicht sicher ob das ein Problem von Asterisk 1.4 oder der Patton ist.
Bei ausgehenden Calls wird die richtige Nummer angezeigt.
Problem von der Smart Node. Nimm diese Sachen mal raus:
mfg Guard-X
Erstmal vielen Danke für deine schnelle Antwort.
Hast mir aufjedenfall schwer weitergeholfen.
Es funktioniert! *freu*
holh-66
